CurrentCost plugin beta 1.0.0.61
    Changes in 1.0.0.61:
    * Database is regularly compacted to reduce file size
    Download installer from here:
    ftp://ftp.homeseer.com/updates/Beta/...st1_0_0_61.msi
    Please post any issue you find.
    While I haven't had a chance to try the new beta yet, is the Db compacting user selectable in that you can truncate data back to a specific period?
    Has any enhancements done with the graphing as well?
    Rob
      This version did`nt help me, my grafs is still wrong.
      But, the temrature is working now.
        Seems like it compacted properly.. but now i get this error
        6/1/2012 11:57:04 AM Current Cost Error adding a record to the history database - see the log for more details.
        6/1/2012 11:57:04 AM Current Cost Error (Continued): SQL=///INSERT INTO [History] ([Sensor],[DateTime],[WattMinuteTotal],[WattMinuteCh1],[WattMinuteCh2],[WattMinuteCh3],[Rate],[Compression]) VALUES (0,'2012-06-01 11:57:04',916.125,166.875,749.25,0,0.13,0);///
        6/1/2012 11:57:04 AM Current Cost Error, SQL Exception adding record to the history database: Attempt to write
        6/1/2012 11:56:04 AM Current Cost Error adding a record to the history database - see the log for more details.
        6/1/2012 11:56:04 AM Current Cost Error, Exception adding record to the history database: Cannot set CommandText while a DataReader is active
        6/1/2012 11:55:04 AM Current Cost Error adding a record to the history database - see the log for more details.
        6/1/2012 11:55:04 AM Current Cost Database failed to open. File: C:\Program Files\HomeSeer HSPRO\Data\CurrentCost\History.db, Exception=Object reference not set to an instance of an object.
        6/1/2012 11:55:04 AM Current Cost Database failed to open. File: C:\Program Files\HomeSeer HSPRO\Data\CurrentCost\History.db, Exception=Connection was closed, statement was terminated
        6/1/2012 11:55:00 AM Current Cost VACUUM process on the CurrentCost history database complete in: 00:00:09.5095440
        6/1/2012 11:54:51 AM Current Cost Starting VACUUM process on the CurrentCost history database.
        6/1/2012 11:54:51 AM Current Cost CurrentCost History Data Compaction FINISHED at 6/1/2012 11:54:51 AM
        6/1/2012 11:54:51 AM Current Cost Compact History, Finished at 11:53 AM, 268 Compacted records added, 2647 Uncompressed records deleted. Total time=00:01:02.4786811
        Error adding a record to the history database - see the log for more details. i get everyminute now
        -Tom-
          Seems after restarting homeseer multiple times the error went away.. i think it happen because i was accessing the history page while it was compacting..
          -Tom-
          -Tom-
            -Tom-
            I can confirm this. the error came back when i was access the history page at the same time it was writing to the database(which seems to be every minute)
            -Tom-
            -Tom-
              Please add the ability to specify the meter read date. The graphs and data do not have any meaning if your meter is read middle of the month like most mesh network meters in the south.
                I would like to see the ability to specify rates based off KWh usage.
                My utility charges one rate for up to 900 KWh and a different rate beyond that. Is this something that can be added to the feature request?
                  That is how we bill here in California too! This would be a VERY welcome addition!
                  Transitioning to HS3Pro .298 - WinXPEmbedded
                    Is there anything happening with this plugin????
                    Robert
                      Api
                      Is there any documentation on the API, also is there a setting to adjust the update time
                        Usage dates and Rate schedules
                        I'll place a second request for determining what days define the calculations. As another poster noted, if you can't define the actual customer billing dates the collected information is just not very useful.
                        I'd also like to request more flexibility in rate schedule calculations. I suspect that I am not the only customer that pays a flat fee (or fees), plus cost per kilowatt consumed (which may be tiered).
                        And I'll also second the request for information on the status of development of this program.....
                        TIA
                        HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
                        Home Assistant 2024.3
                        Enabled Plug-Ins
                          Stops collecting data
                          I have the same issue, when accessing the current cost graphs while a write is trying to take place the plug in stops responding and collection stops all together.
                          Any Ideas guys?
                          Dave
                            Does anyone know if there is a way to check the battery status?
                              What battery?
