Sapi voices in Ubuntu 14.04
    I am addicted to my Homeseer TTS voice fonts. I mostly utilize Neospeech fonts purchased a few years back from Homeseer. I also purchased the AT&T voice fonts that Homeseer sold.
    Its very easy to install the MS SAPI voice fonts. The following step by step will document what I did to get my SAPI voice fonts working in Ubuntu 14.04.
    There is also an endeavor for Linux call S4L - Sapi for Linux - This endeavor uses the SAPI server running in Wine - still playing with this at this time.
    I am going slow on another Joggler Ubuntu box I just built to make sure the step by step works.
    http://sapi4linux.polip.com/
    Linux Wine Installation
    Read about Linux Wine here first.
    https://www.winehq.org/
    Read a bit here:
    https://launchpad.net/~ubuntu-wine/+archive/ubuntu/ppa
    Install it. I personally installed it this way:
    sudo add-apt-repository ppa:ubuntu-wine/ppa
    sudo apt-get update && sudo apt-get install wine && apt-get install winetricks
    Noticed that installing Wine installs Wintricks by default such that you just have to:
    1 - sudo apt-get update && sudo apt-get install wine
    2 - click on the desktop Wine configuration link - little magic happens for a bit (well creates a wintel environment for you).
    Check your audio in Wine to make sure it works. Just click on the little test button under the audio configuration. Here I used Pulse audio and changed the defaults to it. Your computer / hardware may be different. Most important though is that you can hear audio.
    Note: Put on the Wintel hat while doing this and understand that all of it relates to the base underlying Linux connectivity to your hardware. IE: the Wintel stuff doesn't talk to your hardware directly but rather it talks via emulation with base Linux connectivity.
    Update 1st of October, 2014 Status
    I mentioned with my previous SAPI attempts I got it to work throwing the "kitchen sink" at the Wine build. That little PC / Wine is working just fine.
    On my next build while trying to document the step by step to getting there I have gotten caught up in what appears to be dot net hell. I went slow up until dot net 3.5. Then it went to the toilet literally.
    Sapi 5.1 is working fine BUT seeing other issues ....I should leave well enough alone but will continue as I want to document this. I have had to copy some DLL's and register them to get this to work so far.
    Good stuff. Thanks Pete!
      No, the Russound satellite card is still dead. Haven't had the time or the patience to attempt replacing the ufl connector again. Probably going to have to cut it off the PCB with a dremel.
