Dirk, I have very little experience with communications over ethernet, ie TCP UDP etc. I know that the Sony uses SOAP. I am not at all familiar with that, but I was recently successful in sending commands to my Global Cache GC-100 using some TCP code that I found on a Homeseer forum. I tell it the IP address and port # and it sends and receives strings. Can I do the same thing with my Sony or is the TCP code different than what is needed to send and receive with SOAP?
Support for Sony TV, Bluray, Media Player
Originally posted by lastdarkjedi View PostDirk, I have very little experience with communications over ethernet, ie TCP UDP etc. I know that the Sony uses SOAP. I am not at all familiar with that, but I was recently successful in sending commands to my Global Cache GC-100 using some TCP code that I found on a Homeseer forum. I tell it the IP address and port # and it sends and receives strings. Can I do the same thing with my Sony or is the TCP code different than what is needed to send and receive with SOAP?
Changes to next beta:- Support Remote Control functions for Samsung devices (2011 and newer or part of the Smart-TV line)
- Support now Roku XS. This is not a DLNA device but it is discovered through DLNA. Beauty is that it publishes the apps it has installed and you can create buttons that automatically start the APP.
- Support Remote Control functions for Onkyo devices (only those that are network attached, so the newer ones)
- Added ability to remove/delete devices
- Added ability to customize which buttons will be under HS control. You can select which remote functions will be linked to HS device buttons
- Added ability to make Import files, so if you have different remote codes for Samsungs, Sonys, Onkyos, you can make you own list of button names and keycodes
- Added Samsungs message service
- To do: TTS, Actions
I just recently picked up the Sony BDP-S590 (Blu Ray), 5 SA-NS400 Network Wi-Fi Speakers and the NAS-SV20i iPod Speaker Dock. All of these are part of the HomeShare series from Sony (as is the SMP-N200 Media Player). Hoping we can get support for the "Party Mode" that allows the DLNA server to sync playback to all the speakers. Also would like to be able to send the TTS output for some Homeseer events to the speakers. They're usually in network standby mode by default, so hopefully this will work.
I was happy to see this plug-in was out there, since I wasn't sure it I'd be able to use any of these with Homeseer. I just installed the .20 Beta last night (first version I installed). And it picked up all my equipment and found my PC's running DLNA services (Play-On, WMP, etc. Let me know if you want any .xml files for testing.
Ron
Originally posted by rschildt View PostI just recently picked up the Sony BDP-S590 (Blu Ray), 5 SA-NS400 Network Wi-Fi Speakers and the NAS-SV20i iPod Speaker Dock. All of these are part of the HomeShare series from Sony (as is the SMP-N200 Media Player). Hoping we can get support for the "Party Mode" that allows the DLNA server to sync playback to all the speakers. Also would like to be able to send the TTS output for some Homeseer events to the speakers. They're usually in network standby mode by default, so hopefully this will work.
Ron
I've been intrigued by this "party mode" capability of my SMP-N200 but can't find any useful information on-line what it does. Does it only allow you to pair speakers with devices or does it do anything else, like chose which speakers are part of your output and allow you to add/remove them on the fly. Does it allow you to share video or only audio? Does Sony have a PC application or some way to add/remove these?
The UPnP/DLNA interface appears to expose the API to set/combine devices in party mode but without extensive tracing on a set of Sony devices who have it, I have no clue how to use it, not even sure if I was to make a test load what to go look for except for to read some settings.
As to the TTS part, I'm working on that but I ran into a major roadblock. After the text is converted to speech, I need to instruct the renderer to play the file. Unfortunately DLNA servers have specific extensions to their web server interface which HS (who is the acting web-server in this case) doesn't have. The HS team so far has been very helpful to make some changes for me but I haven't succeeded to play mp3 on my Sony (I can do .wav files and .jpg) and other devices like my Samsung TV are more DLNA strict and nothing works on them. I'm currently waiting for some other test load from HS ...
