**********8/27/2013 07:20:53 Z-Wave ********** Adding Z-Wave Device with Node ID of 56 Type GENERIC_TYPE_ENTRY_CONTROL=40H **********8/27/2013 07:20:53 Z-Wave **********8/27/2013 07:20:53 Z-Wave Contacting node 56 to get supported features8/27/2013 07:20:54 Z-Wave Negotiating SECURITY SCHEME for (56)8/27/2013 07:21:30 Error Z-Wave was unable to negotiate a compatible security scheme with node 568/27/2013 07:21:30 Z-Wave Failed to get SECURITY SCHEME from node 56. Device may not be added properly to HomeSeer.8/27/2013 07:21:30 Z-Wave The security device may have a timeout when adding to the network, bring the device close to HomeSeer and use the Add Node button to add it (remove it first)8/27/2013 07:21:30 Z-Wave Warning Failed to add new SECURE node 56 to the network securely - device will not operate properly.8/27/2013 07:21:30 Z-Wave Device: Z-Wave Z-Wave Interface (Node 56) supports class(es): COMMAND_CLASS_MANUFACTURER_SPECIFIC, COMMAND_CLASS_VERSION, COMMAND_CLASS_SECURITY
HomeSeer Version:Professional Edition 2.5.0.60HomeSeer:Is Registered HomeSeer Localization:English (United States)Operating System:Microsoft Windows 7 Professional - Work StationOS Version:6.1.7601 Service Pack: 1.0
This lock used to work and when additional codes were attempted to be added the system could not "get the number of codes." attempts to remove and add have led to these results.
Any ideas?
Any ideas?
