Hey Gang-
I have attached the latest build of the Russound plugin. This provides functionality to integrate your HomeSeer Media Player and iTunes plugins with Russound. Please note: In order to use this plugin you need the latest versions of all three from the updater (except this one, just use the DLL below).
Setup
New Version Posted on 1/6
Setup
- Create or Modify a source on the Russound config page. You will notice 2 new source types, HomeSeer Media Player and HomeSeer iTunes.
- Set the source as the specified music player and click update.
- Make sure that the output from your computer is connected to your Russound controller. For example, your audio out from your computer connects to the audio in on Russound.
- The Russound plugin automatically detects when the plugin has been enabled. Please note that only 1 stream is supported, so if two zones are tuned to HomeSeer they will both see the same data.
- When the source is selected at the Russound Keypad, it will display a menu. This contains "Genres", "Albums", "Artists", "Playlists", and "Tracks."
- Use the "+" and "-" keys to scroll through options, and the "Play" key to select an option. The "Stop" key returns to the parent menu.
- During Playback, press "Pause" to pause music and "Play" to resume. "Stop" stops music and returns to the parent menu. To select new music without stopping the current music, press "+" or "-"
- The "+" and "-" keys can be held to rapidly scroll through music.
