Got an Aeotec Z-Wave Smart Energy Strip, and for the most part it works very well. However I can not get the child devices created for it to update the watt usage properly.
The switches work fine, and the 3rd and 4th outlets do update wattage use properly, however the 1st and 2nd do not. None of them updated until I removed and re-added the device.
In addition I would have expected to see the root device to have a similar configuration settings (Home->Click on Device Name->Click on Configuration Button) as my Aeon Labs Smart Energy Switch, where I can set report rate timing of the groups for W, kWh, etc. However the only settings shown under configuration are for the All on/off setting.
Is there some way I can get it to be more like the Aeon Energy Switch so I can change the update interval per sensor type? Or even get it updating correct?
