This started a few days ago after I installed APC's Powerchute which required .Net Framework 2.0 Service Pack 2. I deleted the APC Powerchute, because I'm using the APCUPSD plugin instead.
Start Up Error:
On Restart:
this plugin, BLCPU, and BLSecurity are all enabled, but you can't click on the plugin name( not blue).
Next to each plugin it says -"
WARNING: Failed getting InterfaceStatus from [PLUGIN NAME] - the interface was not found in the list of active interfaces, the list may need to be refreshed.
If I disable any one of these plugins and re-enable it, ALL of the plugin become clickable(blue).
Should I delete the .Net Framework 2.
On HS3 latest released version.
XP SP3
Thank you for your help.
Tom
Start Up Error:
12/23/2015 12:01:47 AM ~!~Info~!~Plugin BLBackup has connected. IP:127.0.0.1:4581 12/23/2015 12:01:47 AM ~!~Error~!~Initializing plug-in(2): BLBackup Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces() 12/23/2015 12:01:47 AM ~!~Plug-In~!~Finished initializing plug-in BLBackup
XP SP3
Tom
