It's close. hang in there. We'll post to this thread when we release it.
Firmware for HS-WD100+
Originally posted by jumper4000 View PostWill it also have the option to leave the bottom LED on at all times?
New HS-WD100+ wall dimmer firmware posted: http://board.homeseer.com/showthread.php?t=182206
Originally posted by macromark View PostNew HS-WD100+ wall dimmer firmware posted: http://board.homeseer.com/showthread.php?t=182206
Originally posted by macromark View PostNo, it won't have this option. sorry.
How hard would it have been to add this little feature???? I have 14 of these dimmers now and about 20 other dimmers. All the other ones have their LED on when the lights are off, except these. Did you guys just decide not to add that or is it technically impossible to add?
I'm definitely disappointed.
I agree. I have it on 3 dimmers and the ramp rate is working awesome now.
It takes a really long time to upload, so be patient. I noticed I had better success if I left the lights on when I uploaded the firmware (sounds weird but I would get failures if the lights were off) and it's also an indicator that its completed as the light switch resets itself and the lights go off.
Originally posted by jumper4000 View PostHow hard would it have been to add this little feature???? I have 14 of these dimmers now and about 20 other dimmers. All the other ones have their LED on when the lights are off, except these.
Originally posted by waynehead99 View PostI agree. I have it on 3 dimmers and the ramp rate is working awesome now.
Edit: You are correct on the multi segment LED... I should read all the way thru
Mark, just an FYI, the GE Jasco dimmers (which the HS models after) do have an LED so you can find them in the dark (or convert it to be on when the light is on).
https://byjasco.com/products/ge-z-wa...l-smart-dimmer
Originally posted by waynehead99 View PostEdit: You are correct on the multi segment LED... I should read all the way thru
Nonetheless, as I indicated.. you can achieve what you want by adding an event. I whipped together a little video to show how it works:
Originally posted by sparkman View PostThe Leviton dimmers I have also have the LED on when the dimmer is off...
Cheers
Al
Originally posted by macromark View PostWayne, this is what I wrote: "I don't believe there are any Z-Wave dimmers with multi-segment indicator displays..." The Jasco dimmer doesn't have a multi-segment display. That's what makes ours a bit more complicated to manage.
I tried that a while a go when we were talking about ways to make this work, but then every time I want to turn on the light, I would have to hold the On button all the way, because the last dim level was always set to 1%. So then, I setup another Event to always set the single On tap to 100%, which is not perfect, but acceptable... However, another thing that breaks is the status presentation in apps like ImperiHome. ImperiHome thinks the device is on when it's set to 1%. So, then I started messing with the Status Graphics and values and whatnot, but so far I haven't been able to get it to fully behave the way it should, and even if I finally do, I would have to do it individually for all of these 14 dimmers I have. It's just not practical...
Would it be that difficult for you guys to just add that feature in the firmware? How hard could it be to add a few lines of code in the firmware to say if the light is off, leave the bottom LED on?
Pretty much every other dimmer has that option, and so do your own switches. Even if it's just for the sake of consistency, you guys should add it to the dimmers too
