I finally installed the CA3750 I bought last year to control my pool pump and booster pump/cleaner. Since this is ZWave and is fairly far from my controller, I'm nervous because this thing has to work without fail.
I ended up installing some indicator lights for each device so I can look out the back window and tell if one/both are on. I found some 220v AC indicator lights on ebay and installed them on the front cover. Now, I can look out the back door and tell if it is running or not.
