Just installed Ultra1Wire3 to use with my new OWServer V2 ENET. I have a single DS18B20 connected to the OWserver and it registers fine in the OWServer web page. The OWServer is also automatically found by the plugin. However, my sensor does not show up anywhere in HS, including the plugin interface. I also get this error in the HS Log:
The XML document returned by the OWServer was not valid XML.
In the OWServer webpage, under details I get:
When I go to the Details XML in the OWServer interface, I get this:
So it looks like my OWServer is producing a bad xml file. Is this the issue or is there something else? Any suggestions to fix it?
Firmware Version: 1.44 Devices connected: 1 Poll Count: 379 Loop Time: 1.023 Sec Device Name: OWServer_1Wire_1 Host Name: OWSERVER_1WIRE_1�9w MAC Address: D8:80:39:77:D9:A2 Date / Time: 2017-02-11 20:23:36 Connection status: \ Name DS18B20 Description Programmable resolution thermometer Family 28 ROMId DC031681DEBEFF28 Health 7 Channel 3 RawData 94014B467FFF0C1026FF00000000000000000000000000000000000000000000... PrimaryValue 25.2500 Deg C Temperature 25.2500 UserByte1 75 Write UserByte2 70 Write Resolution 12 PowerSource 255
This page contains the following errors: error on line 17 at column 11: Encoding error Below is a rendering of the page up to the first error. 439 1 1.023 0 0 1 0 0 0 4.85 4.84 4.84 5.07 OWServer_1Wire_1
