Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeTroller-SEL
HomeTroller-SEL Discussions related to the HomeTroller-SEL automation controller
Old May 21st, 2016, 11:36 AM
info@kaeseler.dk info@kaeseler.dk is offline
Seer
How to get root access to HomeTroller?
Hi
I am facing some problems with the RFXcom plugin (due to using a prototype 868 MHz version). Therefore I got a special beta-version of the plugin from Bert and need to load that into my HomeTroller SEL.
However this is where I am too Linux-stupid apparently.
Was told to rename the original HSPI_RFXCOM.EXE into e.g. HSPI_RFXCOM.OLD - tried to do this from the Linux tools menu item in my Hometroller SEL. Nothing happens. I assume this is due to lacking access rights. The file has the following permissions:
-rw-r--r-- 1 root root 658432 Jul 1 2015 HSPI_RFXCOM.exe
tried a CHMOD on the file... That fails too. Probably because only "root"-user has rw-access??
How can I proceed? I have no ideas myself...
Thanks for any help.
Old May 21st, 2016, 11:51 AM
sparkman's Avatar
sparkman sparkman is offline
OverSeer
Take a look at this post: http://board.homeseer.com/showthread.php?t=162297. It should give you the info you need.
HS3Pro 3.0.0.318 on Jetway JBC501F9Q-Q87-B i7 8GB 1874 Devices, 955 Events, 28 Plugins
Z-Wave 3.0.1.131 Z-Net 105 nodes:Leviton Vizia,Kwikset,FortrezZ Valve/Sensors,Everspring Sensors/Modules/Outlets,CT30 Stats,MIMOLites,Aeotec Smart Switches
RFXCom W800,RFXrec433,RFXtrx433|APCUPSD|Pushover|Squeezebox|weatherXML|HS Phone W2C|APCUPSD|UltraLog
UltraGCIR GC-100|UltraNetcam|UltraPioneer|Ultra1Wire|DSC PC1832|BLLED|BLTVGuide|ImperiHome|jon00 Utilities|MySensors
PHLocation|X10 CM11A IOLinc,etc
Old February 7th, 2017, 10:07 PM
ocxoman ocxoman is offline
Seer
No root access on Hometroller SEL
Tried all of the the above and the referenced link with success. I am trying to install the OpenSprinkler plugin and need to move some files to an image folder and the ini file to the config folder and exe to the HomeSeer folder.
I can SSH in using homeseer and the password I created and log in and get the proverbial "permission denied" response when attempting to copy the files.
Any ideas?
have tried homeseer/hsthsths3 (wrong password error)
homeseer/mypw gets in but no luck with permissions
Found I have to use the sudo command before each copy command and then everything worked.
Old February 12th, 2017, 10:57 PM
mikedr mikedr is offline
Seer Master
If memory serves, when I had to roll back a Z-Wave plug-in, I ran into this same issue. What I ended up doing was removing the ssd from the SEL box, and plugging it into my computer so I could copy the appropriate files.
HTML code is Off
Warning! Root Remote Access -- TrollerZee hs@home HomeTroller Zee 1 April 1st, 2015 07:56 PM
HomeTroller Zee remote access dentbla HomeSeer General Discussion Area 2 December 13th, 2013 03:34 PM
Cannot access web control on Hometroller - Solved! michael.h HomeTroller™ 19 October 8th, 2012 11:14 AM
How to access HomeTroller from Mac? bholding1 HomeTroller™ 4 April 12th, 2011 09:14 PM
Remote access stopped working on my HomeTroller 3 Smiley HomeTroller™ 3 February 13th, 2011 01:48 PM
