First it woked , or im doing something wrong , here is what i did ,
the trigger triggers to late after its 0 min to precipiation instead of 15 min or 10 left....
1 event is when its 10 min left for precipiation it will put my virtual dev to raining
second event event is when its 15 minutes left for precipiation and if my virtual device is at no rain it sends out a pushover warning message ,
third event , triggers if there is 0 precipiation between now and 15 min , so it puts my virtual to no rain.
now he triggers the events together at 0 precipiation and keeps spamming my pushover... till the event has triggerd to put my virtual to raining./..
see below
see below
Event name : Virtual device 1 IF Minimum 0.25 mm per hour or more precipitation expected between now and the next 10 minutes at xxxxxx xxxx xxxxxx Nederland AND IF Buiten Buienradar Raining has a value equal to No rain Then Set Device Buiten Buienradar Raining to Raining
Event name : Virtual device 2 IF Maximum 0 mm per hour or less precipitation expected between now and the next 20 minutes at xxxxxx xxxx xxxxxxxx Then Set Device Buiten Buienradar Raining to No rain
Event name : Virtual device 3 IF Minimum 0.25 mm per hour or more precipitation expected between now and the next 15 minutes at xxxxxx xxxx xxxxxx Nederland AND IF Buiten Buienradar Raining has a value equal to No rain Then Send Pushover Message to All Clients Title: Rain alert Message: Rain expected in 15 minutes Details :$$DSA:Buienradar-0-2: Priority: Normal Sound: falling Application: Weather Alerts
