Earlier this year I started to switch over from X-10 to Z-wave. I purchased a HomeTrollerZEE controller and SmartStick+. I started with an Aeotec Z-Stick and upgraded when the SmartStick+ became available. The transition from X10 was pretty smooth, but I believe I exceeded the number of devices a ZEE can comfortable handle. I also want to install several plugins that are not supported by the ZEE.
So I just got a Intel NUC i3 based system, another SmartStick+, and HS3 license. I installed HS3 on the NUC and configured the second SmartStick+. Erased that interface just in case there was something there on from factory testing. So now comes the question. How do I transfer my ZEE network into the NUC?
Some suggestions I see describe using the "Send Network to Another Controller and Make it Primary" on the ZEE and "Receive Network from Another Controller" on the NUC. I assume I should do the later first. I also read that "Backup this Interface" (on the ZEE) and "Restore a Network to this Interface" (on the NUC) might work.
Which method would you all suggest? Maybe there's another way to do this?
Claude
Current Date/Time: 12/21/2015 10:19:56 AM
HomeSeer Version: HS3 ZEE Edition 3.0.0.208
Linux version: Linux HomeTrollerZEE 3.6.11+ #538 PREEMPT Fri Aug 30 20:42:08 BST 2013 armv6l GNU/Linux System Uptime: 33 Days 2 Hours 18 Minutes 25 Seconds
IP Address: 192.168.1.4
Number of Devices: 168
Number of Events: 11
Enabled Plug-Ins
3.0.0.72: HSTouch Server
3.0.0.36: X10
3.0.1.29: Z-Wave
Claude
Enabled Plug-Ins
3.0.0.36: X10
3.0.1.29: Z-Wave
