Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > PI-SonosController (3P)
PI-SonosController (3P) Discussion of Sonos Controller Plug-in
  #101
Old February 5th, 2012, 02:38 AM
dcorsus dcorsus is offline
Originally Posted by Rotech View Post
Yes that's correct..... How about the periodic funtions?
The loss of handles is correlated to the number of players, the more players you have the faster you will see it. If you write down the number of handles now and check again in 24 hours, unless they jumped up by a many hundreds, all is OK. If your Homeseer runs fine for many weeks, I'm sure there is no problem. I know I don't have it on Win7, there are a lot of XP users out there and I haven't heard from them, so far one user on Vista32 who loses about 30~50 handles every 5 minutes, hard to miss.
Dirk
  #102
Old February 5th, 2012, 02:10 PM
jbbtex's Avatar
jbbtex jbbtex is offline
Originally Posted by dcorsus View Post
Changes to v1.0.0.81:
  • When you use the basic music browser template in HS Touch, when you deploy and navigate to "Playlist" you will now see your playlist. Change in behavior is that clicking a track will now start playing from that track and continue on. This should be in line with how the Windows Media and iTunes plugin work
  • Added a button to manually trigger a rediscovery of zone players. There is now an option in the config settings, to turn the automatic discovery off
  • Added a few options in the .ini file so you can customize the AnnouncementTitle, Album and Author
  • Made some minor optimizations around trigger events during announcements.
  • Thought I had solved this but maybe now I have finally solved this pesky "Generic error occurred in GDI+" when retrieving Albumartwork
Thanks for the .ini options.
  #103
Old February 5th, 2012, 09:04 PM
Rotech's Avatar
Rotech Rotech is offline
These new changes of the INI are they accessible thru the setup page or you need to access the INI directly?
Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
  #104
Old February 5th, 2012, 09:43 PM
nope only via direct editing of the .ini file. Too many customizations for single users makes everything very complicated.
Cheers,
Dirk
  #105
Old February 15th, 2012, 04:14 AM
New beta v.83 posted
Changes to v1.0.0.83:
  • Added an option to set the maximum time of an announcement
  • Tuned announcement processing a little
  #106
Old March 3rd, 2012, 05:22 PM
New beta v.84 posted
Changes to v1.0.0.84:
  • If you change floor/room/name information, it will be overwritten each time HS is restarted. As of v.84, it won't
  #107
Old March 10th, 2012, 09:20 PM
New beta v.85 posted
Changes to v1.0.0.85:
  • If you have paired players, and you use the "slave" player as source&destination for an announcement, you'll not get the paired players to continue to play after the announcement is over (on condition they were playing when the announcement started of course :-))
  • If you have a number of players linked, and the group is in "paused" state, if now one of the players is part of an announcement, it will trigger the group to start playing
  #108
Old March 15th, 2012, 01:02 AM
New beta v.86 posted
Changes to v1.0.0.86:
  • Added some fake triggers so HST would update status of Shuffle, Repeat and Mute in real-time
  #109
Old March 16th, 2012, 02:41 AM
New beta v.87 posted
Changes to v1.0.0.87:
  • Fixed some race condition forcing HST to update the status of Shuffle, Repeat and Mute in real-time
  • Fixed an issue where config change triggers were not sent when alarms were changed, which I probably broke in v.75
  #110
Old March 25th, 2012, 11:57 AM
New beta v.88 posted
Changes to v1.0.0.88:
  • The new Sonos SW3.7 appear to have changed the behavior of connecting players to another player's audio-input. After connecting to that input, the player is in a pause state instead of (previous default) play state. As such TTS announcements which are routed via an audio-input port are not working anymore.
  #111
Old April 8th, 2012, 06:15 PM
New beta v.89 posted
Changes to v1.0.0.89:
  • Fixed an issue when devices are marked up as "Hidden", after a restart of HS they show up again.
  #112
Old April 22nd, 2012, 07:33 PM
New beta v.90 posted
Changes to v1.0.0.90:
  • Found a few more corner cases for grouped players and HST screens. Play/Pause from a linked zone (non group master) would not work, stop would. Secondly, if you have a linked group when HS starts up, depending on the sequence of how the zones are discovered, the plugin may not have the correct linked state and as a consequence, albumart, player state etc for linked players wouldn't be updated in HST screens.
  #113
Old July 29th, 2012, 06:11 PM
pabbott@cpak.com pabbott@cpak.com is offline
Seer Plus
Problem with plugin hangs
I've installed the latest beta .90 version hoping it would help with my icesue. I'm running the latest version of the Sonos software on everything. Everything seems ok when you boot homeseer for a couple of clicks using the homeseer sonos devices. If you click line-input it locks up access and doesn't link the line input immediately. If you click play, stop or change a couple of stations after about 2 or three times it hangs up access to the sonos players and tabs. It also hangs up access to other external modules like proliphix, and ultramon etc. The only way to get it back is to reboot homeseer.
Here's the log on startup of homeseer. I power off sonos players that I'm not using since I have so many. The ones that I keep on all the time are the main computer and homeseer zones. They are all wired into the network into the same switch that also has homeseer plugged into it.
Any ideas would be appreciated....Do I need to start over is my config scrambled and causing problems?