Dirk
Dirk - I've just started to play around with the Party Mode, as I just picked up my 5th Speaker and the Blu Ray yesterday (the iPod dock is still on it's way). From what I've done so far, you need a server program that can use Win 7 "Play To" feature. This isn't in iTunes, but is available in Windows Media Player 11 & 12. In WMP, I select a song(s) or playlist, and right click on it and then select "Play to" where a choose a speaker. I believe I canonly choose one from the menu. Then I can physically go to around to each speaker and either press the "Party" button on the remote or the unit to add it in. The other better way is via the Sony Network Audio Remote (on iTunes Store or the Google Play Store), where you select the source (WMP, Sony Home share capable Blu Ray player(s), Dock, etc) and send it to the "Player" (ie Network speakers, Homeshare Speaker Dock, Bravia TV, etc) . in there you can select multiple units to send to or click the "party" button in the app de play it on all compatible devices.
I believe I can also start Pandora, Hulu and other app on the Blu Ray player, and then satart the party mode as well. Haven't tried that yet. I'm sure the iPod Dock can do something similar, but I'll have to check that out next week when it arrives.
I'll be playing around with it this Memorial Day weekend, so if there's something more you need, let ne know.
Originally posted by rschildt View PostDirk - I've just started to play around with the Party Mode, as I just picked up my 5th Speaker and the Blu Ray yesterday (the iPod dock is still on it's way). From what I've done so far, you need a server program that can use Win 7 "Play To" feature. This isn't in iTunes, but is available in Windows Media Player 11 & 12. In WMP, I select a song(s) or playlist, and right click on it and then select "Play to" where a choose a speaker. I believe I canonly choose one from the menu. Then I can physically go to around to each speaker and either press the "Party" button on the remote or the unit to add it in. The other better way is via the Sony Network Audio Remote (on iTunes Store or the Google Play Store), where you select the source (WMP, Sony Home share capable Blu Ray player(s), Dock, etc) and send it to the "Player" (ie Network speakers, Homeshare Speaker Dock, Bravia TV, etc) . in there you can select multiple units to send to or click the "party" button in the app de play it on all compatible devices.
Dirk
Originally posted by rschildt View PostI'll get it installed tonight and give it a try. I'll start a track playing to one speaker, and then manually go to each speaker and add it to the "Party".
Dirk
Received my Sony dock (NAS-SV20i) today, so I played with that a bit. When I pressed the "Party" button, all 5 speakers (SA-NS400's) started playing. Here's what Homeseer picked up in the log:
5/31/2012 7:46:26 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-2. VarName = X_PartyState Value = LISTENING
5/31/2012 7:46:26 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-2 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:46:26 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyState = LISTENING
5/31/2012 7:46:26 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyMode = PARTY
5/31/2012 7:46:26 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartySong = PUBLIC
5/31/2012 7:46:26 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySessionID = 1448305
5/31/2012 7:46:26 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyNumberOfListeners = 0
5/31/2012 7:46:26 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyListenerList =
5/31/2012 7:46:26 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:46:26 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:46:26 PM DLNA Manager SonyPartyStateChange for device = SA-NS400. VarName = X_PartyState Value = LISTENING
5/31/2012 7:46:27 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:46:27 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyState = LISTENING
5/31/2012 7:46:27 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyMode = PARTY
5/31/2012 7:46:27 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartySong = PUBLIC
5/31/2012 7:46:27 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySessionID = 709545
5/31/2012 7:46:27 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyNumberOfListeners = 0
5/31/2012 7:46:27 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyListenerList =
5/31/2012 7:46:27 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:46:27 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:46:27 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-1. VarName = X_PartyState Value = LISTENING
5/31/2012 7:46:27 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-1 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyState = LISTENING
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyMode = PARTY
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartySong = PUBLIC
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySessionID = 1079851
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyNumberOfListeners = 0
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyListenerList =
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:46:28 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-4. VarName = X_PartyState Value = LISTENING
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-4 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyState = LISTENING
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyMode = PARTY
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartySong = PUBLIC
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySessionID = 183789
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyNumberOfListeners = 0
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyListenerList =
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:46:28 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:46:28 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-3. VarName = X_PartyState Value = LISTENING
5/31/2012 7:46:29 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-3 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:46:30 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyState = LISTENING
5/31/2012 7:46:30 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyMode = PARTY
5/31/2012 7:46:30 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartySong = PUBLIC
5/31/2012 7:46:30 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySessionID = 906499
5/31/2012 7:46:30 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyNumberOfListeners = 0
5/31/2012 7:46:30 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyListenerList =
5/31/2012 7:46:30 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:46:30 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:47:45 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-4. VarName = X_PartyState Value = IDLE
5/31/2012 7:47:45 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-4 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:47:45 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyState = IDLE
