New house construction using PEX tubing for in-basement-floor and under-subfloor hydronic radiant heat. There are four zones, meaning four pumps, four temp sensors, and a four-zone thermostat. I want to use in-floor sensors to monitor floor temp (recommend with hydronic radiant), have a wall-mount thermostat, and be able to override or change wall-mount using HS. (I'm not yet a HS user, but plan to purchase. Construction phase is open studs, rough-in wiring, getting ready for CAT5e. I welcome any suggestions on thermostats, wiring, etc. I will need to be able to control the heat before HS gets installed and running. Thanks. -Jack
Floor sensor & thermostat for hydronic radiant heat
JackTags: None
Near76
I use AprilAire 8870s for my house and they work just fine with HS 2.0. I put them in my equipment room with remote temp sensors in the walls for each zone, so all of my control is done through touch screens using MainLobby/HS 2.0. Although, you can locally control the 8870 without issue.
