Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > PI-SonosController (3P)
PI-SonosController (3P) Discussion of Sonos Controller Plug-in
  #61
Old December 3rd, 2011, 03:57 AM
dcorsus dcorsus is offline
Originally Posted by Hflorez View Post
Wher can I get 67?
If your install of version .73 failed, I guess version .67 is still installed.
Did you extract the files or click on the .msi file in windows explorer? Make sure you extract the files properly then click on the extracted file, not the file that shows up when you explorer is displaying what is inside the .zip file.
Also make sure you use the setup.exe file to install and that you are logged in with the same (administrator) account as you use to install Homeseer and/or that you used to install the previous plug-in version (which seems to be v.67 in your case).
Hope this helps.
Dirk
  #62
Old December 3rd, 2011, 09:28 AM
mark_anderson_us mark_anderson_us is offline
67 is attached
________________________
Dell Zino HD - HSPRo 2.x
HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
2 x Brultech ECM1240 with UltraECM
USB UIRT
Cooper Aspire Z-Wave Switches
WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
HM ST812-2 Flood Sensor
HSM100 - Motion Detector with Light and Temperature
2GIG Thermostat
BLDSC - Alarm Plug-in
BLUPS
UltraLog (SQL2008)
Jon00 Plugins
Host XR3 BT and Jon00 BT Proximity
Global Cache IP2IR
Foscam FI8918W
  #63
Old December 3rd, 2011, 10:29 AM
Rotech's Avatar
Rotech Rotech is offline
Originally Posted by dcorsus View Post
Changes to v1.0.0.73:
  • Filtered out trackchange/songchange events caused by Sonos Player events: ZPSTR_CONNECTING and ZPSTR_BUFFERING, which can occur a lot when connecting to radiostations
Where do you get the ver 73, in updater? Is this ver still in testing status?
Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
  #64
Old December 3rd, 2011, 12:04 PM
Hey hector, it's at the top of this thread
  #65
Old December 3rd, 2011, 09:11 PM
Hflorez Hflorez is offline
Mark,
Thanks. I downloaded 67 and fixed my current one. Then I was able to install 73. Now everything OK.. BTW Dirk nice plug-in!
  #66
Old December 3rd, 2011, 11:49 PM
Mark,
Great news. Great plug-in, and outstanding support from Dirk. Real pleasure to do business with someone like that. (I'm guessing his revenue barely covers his Starbuck's bill )
Regards
Mark
  #67
Old December 4th, 2011, 07:49 PM
Rotech's Avatar
Dirk, when will this ver. Be the official one?
  #68
Old December 4th, 2011, 09:33 PM
I usually wait a couple of weeks, especially when the changes are big, to see if anything got broken before I update the official version.
Dirk
  #69
Old December 17th, 2011, 02:37 PM
New beta v.74 posted
Changes to v1.0.0.74:
  • Added option in .ini file to change plugin name (either different name or lower case) Note: changing this will mess up all your events/actions and you will have to recreate them all
  • Added support for Slacker radio stations, iHeartRadio, RHapsody channels, they will now be learned radiostations
  • Changed default behavior of "Include Learned RadioStations" from false to true (only effect api calls next/prev radiostation)
  #70
Old December 19th, 2011, 11:05 PM
Rotech's Avatar
Hey Dirk, what are the procedures to install the new ver?
  #71
Old December 19th, 2011, 11:56 PM
You can find it here http://board.homeseer.com/showpost.p...45&postcount=1 , it is at the bottom.
Download it, unpack it. Stop HS. Click on setup, click on the OK button (might have to move the install window). Start HS.
That's it.
Dirk
  #72
Old December 28th, 2011, 02:37 PM
New beta v.75 posted
Changes to v1.0.0.75:
  • I pulled Beta .74. There might be a bug in the event handling, meaning, events such as track change start/stop are not reported. Investigating if only in my copy or slipped into released version.
  • Made update to Art.aspx file. When you change the plugin name to something else then "SonosController", your album art could be missing when you open the web page for any specific player
  • I may finally have solved this pesky "Generic error occurred in GDI+" when retrieving Albumartwork
  • Fixed an issue where a previously discovered player, when not on-line when HS is started, but comes on-line afterwards, won't get initialized properly
  • Optimized the code for Player changes to avoid unnecessary MusicDB updates due to announcements
  • Added a property PlayerIconURL, which you can read if you want to display an icon representing the type of player (S5, ZP90, ZP120..). This is retrieved from the player itself
  #73
Old December 28th, 2011, 02:51 PM
tCC tCC is offline
great, thanks a lot !