5/31/2012 7:47:45 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyMode = IDLE
5/31/2012 7:47:45 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartySong = PUBLIC
5/31/2012 7:47:45 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySessionID = 0
5/31/2012 7:47:45 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyNumberOfListeners = 0
5/31/2012 7:47:45 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyListenerList =
5/31/2012 7:47:45 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerUUID =
5/31/2012 7:47:45 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerSessionID = 0
5/31/2012 7:47:56 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-3. VarName = X_PartyState Value = IDLE
5/31/2012 7:47:57 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-3 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:47:57 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyState = IDLE
5/31/2012 7:47:57 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyMode = IDLE
5/31/2012 7:47:57 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartySong = PUBLIC
5/31/2012 7:47:57 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySessionID = 0
5/31/2012 7:47:57 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyNumberOfListeners = 0
5/31/2012 7:47:57 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyListenerList =
5/31/2012 7:47:57 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerUUID =
5/31/2012 7:47:57 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerSessionID = 0
5/31/2012 7:48:01 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-1. VarName = X_PartyState Value = IDLE
5/31/2012 7:48:01 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-1 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:48:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyState = IDLE
5/31/2012 7:48:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyMode = IDLE
5/31/2012 7:48:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartySong = PUBLIC
5/31/2012 7:48:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySessionID = 0
5/31/2012 7:48:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyNumberOfListeners = 0
5/31/2012 7:48:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyListenerList =
5/31/2012 7:48:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerUUID =
5/31/2012 7:48:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerSessionID = 0
5/31/2012 7:48:23 PM DLNA Manager SonyPartyStateChange for device = SA-NS400. VarName = X_PartyState Value = IDLE
5/31/2012 7:48:23 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:48:23 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyState = IDLE
5/31/2012 7:48:23 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyMode = IDLE
5/31/2012 7:48:23 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartySong = PUBLIC
5/31/2012 7:48:23 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySessionID = 0
5/31/2012 7:48:23 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyNumberOfListeners = 0
5/31/2012 7:48:23 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyListenerList =
5/31/2012 7:48:23 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerUUID =
5/31/2012 7:48:23 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerSessionID = 0
5/31/2012 7:48:28 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-2. VarName = X_PartyState Value = IDLE
5/31/2012 7:48:28 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-2 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:48:29 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyState = IDLE
5/31/2012 7:48:29 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyMode = IDLE
5/31/2012 7:48:29 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartySong = PUBLIC
5/31/2012 7:48:29 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySessionID = 0
5/31/2012 7:48:29 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyNumberOfListeners = 0
5/31/2012 7:48:29 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyListenerList =
5/31/2012 7:48:29 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerUUID =
5/31/2012 7:48:29 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerSessionID = 0
5/31/2012 7:49:00 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-1. VarName = X_PartyState Value = LISTENING
5/31/2012 7:49:00 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-1 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:49:00 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyState = LISTENING
5/31/2012 7:49:00 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyMode = PARTY
5/31/2012 7:49:00 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartySong = PUBLIC
5/31/2012 7:49:00 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySessionID = 1461001
5/31/2012 7:49:00 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyNumberOfListeners = 0
5/31/2012 7:49:00 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyListenerList =
5/31/2012 7:49:00 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:49:00 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:49:00 PM DLNA Manager SonyPartyStateChange for device = SA-NS400. VarName = X_PartyState Value = LISTENING
5/31/2012 7:49:01 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:49:01 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyState = LISTENING
5/31/2012 7:49:01 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyMode = PARTY
5/31/2012 7:49:01 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartySong = PUBLIC
5/31/2012 7:49:01 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySessionID = 912697
5/31/2012 7:49:01 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyNumberOfListeners = 0
5/31/2012 7:49:01 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyListenerList =
5/31/2012 7:49:01 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:49:01 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:49:01 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-4. VarName = X_PartyState Value = LISTENING
5/31/2012 7:49:01 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-4 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyState = LISTENING
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyMode = PARTY
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartySong = PUBLIC
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySessionID = 402939
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyNumberOfListeners = 0
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyListenerList =
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:49:02 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-3. VarName = X_PartyState Value = LISTENING
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-3 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyState = LISTENING
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyMode = PARTY
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartySong = PUBLIC
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySessionID = 319651
