I used Imperihome long time with the custom server port 8072 : http://192.168.178.60:8072/issapi this worked great. Now i have updated HS to version 3.0.0.312 and Imperihome to 3.0.0.19 and used the deafult port 80 : http://192.168.178.60:80/issapi. I did this because i also wanted to use IH remote with : https://connected2.homeseer.com/issapi as described in the manual. Also this works perfect but the only thing i see in the log that there is a lot of trafficlog is generated like :
mrt-04 16:35:24 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:35:19 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:35:16 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:35:14 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:35:12 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:35:07 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:35:05 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:35:02 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:35:00 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:34:57 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:34:55 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:34:53 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:34:50 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:34:48 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:34:46 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:34:43 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:34:41 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:34:39 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
mrt-04 16:34:36 Web Server Web Server authorized login successful from: 192.168.178.10 User: egbert
etc etc (everytime IH refreshes , so every 2 seconds there is a login in Homeseer)
This was only to test for several seconds for 1 tablet, when i use 3 of them there is even more log.
I know i can uncheck the option log remote and local log but then other login is also not logged. Also it was not there with port 8072.
Also tried to set different options for log level in IH plugin but that does not affect.
I want to use the default port 80 so that i can also use remote acces with MYHS to IH and dont have to port forward port 8072 in my router.
Other options?
Egbert
Other options?
Egbert
