I am using the current temperature reported by my Go Control GC-TBZ48 Thermostat in a script. Once a week or so, the reported temperature stops working. Status on the device has changed from temperature to Dim percentage(!??!!) and I get the following error in the log:
(2) Sensor Multilevel Report for type Air_Temperature received, but the corresponding device Node ID cannot be found.(2) Node/Instance=64/-1
Has anyone else seen this or know of a way to fix it without excluding the thermostat and re-including it? A rescan does not change anything...
