If you have the RFXrec433E or RFXtrx433E use Ext2 firmware. Enable Lighting4 and X10 and the Kerui sensors are decoded as X10 security sensors.
Ext and Ext2 firmware can only be used in the RFXrec433E or RFXtrx433E.
It is not possible to receive the Kerui sensors as X10 security sensors using the RFXrec433 or RFXtrx433 which can only use Type1 or Type2 firmware.
You should be able to receive the Kerui sensors as Lighting4 sensors with Type1 or Type2 in the RFXtrx433 and select only Lighting4.
