To create a playlist in XBMC, go to the Music section, switch to library mode and then select "New playlist...". Add all the songs you want then save:
On windows your playlist are saved as m3u files in C:\Users\<username>\AppData\Roaming\XBMC\userdata\playlists\ music
Warning: In the current version of XBMC (Frodo), there is a bug that tag m3u files as picture files, so when the plugin will try to load your m3u file XBMC will actually try to start a slideshow. To fix this you need to create a file call advancedsettings.xml in C:\Users\<username>\AppData\Roaming\XBMC\userdata, and paste the following lines in it:
Then in HS, create an event with a XBMC action of type "Player Open Media". Choose "File" as the media type, and enter the path of your m3u file like in the screenshot below.
<advancedsettings> <pictureextensions> <remove>.m3u</remove> </pictureextensions> </advancedsettings>