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyNumberOfListeners = 0
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyListenerList =
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:49:02 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-2. VarName = X_PartyState Value = LISTENING
5/31/2012 7:49:02 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-2 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:49:03 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyState = LISTENING
5/31/2012 7:49:03 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyMode = PARTY
5/31/2012 7:49:03 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartySong = PUBLIC
5/31/2012 7:49:03 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySessionID = 1901455
5/31/2012 7:49:03 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyNumberOfListeners = 0
5/31/2012 7:49:03 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyListenerList =
5/31/2012 7:49:03 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:49:03 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:49:32 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-3. VarName = X_PartyState Value = IDLE
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-3 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyState = IDLE
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyMode = IDLE
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartySong = PUBLIC
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySessionID = 0
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyNumberOfListeners = 0
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyListenerList =
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerUUID =
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerSessionID = 0
5/31/2012 7:49:33 PM DLNA Manager SonyPartyStateChange for device = SA-NS400. VarName = X_PartyState Value = IDLE
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyState = IDLE
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyMode = IDLE
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartySong = PUBLIC
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySessionID = 0
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyNumberOfListeners = 0
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyListenerList =
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerUUID =
5/31/2012 7:49:33 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerSessionID = 0
5/31/2012 7:49:33 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-2. VarName = X_PartyState Value = IDLE
5/31/2012 7:49:34 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-2 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:49:36 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyState = IDLE
5/31/2012 7:49:36 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyMode = IDLE
5/31/2012 7:49:36 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartySong = PUBLIC
5/31/2012 7:49:36 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySessionID = 0
5/31/2012 7:49:36 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyNumberOfListeners = 0
5/31/2012 7:49:36 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyListenerList =
5/31/2012 7:49:36 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerUUID =
5/31/2012 7:49:36 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerSessionID = 0
5/31/2012 7:49:36 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-1. VarName = X_PartyState Value = IDLE
5/31/2012 7:49:36 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-1 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyState = IDLE
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyMode = IDLE
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartySong = PUBLIC
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySessionID = 0
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyNumberOfListeners = 0
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyListenerList =
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerUUID =
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerSessionID = 0
5/31/2012 7:49:37 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-4. VarName = X_PartyState Value = IDLE
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-4 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyState = IDLE
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyMode = IDLE
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartySong = PUBLIC
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySessionID = 0
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyNumberOfListeners = 0
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyListenerList =
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerUUID =
5/31/2012 7:49:37 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerSessionID = 0
5/31/2012 7:50:02 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-4. VarName = X_PartyState Value = LISTENING
5/31/2012 7:50:04 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-4 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:50:04 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyState = LISTENING
5/31/2012 7:50:04 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyMode = PARTY
5/31/2012 7:50:04 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartySong = PUBLIC
5/31/2012 7:50:04 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySessionID = 1060003
5/31/2012 7:50:04 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyNumberOfListeners = 0
5/31/2012 7:50:04 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyListenerList =
5/31/2012 7:50:04 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:50:04 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:50:04 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-1. VarName = X_PartyState Value = LISTENING
5/31/2012 7:50:05 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-1 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:50:06 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyState = LISTENING
5/31/2012 7:50:06 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyMode = PARTY
5/31/2012 7:50:06 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartySong = PUBLIC
5/31/2012 7:50:06 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySessionID = 1113067
5/31/2012 7:50:06 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyNumberOfListeners = 0
5/31/2012 7:50:06 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyListenerList =
5/31/2012 7:50:06 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:50:06 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:50:06 PM DLNA Manager SonyPartyStateChange for device = SA-NS400. VarName = X_PartyState Value = LISTENING
5/31/2012 7:50:06 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:50:07 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyState = LISTENING
5/31/2012 7:50:07 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyMode = PARTY
5/31/2012 7:50:07 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartySong = PUBLIC
