That's perfect, I'll give it a spin this weekend.
Kodi/XBMC Plug-in - Beta Testing
do you have the Apple Bonjour service installed and running on your HomeSeer machine as explained in the user guide thread?
http://board.homeseer.com/showthread.php?t=161821
Originally posted by vanisher View PostI use XMBC also to listen to internet radio streams. Is there a possibility to directly select a file to play from HS?
When you say you want to be able to select a file from HS, do you mean
(a) you want to do that programmatically from a script
(b) you want a web page from which you could browse your library and select a file to play
If it is possible to parse it to HStouch it would be creat.
but via a script is no problem at all.
What i have done is i created a mapping to my nas which has the strm / tbn files.
With yatse on my tab / phone i can browse the files and select which radiostation i want to hear.
Maybe there is a better way to do it, but that way i don't need to see the screen of xbmc.
in version 3.0.0.4 attached to first post I have added links to the XBMC web interface that will allow you to control your XBMC instances (remote controls + browse media libraries) directly from the HS web pages.
It is still not a solution to browse libraries from HSTouch unless you include the whole web page in one of your HSTouch page.
To implement a more flexible solution for HSTouch, I'm waiting for more info on the media API from HST guys.
you can ignore the warning about XBMC.ini, this file is created by the plugin when it needs it.
Let me know if the plugin still can't find XBMC on your PI.
Make sure all your XBMC settings are set like in the user guide: http://board.homeseer.com/showthread.php?t=161821
especially "Announce these services to other systems via Zeroconf"
Originally posted by spud View Postcool, what was the problem?
sill can't get Pi connected to internet, but is avail to Intranet
will write instruction cheat sheet when done
working on USENET > NewsBIN > SABNZBd+ > FileBOT > Couchpotato >...
Really dusting off the Unix Hat ( Xenix, SCO, SUNoS, Solaris all now gone )Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
Extremely cool plugin! Thank you for all your work in this! I'm all in past trial for sure. Wondering if you could help with the MPAA feature. I've created the event, but just two issues. So I enable "xbmc mpaa rating", "is set to (enter a custom value)" "0 to 0". What do I put here? I even set custom values for all the ratings in the MPAA device setup, but the event is not triggering.
Also, when I manually execute the event i only get the text I put in for "Title", the text I entered for "Message=" does not show. I'm using XBMC 12.2.
