Null reference error during startup
    Occasionally I see this error in the Startup Log. The same error also occasionally occurs with the Restart Plugin.
    12/19/2017 3:03:35 PM ~!~Z-Wave~!~Z-Net Z-Wave: .............................. FINISHED ..............................
    12/19/2017 3:03:35 PM ~!~Z-Wave~!~Z-Net Z-Wave: ............................................................ ..........
    12/19/2017 3:03:35 PM ~!~Error~!~Initializing plug-in(2): Insteon Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
    12/19/2017 3:03:35 PM ~!~Plug-In~!~Finished initializing plug-in Insteon
    12/19/2017 3:03:36 PM ~!~HSTouch Server~!~Server started on port 10200
    12/19/2017 3:03:36 PM ~!~Startup~!~HStouch server started, waiting for clients to connect.
    12/19/2017 3:03:39 PM ~!~Z-Wave~!~***************************************************** **************************
    12/19/2017 3:03:39 PM ~!~Z-Wave~!~ STARTUP COMPLETE: All configured interfaces were successfully initialized.
    did you get this resolved?
    Mark
    HS3 Pro 4.2.19.5
      Homeseer says the problem is with the Plugin
      When I asked Homeseer about it, they said the problem was with the plugins. What is the next step?
      The same error occurs with the Restart Plugin. The author added some additional diagnostic displays and they do not show errors in the Restart Plugin.
      The error happened again today. It does not happen every day, only occasionally. I have the server reboot every day at 3:00 PM to reset and clear everything. I experienced reliability issues when I did not have the server reboot periodically.
      Here is an excerpt from the startup log:
      12/29/2017 3:03:51 PM ~!~Z-Wave~!~Z-Net Z-Wave: ............................................................ ..........
      12/29/2017 3:03:51 PM ~!~Plug-In~!~Finished initializing plug-in Restart
      12/29/2017 3:03:51 PM ~!~Info~!~Plugin Insteon has connected. IP:127.0.0.1:1207
      12/29/2017 3:03:53 PM ~!~Z-Wave~!~***************************************************** **************************
      12/29/2017 3:03:53 PM ~!~Z-Wave~!~ STARTUP COMPLETE: All configured interfaces were successfully initialized.
      12/29/2017 3:03:54 PM ~!~Error~!~Initializing plug-in(2): Insteon Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
      12/29/2017 3:03:54 PM ~!~Plug-In~!~Finished initializing plug-in Insteon
      12/29/2017 3:03:54 PM ~!~HSTouch Server~!~Server started on port 10200
      12/29/2017 3:03:54 PM ~!~Startup~!~HStouch server started, waiting for clients to connect.
      12/29/2017 3:03:59 PM ~!~Web Server~!~Local IP address (subnet) is: 10.0.0.32 (255.255.255.0)
      12/29/2017 3:03:59 PM ~!~Web Server~!~UPNP Discovery started
      12/29/2017 3:03:59 PM ~!~Web Server~!~Web Server started on port 80
        can you verify the plugin version you are running, and the version of the insteon.dll file
        please post here
        Mark
        HS3 Pro 4.2.19.5
          plugin version 3.0.6.0 Inteon.dll 1.0.6.0 11/28/2016
            can you disable all your other plugins and restart hs a few times and see if you get the error
            Mark
            HS3 Pro 4.2.19.5
              I disabled CM15A, Restart, and ZWAVE plugins, then restarted 3 times, no errors.
                I could do without the Restart plugin for several days and see if the error occurs again.
                  After your test, Also try enabling other plugins one by one to see which one might be causing the problem for the others
                  Mark
                  HS3 Pro 4.2.19.5
                    I disabled the other three plugins then enabled them one-by-one, restarting several times after each was enabled. No errors. Unfortunately, it is an intermittent error. I hate having them in my programs.
                      Let me know what you find.
                      Mark
                      HS3 Pro 4.2.19.5
                        Things have been running well. I have my computer running Homeseer restart every day. Today it received this error:
                        ANDARD version.
                        3/1/2018 3:06:09 PM ~!~Info~!~Remote plug-in API interface started on port 10400
                        3/1/2018 3:06:09 PM ~!~Startup~!~Checking for available plug-ins
                        3/1/2018 3:06:12 PM ~!~Plug-In~!~Found plug-in: CM15A, version: 3.0.0.8
                        3/1/2018 3:06:13 PM ~!~Plug-In~!~Found plug-in: Insteon, version: 3.0.6.0
                        3/1/2018 3:06:14 PM ~!~Plug-In~!~Found plug-in: Restart, version: 1.0.0.7
                        3/1/2018 3:06:17 PM ~!~Plug-In~!~Found plug-in: Z-Wave, version: 3.0.1.87
                        3/1/2018 3:06:17 PM ~!~Startup~!~Initializing Plug-Ins
                        3/1/2018 3:06:20 PM ~!~Info~!~Plugin Insteon has connected. IP:127.0.0.1:1542
                        3/1/2018 3:06:21 PM ~!~Error~!~Initializing plug-in(2): Insteon Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
                        3/1/2018 3:06:21 PM ~!~Plug-In~!~Finished initializing plug-in Insteon
                        3/1/2018 3:06:21 PM ~!~Info~!~Plugin CM15A has connected. IP:127.0.0.1:1544
                        3/1/2018 3:06:23 PM ~!~Plug-In~!~Finished initializing plug-in CM15A
                        3/1/2018 3:06:24 PM ~!~CM15A~!~Initialization Successful.
                        3/1/2018 3:06:25 PM ~!~Info~!~Plugin Z-Wave has connected. IP:127.0.0.1:1546
                        Current Date/Time: 3/1/2018 10:32:04 PM
                        HomeSeer Version: HS3 Standard Edition 3.0.0.357
                        Operating System: Microsoft Windows 7 Home Premium - Work Station
                        System Uptime: 0 Days 7 Hours 25 Minutes 57 Seconds
                        IP Address: 10.0.0.32
                        Number of Devices: 152
                        Number of Events: 97
                        Available Threads: 200
                        Enabled Plug-Ins
                        3.0.0.8: CM15A
                        3.0.6.0: Insteon
                        1.0.0.7: Restart
                        3.0.1.87: Z-Wave
                          can you try your setup for a while without the Restart plugin
                          Mark
                          HS3 Pro 4.2.19.5
                            I can try it but I found that I have problems with the Homeseer software if I don't reboot often. I'll try for a while and see what happens.
                              doesn't look like you are running the latest hs3 version
                              Mark
                              HS3 Pro 4.2.19.5