5/31/2012 7:50:07 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySessionID = 565761
5/31/2012 7:50:07 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyNumberOfListeners = 0
5/31/2012 7:50:07 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyListenerList =
5/31/2012 7:50:07 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:50:07 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:50:07 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-2. VarName = X_PartyState Value = LISTENING
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-2 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyState = LISTENING
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyMode = PARTY
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartySong = PUBLIC
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySessionID = 1559521
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyNumberOfListeners = 0
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyListenerList =
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:50:08 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-3. VarName = X_PartyState Value = LISTENING
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-3 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyState = LISTENING
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyMode = PARTY
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartySong = PUBLIC
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySessionID = 319717
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyNumberOfListeners = 0
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyListenerList =
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerUUID = uuid:200000000000-1010-8000-5442491fd2ee
5/31/2012 7:50:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerSessionID = 1339295841
5/31/2012 7:52:00 PM Event Event Trigger "Dusk On"
5/31/2012 7:52:00 PM Device Control Device: First Great Room Floor Lamps (A1) ON
5/31/2012 7:52:07 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-2. VarName = X_PartyState Value = IDLE
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-2 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyState = IDLE
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartyMode = IDLE
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyPartySong = PUBLIC
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySessionID = 0
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyNumberOfListeners = 0
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonyListenerList =
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerUUID =
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-2 retrieved SonySingerSessionID = 0
5/31/2012 7:52:08 PM DLNA Manager SonyPartyStateChange for device = SA-NS400. VarName = X_PartyState Value = IDLE
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyState = IDLE
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartyMode = IDLE
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyPartySong = PUBLIC
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySessionID = 0
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyNumberOfListeners = 0
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonyListenerList =
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerUUID =
5/31/2012 7:52:08 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400 retrieved SonySingerSessionID = 0
5/31/2012 7:52:08 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-1. VarName = X_PartyState Value = IDLE
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-1 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyState = IDLE
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartyMode = IDLE
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyPartySong = PUBLIC
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySessionID = 0
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyNumberOfListeners = 0
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonyListenerList =
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerUUID =
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-1 retrieved SonySingerSessionID = 0
5/31/2012 7:52:09 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-4. VarName = X_PartyState Value = IDLE
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-4 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyState = IDLE
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartyMode = IDLE
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyPartySong = PUBLIC
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySessionID = 0
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyNumberOfListeners = 0
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonyListenerList =
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerUUID =
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-4 retrieved SonySingerSessionID = 0
5/31/2012 7:52:09 PM DLNA Manager SonyPartyStateChange for device = SA-NS400-3. VarName = X_PartyState Value = IDLE
5/31/2012 7:52:09 PM DLNA Manager SonyPartyX_GetDeviceInfo for device = SA-NS400-3 retrieved SingerCapability = 10 and TransportPort = 3975
5/31/2012 7:52:10 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyState = IDLE
5/31/2012 7:52:10 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartyMode = IDLE
5/31/2012 7:52:10 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyPartySong = PUBLIC
5/31/2012 7:52:10 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySessionID = 0
5/31/2012 7:52:10 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyNumberOfListeners = 0
5/31/2012 7:52:10 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonyListenerList =
5/31/2012 7:52:10 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerUUID =
5/31/2012 7:52:10 PM DLNA Manager SonyPartyX_GetState for device = SA-NS400-3 retrieved SonySingerSessionID = 0
Originally posted by rschildt View PostReceived my Sony dock (NAS-SV20i) today, so I played with that a bit. When I pressed the "Party" button, all 5 speakers (SA-NS400's) started playing. Here's what Homeseer picked up in the log:
So the way it works is that you press a button on the Sony Dock and it automatically links in any speaker it finds? So you cannot chose which ones that you want to link and which not?
Dirk
Yes the plugin detected the dock, and I added today.
Party mode on the dock and the android app will play to all speakers you have. I can start just one speaker w/ WMP, and the go to any speaker and press the "party" button on the unit or remote to manually add it.
Any ideas why I can't use any of the buttons the plugin creates? The log shows:
6/1/2012 10:08:08 PM Error Web Server Error 404, cannot serve file: C:\Program Files (x86)\HomeSeer HSPRO\html/SA-NS400-4;3
That's just one. All the buttons for my active DLNA devices give the same error. I saw something in the other thread for the .20 plugin that said you need to go into setup and load something for them to work. Not sure where to go to do this.
Originally posted by rschildt View PostYes the plugin detected the dock, and I added today.
Did you consult the help file?
Dirk