  #74
Old December 28th, 2011, 06:45 PM
New beta v.76 posted
Sorry for all the betas, guess I broke more than I bargained for and some folks just ran into so interop issues.
Changes to v1.0.0.76:
  • URGGH, found another issue with changing plugin name. The buttons on the HS Webpage don't work anymore. Moreover, actions are being treated either. Fixed here . Hopefully this is the last fix. As of version .v76 the plugin name will be changing from SONOSCONTROLLER to SonosController by default, in fact for as far is I have tested, there is no need to redo events/actions, but if one happens to be broken, just recreate it. If you are upgrading from beta .74 or .75 and you don't care about the name, do nothing. If you do care and want the name to be in lower case, stop HS, remove this line from the .ini file: "Plugin Name=SONOSCONTROLLER", restart HS and now the plugin name should be in lowercase. If you had it set to anything else than SonosController than leave the entry in the .ini file.
  • There seems to be a compatibility problem using the Interop.ADODB.dll with DooMotion, mcsXap and BLRadar. This version removes the use of the COM object (Interop.adodb.dll) and uses the .net provided adodb
  • Fixed minor issue on toggling repeat/shuffle
  #75
Old December 31st, 2011, 09:51 AM
tCC tCC is offline
don't know if it's new to version 1.0.0.76, but getting things like this in my logging a couple of times a day:
31-12-2011 14:46:26 SonosController ZonePlayer Living Room has been disconnected from the network in myDeviceFinderCallBack_DeviceLost.
31-12-2011 14:46:31 SonosController ZonePlayer Living Room reachable on network. Attempting to reconnect
31-12-2011 14:46:31 SonosController Connect: Connecting to ZonePlayer - Living Room: UDN = uuid:RINCON_000E588908BC01400
31-12-2011 14:46:32 SonosController Callback received for Zone Living Room with device name = uuid:RINCON_000E588908BC01400 and Model = S5
31-12-2011 14:46:33 SonosController AvTransportCallback added for zoneplayer = Living Room
31-12-2011 14:46:33 SonosController RenderingControlCallback added for zoneplayer = Living Room
31-12-2011 14:46:33 SonosController ContentDirectoryControlCallback added for zoneplayer = Living Room
31-12-2011 14:46:33 SonosController ZoneGroupTopology ControlCallback added for zoneplayer = Living Room
31-12-2011 14:46:33 SonosController GroupManagement ControlCallback added for zoneplayer = Living Room
31-12-2011 14:46:33 SonosController AlarmClock ControlCallback added for zoneplayer = Living Room
31-12-2011 14:46:33 SonosController AudioInCallback added for zoneplayer = Living Room
31-12-2011 14:46:33 SonosController DevicePropertiesCallback added for zoneplayer = Living Room
31-12-2011 14:46:33 SonosController Service callbacks established for zoneplayer = Living Room
31-12-2011 14:46:36 SonosController ERROR in myDeviceFinderCallback_DeviceFound for Living Room. Call back w/ wrong Device pointer. Expected = 333645224 <> 334103160
31-12-2011 14:46:40 SonosController Search for ZonePlayer Living Room complete.
31-12-2011 14:46:41 SonosController Connect: Connecting to ZonePlayer - Living Room: UDN = uuid:RINCON_000E588908BC01400
31-12-2011 14:46:41 SonosController Callback received for Zone Living Room with device name = uuid:RINCON_000E588908BC01400 and Model = S5
31-12-2011 14:46:42 SonosController AvTransportCallback added for zoneplayer = Living Room
31-12-2011 14:46:42 SonosController RenderingControlCallback added for zoneplayer = Living Room
31-12-2011 14:46:42 SonosController ContentDirectoryControlCallback added for zoneplayer = Living Room
31-12-2011 14:46:42 SonosController ZoneGroupTopology ControlCallback added for zoneplayer = Living Room
31-12-2011 14:46:42 SonosController GroupManagement ControlCallback added for zoneplayer = Living Room
31-12-2011 14:46:42 SonosController AlarmClock ControlCallback added for zoneplayer = Living Room
31-12-2011 14:46:42 SonosController AudioInCallback added for zoneplayer = Living Room
31-12-2011 14:46:42 SonosController DevicePropertiesCallback added for zoneplayer = Living Room
31-12-2011 14:46:42 SonosController Service callbacks established for zoneplayer = Living Room
31-12-2011 14:46:50 SonosController Search for ZonePlayer Living Room complete.
  #76
Old December 31st, 2011, 10:36 AM
tCC tCC is offline
and another one
31-12-2011 15:31:40 SonosController ZonePlayer Living Room has been disconnected from the network in myDeviceFinderCallBack_DeviceLost.
