From stuff I ordered on eBay I made a cable for my "slimme meter".
Installed P1 and set "Update energy database every (in minutes)" to 5 minutes.
In the HS setup "Enable Energy Logging and Graphing" is unchecked.
To check if my eBay-cable works, I switched on "Log Received data (raw)":
Raw data looks good and devices within HS are changing approx. every 10 seconds.... as you would expect. In the log-files every 5 minutes I see a message like:
so that's working too (although, energy logging is disabled in Homeseer).
As soon as I enable "Enable Energy Logging and Graphing" in HS I get error messages in the logs:
When I go to View -> Energy I get a single line in my browser "error - Object Reference not set to an instance of an Object".
I found this thread (https://board.homeseer.com/showthread.php?t=185995), so stopped HS, removed energy.hsd and restarted HS again. The energy-view now works, but P1 stopped working.... Putting back the old energy.hsd does not work.
Switched switched on "Log Received data (raw)" in P1 this is what I get :
I have to remove P1 completly and re-install it to get it working again.
Someone a clue what causes the issues and how the solve them?
My setup:
Current Date/Time: 29-12-2016 12:32:08
HomeSeer Version: HS3 Standard Edition 3.0.0.297
Operating System: Microsoft Windows 10 Pro - Work Station
System Uptime: 0 Days 0 Hours 15 Minutes 9 Seconds
IP Address: 192.168.178.61
Number of Devices: 180
Number of Events: 36
Available Threads: 100
Enabled Plug-Ins
2.0.35.0: BLLAN
3.0.0.21: Buienradar
3.0.0.1: FritzTR064
3.0.0.75: HSTouch Server
3.0.0.8: P1
30.0.0.33: RFXCOM
3.0.0.57: weatherXML
dec-29 11:59:46 P1 !4F76 dec-29 11:59:46 P1 1-0:31.7.0(004*A) dec-29 11:59:46 P1 1-0:21.7.0(00.964*kW) dec-29 11:59:46 P1 1-0:22.7.0(00.000*kW) dec-29 11:59:46 P1 0-1:24.1.0(003) dec-29 11:59:46 P1 0-1:96.1.0(4730303139333430333034343630393136) dec-29 11:59:46 P1 0-1:24.2.1(161229110000W)(00494.500*m3) dec-29 11:59:46 P1 1-0:2.7.0(00.000*kW) dec-29 11:59:46 P1 0-0:96.7.21(00001) dec-29 11:59:46 P1 0-0:96.7.9(00001) dec-29 11:59:46 P1 1-0:99.97.0(1)(0-0:96.7.19)(000101000001W)(2147483647*s) dec-29 11:59:46 P1 1-0:32.32.0(00000) dec-29 11:59:46 P1 1-0:32.36.0(00000) dec-29 11:59:46 P1 0-0:96.13.1() dec-29 11:59:46 P1 0-0:96.13.0() dec-29 11:59:46 P1 1-0:1.7.0(00.964*kW) dec-29 11:59:46 P1 1-0:2.8.1(000000.000*kWh) dec-29 11:59:46 P1 1-0:2.8.2(000000.000*kWh) dec-29 11:59:46 P1 0-0:96.14.0(0002) dec-29 11:59:46 P1 1-0:1.8.2(001358.700*kWh) dec-29 11:59:45 P1 1-0:1.8.1(001231.024*kWh) dec-29 11:59:45 P1 0-0:1.0.0(161229115945W) dec-29 11:59:45 P1 0-0:96.1.1(4530303235303030303634323637333136) dec-29 11:59:44 P1 /KFM5KAIFA-METER dec-29 11:59:44 P1 1-3:0.2.8(42)
dec-29 12:04:05 P1 Update energy database ok, device 307, last update 11:58:55, usage 0,083kWh, rate 0 dec-29 12:04:04 P1 Update energy database ok, device 305, last update 11:58:55, usage 0,000kWh, rate 0
[COLOR=Red]dec-29 12:09:34 P1 Update energy database failed, device 307, last update 12:04:05, usage 0,088kWh, rate 0 dec-29 12:09:34 P1 Update energy database failed, device 305, last update 12:04:04, usage 0,000kWh, rate 0 dec-29 12:09:25 P1 Update energy database failed, device 307, last update 12:04:05, usage 0,083kWh, rate 0 dec-29 12:09:25 P1 Update energy database failed, device 305, last update 12:04:04, usage 0,000kWh, rate 0 dec-29 12:09:14 P1 Update energy database failed, device 307, last update 12:04:05, usage 0,080kWh, rate 0 dec-29 12:09:14 P1 Update energy database failed, device 305, last update 12:04:04, usage 0,000kWh, rate 0[/COLOR]
dec-29 12:14:55 P1 ?!4?E?4??6 dec-29 12:14:55 P1 ?0-1??:2?4?.1?.0(003) dec-29 12:14:55 P1 ?0?-1?:96.1.0(4?7??303031?393334?30333034?3436303931??36)? dec-29 12:14:55 P1 0?-1:2??4?.2.1??(161??2?291?2??0000W?)?(004?94?.92?4?*m?3)? dec-29 12:14:55 P1 ?1??-0:32?.32?.0(00000)? dec-29 12:14:55 P1 1?-0:32?.36.0(00000)? dec-29 12:14:55 P1 ??0-0:96.13.1?()?? dec-29 12:14:55 P1 0-0:96.1?3.0()?? dec-29 12:14:55 P1 1??-0:31?.7?.0(003*?A)? dec-29 12:14:55 P1 ?1-0:2??1?.7?.0(00.8?36*?kW?)?? dec-29 12:14:55 P1 ?1?-0:2?2.7?.0(00.000*??k?W?) dec-29 12:14:55 P1 ?1??-0:99.97?.0(1?)?(0-0:96.7.1?9)??(0001?01?000001?W)?(2??1?4?7?48??3647??*s??) dec-29 12:14:54 P1 ?1?-0:2?.8.1?(000000.000*??k?W?h?) dec-29 12:14:54 P1 ??1?-0:2.8??.2(000000.000*?k??W?h?)? dec-29 12:14:54 P1 0-0:96.1?4??.0(0002?)? dec-29 12:14:54 P1 ?1-0:1?.7??.0(00.8?36*?k?W)? dec-29 12:14:54 P1 ??1?-0:2?.7?.0(00.000*k?W??)? dec-29 12:14:54 P1 ?0-0:96.7?.21?(00001??)? dec-29 12:14:54 P1 ?0-0:96.7?.9(00001?) dec-29 12:14:54 P1 ?/?KF??M5KAI?F?A-MET??E?R dec-29 12:14:54 P1 ? dec-29 12:14:54 P1 ??1?-3:0.2?.8?(42?)??
My setup:
Enabled Plug-Ins
2.0.35.0: BLLAN
3.0.0.1: FritzTR064
3.0.0.8: P1
30.0.0.33: RFXCOM