Philip
pabbott@cpak.com
7/29/2012 6:07:30 PM Plug-In Initializing Plug-in: SONOSCONTROLLER
7/29/2012 6:07:30 PM SonosController InitIO Called
7/29/2012 6:07:30 PM SonosController Info not found in .ini file Devtype = Sonos Transport devicecode=16
7/29/2012 6:07:30 PM SonosController Info not found in .ini file Devtype = Sonos Transport devicecode=32
7/29/2012 6:07:39 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Master Control with index 2
7/29/2012 6:07:39 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Master Bedroom with index 4
7/29/2012 6:07:39 PM SonosController DirectConnect called for Zone Main Computer with device name = uuid:RINCON_000E5830551C01400 and Model = ZP120
7/29/2012 6:07:39 PM SonosController AvTransportCallback added for zoneplayer = Main Computer
7/29/2012 6:07:39 PM SonosController RenderingControlCallback added for zoneplayer = Main Computer
7/29/2012 6:07:39 PM SonosController ZoneGroupTopology ControlCallback added for zoneplayer = Main Computer
7/29/2012 6:07:39 PM SonosController GroupManagement ControlCallback added for zoneplayer = Main Computer
7/29/2012 6:07:39 PM SonosController AlarmClock ControlCallback added for zoneplayer = Main Computer
7/29/2012 6:07:39 PM SonosController AudioInCallback added for zoneplayer = Main Computer
7/29/2012 6:07:39 PM SonosController DevicePropertiesCallback added for zoneplayer = Main Computer
7/29/2012 6:07:39 PM SonosController Service callbacks established for zoneplayer = Main Computer
7/29/2012 6:07:39 PM SonosController DirectConnect for zoneplayer = Main Computer found AudioInputName = Philip's Computer
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Main Computer with index 6
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Master Closet with index 8
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Master Area with index 10
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Master Bathroom with index 12
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Kitchen with index 14
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = with index 16
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Upstairs Data with index 18
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Basement with index 20
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Pergola with index 22
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Main Control with index 24
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Back Patio with index 26
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = BC with index 28
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = JAP with index 30
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = with index 32
7/29/2012 6:07:40 PM SonosController DirectConnect called for Zone HomeSeer with device name = uuid:RINCON_000E582353F601400 and Model = ZP90
7/29/2012 6:07:40 PM SonosController AvTransportCallback added for zoneplayer = HomeSeer
7/29/2012 6:07:40 PM SonosController RenderingControlCallback added for zoneplayer = HomeSeer
7/29/2012 6:07:40 PM SonosController ZoneGroupTopology ControlCallback added for zoneplayer = HomeSeer
7/29/2012 6:07:40 PM SonosController GroupManagement ControlCallback added for zoneplayer = HomeSeer
7/29/2012 6:07:40 PM SonosController AlarmClock ControlCallback added for zoneplayer = HomeSeer
7/29/2012 6:07:40 PM SonosController AudioInCallback added for zoneplayer = HomeSeer
7/29/2012 6:07:40 PM SonosController DevicePropertiesCallback added for zoneplayer = HomeSeer
7/29/2012 6:07:40 PM SonosController Service callbacks established for zoneplayer = HomeSeer
7/29/2012 6:07:40 PM SonosController DirectConnect for zoneplayer = HomeSeer found AudioInputName = HomeSeer
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = HomeSeer with index 34
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Piano Room with index 35
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Basement Outside with index 37
7/29/2012 6:07:40 PM SonosController CreateSonosControllers: Created instance of ZonePlayerController for Zoneplayer = Guest Bedroom with index 38
7/29/2012 6:07:40 PM SonosController Initialized
7/29/2012 6:07:40 PM Plug-In Finished initializing plug-in SONOSCONTROLLER
  #114
Old July 29th, 2012, 06:26 PM
Philip,
something is indeed not kosher, see these lines:
If you have a lot of events and touchscreens I wouldn't recommend you delete all and start over. There are always backup files of the .ini file and I would focus on devices 16 and 32. Other option is that you do a screenshot of all your Sonos devices and email me the .ini file, I can try to manually fix it, a full startup log with debug flag on and all devices powered up will do as well.
Dirk
  #115
Old July 31st, 2012, 11:39 PM
New beta v1.0.0.92 posted
Changes to v1.0.0.92:
  • Increased time to wait for saving of queue and let Sonos sync info between players in order to avoid ending up with wrong queue info post announcement
  • Supporting new SUB player
  • Some changes to chasing a ghost where an announcement get repeated over and over
  • Added a retry in case the player has "lost" the play command to start the announcement. Seems worse with SW R3.8
  • Fix for announcements, where a source zone is already linked when the announcement starts
  #116
Old August 1st, 2012, 08:39 AM
mark_anderson_us mark_anderson_us is offline
92 not working
Hi Dirk
Just installed 92 and nothig works. Getting a lot of these in log:
8/1/2012 7:37:43 AM - SONOSCONTROLLER - Error getting ZoneName. Error: Object variable or With block variable not set.
Dell Zino HD - HSPRo 2.x
HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
2 x Brultech ECM1240 with UltraECM
USB UIRT
Cooper Aspire Z-Wave Switches
WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
HM ST812-2 Flood Sensor
HSM100 - Motion Detector with Light and Temperature
2GIG Thermostat
BLDSC - Alarm Plug-in
BLUPS
UltraLog (SQL2008)
Jon00 Plugins
Host XR3 BT and Jon00 BT Proximity
Global Cache IP2IR
Foscam FI8918W
  #117
Old August 1st, 2012, 10:48 AM
Originally Posted by mark_anderson_us View Post
Hi Dirk
Sorry to read that Mark. Can you turn the Sonos PI debug flag on, restart HS and email me that log. Do you have SUB players?
Dirk
  #118
Old August 1st, 2012, 11:03 AM
Will do when I get home.
Don't have Sub (already got 5 sub woofers in house :-)). Have 3 100/120's, 2 90/90 and one S5
  #119
Old August 2nd, 2012, 07:50 AM
Wouldn't you know it Dirk?
Worked fine when I restarted again
  #120
Old August 8th, 2012, 07:47 PM
sweden's Avatar
sweden sweden is offline
Sorry but i don't find how to download the latest beta(92). Have you moved the download link from the first post?
