Great to hear you are up and running...enjoy the pool!
pH and ORP devices and hide buttons
Don't worry about any hijacking, the more the merrier.
I tried this version and have some problems.
In the log, I see a lot of these errors:
Error in ProcessResponse, Argument 'Length' must be greater or equal to zero.
The other problem is the new devices. I can see the devices for pH and ORP but there are no values filled in?
I wasn't clear in my initial post but the pH and ORP values are shown at the same time when the display scrolls.:
"pH 7.6 ORP 640 mV"
not sure if that could be the cause?
thanks
Mats
With this version, I do get values in the devices but there are still some errors:
This is from the thread:
When scrolling to the show the value in the "Default Menu", Screen says: "pH 7.6 ORP 645 mV"
May-18 10:50:42 PM AquaConnect workingstring = 645 mV
May-18 10:50:42 PM AquaConnect detected pH/ORP update
May-18 10:50:42 PM AquaConnect workingstring = pH 7.6
May-18 10:50:42 PM AquaConnect workingstring = 7.6
May-18 10:50:40 PM AquaConnect workingstring = pH 7.6
May-18 10:50:40 PM AquaConnect workingstring = 7.6
May-18 10:50:40 PM AquaConnect workingstring = 645 mV
May-18 10:50:40 PM AquaConnect detected pH/ORP update
May-18 10:50:38 PM AquaConnect workingstring = 7.6
May-18 10:50:38 PM AquaConnect workingstring = 645 mV
May-18 10:50:38 PM AquaConnect detected pH/ORP update
May-18 10:50:38 PM AquaConnect workingstring = pH 7.6
May-18 10:50:36 PM AquaConnect workingstring = 7.6
May-18 10:50:36 PM AquaConnect workingstring = 645 mV
May-18 10:50:36 PM AquaConnect detected pH/ORP update
May-18 10:50:36 PM AquaConnect workingstring = pH 7.6
May-18 10:50:34 PM AquaConnect workingstring = 645 mV
May-18 10:50:34 PM AquaConnect detected pH/ORP update
When scrolling to the show the value in the "Diagnostic Menu", Screen says: "pH 7.6 (Off)ORP 645 mV (Off)" (have not seen the "(Off) " earlier).
May-18 10:53:34 PM AquaConnect Error in ProcessResponse, Argument 'Length' must be greater or equal to zero.
May-18 10:53:34 PM AquaConnect detected pH/ORP update
May-18 10:53:34 PM AquaConnect workingstring =
May-18 10:53:32 PM AquaConnect Error in ProcessResponse, Argument 'Length' must be greater or equal to zero.
May-18 10:53:32 PM AquaConnect detected pH/ORP update
May-18 10:53:32 PM AquaConnect workingstring =
May-18 10:53:28 PM AquaConnect Error in ProcessResponse, Argument 'Length' must be greater or equal to zero.
May-18 10:53:28 PM AquaConnect detected pH/ORP update
May-18 10:53:28 PM AquaConnect workingstring =
May-18 10:53:26 PM AquaConnect detected pH/ORP update
May-18 10:53:26 PM AquaConnect workingstring =
May-18 10:53:26 PM AquaConnect Error in ProcessResponse, Argument 'Length' must be greater or equal to zero.
May-18 10:53:24 PM AquaConnect detected pH/ORP update
thanks
Mats
When I activate the:
Select the option below to create pH and ORP devices if you have the Sense and Dispense unit installed:
pH and ORP Devices Enable
I got the:
in the log.
Can you correct this or did I do something wrong?
I'm running the version : 3.0.2.0
