  #221
Old March 20th, 2017, 06:37 PM
SteveMSJ SteveMSJ is offline
Seer Master
Quote:
Originally Posted by racerfern View Post
Thanks for an awesome plugin! Interestingly, I used to have an event to monitor the smoke alarm heartbeat but it stopped "seeing" the heartbeat and there was nothing in the log. I could see it on device view, though.
Since I installed the plugin, the heartbeat notification now shows up again in the log. Go figure.
I can probably explain that, if the device is a Zsmoke anyway. The device sends the Heartbeat value but doesn't reset it so It is set but not changed. HS3 only logs device changes so the heartbeats don't show in the log unless a smoke or other event happens in between. It still should trigger an event if you use the correct trigger.
HS also doesn't send callbacks to plugins if the value doesn't change so to be able to monitor the heartbeats the plugin sets the device value to Heartbeat Acknowledged after each Heartbeat so the next heartbeat will be a change in value and it will receive a callback. A side effect of that is that HS will also log the Heartbeat.
Steve
  #222
Old March 20th, 2017, 07:16 PM
racerfern racerfern is offline
Seer Deluxe
Thanks for the explanation, I think. I say that because one day I was seeing heartbeats and my event worked correctly. The next day, no more heartbeats in the log and the event stopped firing.
I would still see the time of the last heartbeat update in the Device Management view, every 67 minutes but that's the only place it was obvious that heartbeats were still ongoing.
  #223
Old March 21st, 2017, 05:40 AM
akurz akurz is offline
Seer
Quote:
Originally Posted by SteveMSJ View Post
I've updated the version attached to message #192. Now 3.0.4.3.
What are the VisionSec motion detectors doing?
Steve
Hard to say... I've disabled discharge warning yesterday and after re-enabling and upgrading to the latest version the sensors show all green. Looks I have to wait til one of my sensors changes battery value. I'll definitely keep you updated.
Cheers,
Alex
  #224
Old March 21st, 2017, 10:40 AM
Seer Master
Quote:
Ok, feedback is welcomed.
Steve
  #225
Old March 22nd, 2017, 11:58 AM
Seer Master
Further information on reported battery discharge rates.
I have an Everspring Siren whose battery has been at 80% for a number of months now. The battery life on the Everspring devices is generally really good. Anyway, it is now occasionally reporting 70% and then back to 80%. The discharge rate therefore keeps jumping up and then going back to zero. The battery level will probably settle at 70% after a few days and then stay like that for another few months.
I think I might default to turning off alerts on high discharge rate.
Perhaps the average discharge rate since batteries were replaced would be a better value to report. This would be less affected by fluctuations although an increase in discharge rate would be less obvious. It would also require saving the starting level (not necessarily 100%) which I don't currently do.
Steve
  #226
Old March 22nd, 2017, 12:23 PM
cheeryfool's Avatar
cheeryfool cheeryfool is offline
Seer Master
Steve
The lock I mentioned also jumped UP just after I posted about it - to 86% then settled back a while later to 84%
cheeryfool
  #227
Old March 22nd, 2017, 12:32 PM
Seer Master
Quote:
Thanks, that explains the high reported discharge rate when it dropped back to 84%.
Steve
  #228
Old March 22nd, 2017, 05:43 PM
ralnet ralnet is offline
Seer Deluxe
Thought I would chime in about this plugin. I have several new devices, "Sensitive Strips" for access notification. See attached image.
This plugin works very well.
  #229
Old March 23rd, 2017, 03:47 PM
Seer Master
I'm glad it's working for you.
Steve
HTML code is Off
Does the z-wave plugin have something against battery status? - Solution! garyd9 HomeSeer Z-Wave Plug-in 69 March 3rd, 2017 01:24 AM
Error Ultra1Wire3 ?Plugin Smart Battery Monitor Not all voice recognition aldo Ultra1Wire HSPI 1 January 6th, 2017 08:56 PM
Is there a way to find out the health my Z-Wave network? Agwan HS3 / HS3PRO Discussion 0 March 25th, 2015 11:18 AM
