I'm using X10 Extended Dim with Leviton DHC wall dimmers (HCM06).
When using the HS3 Device List GUI, clicking the "On" button, brings the light up to its last set dim level rather than to a full on state. However, the dim slider on the GUI is set to the full on (100%) position.
The results are the same if the "On" command is sent from an event - sending an "On" command sets the light to the last set dim level. To set the light to full on, I have to set the action to dim to 99%.
Is there a way to make the light go to full on when clicking the "On" button or sending an "On" command from an event?
Mike
Mike
