If you have a problem with the Cooper scene controllers, please try Z-Wave plugin 3.0.1.136 which is in the Beta section on the plugins page.
I backed out a change that may be causing your issue, I want to see. A change was made to not update HS of a device change an LED is set. I suspect some of you are depending on the device changing from off to on when an LED is set. However, I think there are others that just want to set the LED and do not want the scene status to change. So this change may fix some, but break others. Will have to ponder on how to resolve that. But first lets see if this version fixes the current issue.
Originally posted by jackallweiss
View Post
