I've tried for hours to get the IPThermostat plugin to work with my Proliphix NT150h. I've upgraded to 3.0.5 on the thermostat and 3.4.5.0 for the IPThermostat plugin.
I consistently receive the following errors below.
If I run the MIB URLs I get the following responses:
http://192.168.27.9:80/get?OID4.1.13=:
OID4.1.13=691&
http://192.168.27.9:80/get?OID4.1.5=:
OID4.1.5=680&
I know for certain that the username and password are correct despite what the logs seem to indicate.
It appears that the thermostat won't appear under devices in HomeSeer because of these errors so I'm stuck.
Any idea what could be happening?
Much appreciated!
Jan-05 1:50:18 AM IPThermostat ERROR: PollProliphix: Cannot query http://192.168.27.9:80/get?OID4.1.5=: Conversion from string "" to type 'Long' is not valid.
Jan-05 1:50:18 AM IPThermostat ERROR: DoGet --> Communication error: Error getting response stream (ReadDone2): ReceiveFailure, at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) <0x73780720 + 0x00164> in :0 at System.Net.HttpWebRequest.GetResponse () <0x7377a2d0 + 0x00067> in :0 at HSPI_IPTHERMOSTAT.PROLILPHIX.doGET (System.String url, System.String username, System.String password) <0x72af95d8 + 0x00433> in :0
Jan-05 1:50:18 AM IPThermostat ERROR: DoGET --> Unable to communicate with PROLIPHIX. Are you sure the username and password are correct?
Jan-05 1:50:18 AM IPThermostat DEBUG3: Test1
Jan-05 1:50:18 AM IPThermostat DEBUG3: Entering DoGet
Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat Current Temperature = 19.6666666666667
Jan-05 1:50:18 AM IPThermostat DEBUG3: Test3
Jan-05 1:50:18 AM IPThermostat DEBUG3: Test2
Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat userdID = 1234
Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat userdID = admin
Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat Icon =
Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat Type = IP Thermostat
Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat brand = PROLIPHIX
Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat name = Proliphix Thermostat
Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostate ID = 1
Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Network = 1
Jan-05 1:50:18 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix HS_REF = 0
Jan-05 1:50:18 AM IPThermostat DEBUG1: PollProliphix: Entering
Jan-05 1:49:48 AM IPThermostat ERROR: PollProliphix: Cannot query http://192.168.27.9:80/get?OID4.1.13=: Conversion from string "" to type 'Long' is not valid.
Jan-05 1:49:48 AM IPThermostat ERROR: DoGet --> Communication error: Error getting response stream (ReadDone2): ReceiveFailure, at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) <0x73780720 + 0x00164> in :0 at System.Net.HttpWebRequest.GetResponse () <0x7377a2d0 + 0x00067> in :0 at HSPI_IPTHERMOSTAT.PROLILPHIX.doGET (System.String url, System.String username, System.String password) <0x72af95d8 + 0x00433> in :0
Jan-05 1:49:48 AM IPThermostat ERROR: DoGET --> Unable to communicate with PROLIPHIX. Are you sure the username and password are correct?
Jan-05 1:49:48 AM IPThermostat DEBUG3: Test1
Jan-05 1:49:48 AM IPThermostat DEBUG3: Entering DoGet
Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat userdID = 1234
Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat userdID = admin
Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat Icon = Proliphix-NT.jpg
Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat Type = IP Thermostat
Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat brand = PROLIPHIX
Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostat name = Proliphix NT150 Thermostat
Jan-05 1:49:48 AM IPThermostat DEBUG3: Test3
Jan-05 1:49:48 AM IPThermostat DEBUG3: Test2
Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Thermostate ID = 1
Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix Network = 1
Jan-05 1:49:48 AM IPThermostat DEBUG3: Proliphix Thermostat information retreivement -- Proliphix HS_REF = 0
Jan-05 1:49:48 AM IPThermostat DEBUG1: PollProliphix: Entering
OID4.1.13=691&
OID4.1.5=680&
Much appreciated!
