The current schedule is April 20th for this change, but that could change (sooner or later).
The change will make the switch work like the earlier 100 series where you can dim down lower. I tested an led with the older firmware and I could dim it so low you could barely see that it was on.
I am not aware of an issue with our switches where it keeps the load on when dimmed all the way down.
Originally posted by jlrichar
View Post
