Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeTroller-SEL
HomeTroller-SEL Discussions related to the HomeTroller-SEL automation controller
Old May 27th, 2017, 10:39 AM
mworsnop mworsnop is offline
Seer Deluxe
VBEN will run and VB do not - Fails
I just moved to a SEL from a Z2.
VBEN will run and VB do not.
I have a simple event that calls a script and it fails. (see the log below)
This happens with all scripts and was originally noticed on one of Jon00 scripts for Alexa.
However compiled scripts do work. The have made the script with one simple writelog and also empty just main and end. But either fails
Originally posted on the HS3 thread but this seems like the proper place to post this
May-27 06:27:02	 	Error	Compiling script /usr/local/HomeSeer/scripts/wx.vb:
May-27 06:27:02	 	Event	Running script in background: /usr/local/HomeSeer/scripts/wx.vb
May-27 06:27:02	 	Event	Event Trigger "Utility test"
HTML code is Off
What is a vben file? ncherry HS3 / HS3PRO Discussion 2 December 21st, 2014 01:17 PM
PH_RFXCharts.vben runtime error Mark42 RFXCOM Plug-In (3P) 0 January 28th, 2014 06:36 PM
PH_RFXCOM2.vben. I Need older version of this scriptfile. WildeFA RFXCOM Plug-In (3P) 1 December 2nd, 2013 08:55 PM
Errors with Jon00AppControl.vben("main","3") mkronmal Jon00's plugins and scripts 11 August 30th, 2008 03:30 AM
CheckEmailPOP_V3_HS2.vben hangs RegForte Jon00's plugins and scripts 5 November 19th, 2007 03:09 PM
