ISY vs Insteon plugin
    New to Homeseer, been using Vera with ISY. Before starting my installation/config, looking at if I need the ISY anymore
    What benefits are there to keeping the ISY vs using the PLM directly with the PLM plugin?
    Thx for the help
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    see the following post for a list of the features of this plugin. You will have to do your own comparison against the ISY (I've never used one).
    https://forums.homeseer.com/showthread.php?t=184037
    Mark
    HS3 Pro 4.2.19.5
      Thx for the help
      I have just recently switched from the ISY with a serial PLM to a Hometroller-SEL with a USB PLM ( 2 weeks ago). My Insteon experiences were not good. With the HS plug-in I couldn't get a KeypadLinc to add all the buttons, just the main one. With mnsandler's plug-in the KeypadLinc wouldn't add correctly and the KPL blinked the set button red whenever I pressed a button.
      I saw talk about the USB PLM not being reliable. So I switched everything to Z-Wave and couldn't be happier.
      I think the ISY is great at Insteon, not so good with Z-Wave.
      The Homeseer system is great with Z-Wave, not so good with Insteon.
      Of course I didn't try a USB to serial dongle so I could try using the serial PLM, but it was time anyway to update my system to Z-Wave. I definitely miss my two 8 button KPLs though, there seems to be no Z-Wave equivalent.
        Did you try using the ISY plugin for HS?
        I have 20 insteon switches installed , and another 10 needing to be. Switching out is an expensive proposition for me.
        I also don't have, or plan on, using KPL.
        Thx for the help
          Have you seen this scene controller. It has the 8 buttons which can be programmed for up to 24 devices I believe.
          https://www.amazon.com/ZRC-90US-BW85...keywords=zrc90
            I've never had a problem with my KPLs. Plus Mark is very active on the forums and helps with any problems that come up.
              I tried again to get the KPLs added. First attempt was to Tap to discover which failed again for me.
              So then I tried discovering the KPL by device # which worked great. I am back up and running with my 2 KPLs again. This really is a great plug-in.
              With ISY you could trigger differently whether the button on the KPL was physically pressed or the button was turned on programmatically.
              You would use "if control" to detect a physical button press, or "if status" to detect if the button was turned on by a button press OR an event.
              I'm guessing this doesn't exist in Mark's plug-in?
                there are triggers to capture a physical on or off but not conditions.
                Mark
                HS3 Pro 4.2.19.5
                  Perfect. Figured it out.
