Im running into a strange problem on the latest (435) build of HS. At reboot time all of my plugins (and other plugins) load properly. However if I stop a plugin and restart it many times it sits with a status of "INFO: Plugin start is pending". If I kill a plugin (remote and disconnect it from HS) and try to restart it, the connection to HS is made. Name and AccessLevel is called, but InitIO is never called. If I reboot then InitIO is called again normally. This is on Linux and has made debugging horrific (have to reboot the entire system after any change). Lately one plugin always says "INFO: Plugin start is pending". Ive code reviewed it, I can find no difference in the startup logic vs other plugins, but the system always reports this.
Any pointers on tracking down what might be going on?
