A new version of the HAI plugin was submitted to the updater this afternoon. It may take a day or so
before it shows up. I am no longer providing the updates here to keep things a little cleaner.
Changes in this version:
***Backup your current installation so you can revert back if needed!!
Scene Users: There is a new tab in the plugin page called "Scenes". It is a test page only.
I need you to see if your scenes work with the commands on that page.
It does not read your existing scenes, only the scene numbers.
You will need to do the following:
--test setting a scene ON, OFF and A-D.
--These are HLC scenes, however, they function as Compose scenes.
--Note which combination you used, the expected behavior, did it work.
--What type of scene controller (mfg) are you using.
This information will be logged and you will need to send me the log files.
The purpose of this approach is that it is difficult to test all scene hardware everyone
is running. The information gathered here, will help me build HS devices so that
you can control your scenes with HS Events.
Note: As of HS3 v3.0.0.312, HST has removed backups of the plugin updates.
For this reason, rolling back to previous versions is dependent on the user making a backup
before upgrading in the updater. Always make a backup of your HS folder before installing updates.
- Fixed - Issue with building events for "Any User Except" (users must delete/rebuild events) (lakemirror)
- Added - Logs page for displaying logs instead of having to get them manually (chasers03)
- Fixed - connection issues (madas)