31-12-2011 15:31:43 SonosController ZonePlayer Living Room reachable on network. Attempting to reconnect
31-12-2011 15:31:43 SonosController Connect: Connecting to ZonePlayer - Living Room: UDN = uuid:RINCON_000E588908BC01400
31-12-2011 15:31:44 SonosController Callback received for Zone Living Room with device name = uuid:RINCON_000E588908BC01400 and Model = S5
31-12-2011 15:31:45 SonosController AvTransportCallback added for zoneplayer = Living Room
31-12-2011 15:31:45 SonosController RenderingControlCallback added for zoneplayer = Living Room
31-12-2011 15:31:45 SonosController ContentDirectoryControlCallback added for zoneplayer = Living Room
31-12-2011 15:31:45 SonosController ZoneGroupTopology ControlCallback added for zoneplayer = Living Room
31-12-2011 15:31:45 SonosController GroupManagement ControlCallback added for zoneplayer = Living Room
31-12-2011 15:31:45 SonosController AlarmClock ControlCallback added for zoneplayer = Living Room
31-12-2011 15:31:45 SonosController AudioInCallback added for zoneplayer = Living Room
31-12-2011 15:31:45 SonosController DevicePropertiesCallback added for zoneplayer = Living Room
31-12-2011 15:31:45 SonosController Service callbacks established for zoneplayer = Living Room
31-12-2011 15:31:50 SonosController ERROR in myDeviceFinderCallback_DeviceFound for Living Room. Call back w/ wrong Device pointer. Expected = 201920664 <> 333645464
31-12-2011 15:31:53 SonosController Search for ZonePlayer Living Room complete.
31-12-2011 15:31:53 SonosController Connect: Connecting to ZonePlayer - Living Room: UDN = uuid:RINCON_000E588908BC01400
31-12-2011 15:31:54 SonosController Callback received for Zone Living Room with device name = uuid:RINCON_000E588908BC01400 and Model = S5
31-12-2011 15:31:55 SonosController AvTransportCallback added for zoneplayer = Living Room
31-12-2011 15:31:55 SonosController RenderingControlCallback added for zoneplayer = Living Room
31-12-2011 15:31:55 SonosController ContentDirectoryControlCallback added for zoneplayer = Living Room
31-12-2011 15:31:55 SonosController ZoneGroupTopology ControlCallback added for zoneplayer = Living Room
31-12-2011 15:31:55 SonosController GroupManagement ControlCallback added for zoneplayer = Living Room
31-12-2011 15:31:55 SonosController AlarmClock ControlCallback added for zoneplayer = Living Room
31-12-2011 15:31:55 SonosController AudioInCallback added for zoneplayer = Living Room
31-12-2011 15:31:55 SonosController DevicePropertiesCallback added for zoneplayer = Living Room
31-12-2011 15:31:55 SonosController Service callbacks established for zoneplayer = Living Room
31-12-2011 15:31:55 SonosController myDeviceFinderCallback_DeviceFound found AudioInputName = Line-In
31-12-2011 15:32:02 SonosController Search for ZonePlayer Living Room complete.
  #77
Old December 31st, 2011, 11:42 AM
Lost connection
tCC,
you get this when the plugin (or better Microsoft's UPNP subsystem) loses contact with the player. You'll get this typically when your player boots (example SW upgrade), network problems/congestion or network reconfigurations. I see it a lot on my players, when I boot up/power down a player, especially wireless ones; Sonos does maintain its own wireless "network" and if that get reconfigured because a player was added or removed, the UPnP subsystem seems to get disconnected as well. I also get this when my PC was put to sleep/awoken or perhaps your Ethernet port that got powered down.
The error you see is harmless but shouldn't be there. The UPnP subsystem is a bit finicky, most of the times the object can just rediscover the player but sometimes, the object itself is dead and I need to recreated it. What I haven't figured out is some race condition where the events from the old object and the new object intersect, really a benign error.
Before I forget, nothing in the last 20 or so beta was changed in this area ..... at least not intentionally
Dirk
  #78
Old December 31st, 2011, 02:15 PM
tCC tCC is offline
okay, thanks for the reply.
I've restarted HomeSeer to see if that helps, the Sonos player itself never boots
  #79
Old January 1st, 2012, 08:38 AM
tCC tCC is offline
it's indeed the (wireless) netwerk connection itself, sigh, thnx
  #80
Old January 1st, 2012, 07:25 PM
New beta v.77 posted
Changes to v1.0.0.77:
  • My music screens are not updated when my iPad HSTouch client reconnects. Pretty sure it is a problem with either HS server or the iPad client but I've added sending some track-change events which seems to do the trick
