Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > PI-SonosController (3P)
PI-SonosController (3P) Discussion of Sonos Controller Plug-in
  #161
Old September 2nd, 2013, 05:57 PM
jbbtex's Avatar
jbbtex jbbtex is offline
Thanks, Dirk. Works perfectly.
Brady
  #162
Old November 17th, 2013, 12:05 AM
dcorsus dcorsus is offline
New beta v1.0.0.116 posted
Changes to v1.0.0.116
  • Added support for S1 and S3 players
  • With new Sonos SW 4.2, no more need to save queues so announcement linking can be a bit faster. For fastest result, edit the HSPI_SonosController.ini file and change AnnouncementWaitforPlayTime=0. If you experience some announcement play problems change it to 1 or 2 or as high as needed
  #163
Old May 21st, 2014, 12:42 AM
michaeldecharon michaeldecharon is offline
Seer Plus
SonosController Plug-In Beta testing Forum
Can we expect a new version? Due to the software-update from sonos the alarm trigger doesn't work any more.
  #164
Old May 21st, 2014, 01:47 AM
Are you referring to the HS3 variant or the HS2? If the prior, this post is in the wrong place and you would be right, I broke that. If HS2, please confirm, which PI version and check the start-up log for errors.
Dirk
  #165
Old June 29th, 2014, 10:10 PM
End of life announcement for Sonos HS2 PI !!
Find the latest version attached to the first post on this Thread. The protection was removed so this version doesn't need a license.
This version is most likely the last HS2 version, no more support is planned going forward.
Changes to v1.0.0.117
  • Re-arranged service discovery a little, hopefully works around some more recent Sonos introduced issues (alarm services)
  • Made minor change to pulling Albums from the MusicDB
  • This version IS FREE. This is introducing the End Of Life of this product. No more changes are planned in the future for this HS2 variant!
  #166
Old July 24th, 2014, 02:49 AM
Seer Plus
Dirk
Dirk,
I'm referring to the HS2 variant and i'm running v1.0.0.117, with no errors on start-up or on event triggering. It wouldn't pick up the alarmtrigger and therefor not start a event.
  #167
Old July 24th, 2014, 12:16 PM
Dirk,
The alarm handling broke due to a change Sonos made in their SW. However, the change is not the problem, the problem is in the Microsoft UPNP DLL I use.
On a different forum (a Sonos forum http://forums.sonos.com/showthread.p...074#post230074 ), another developer stumbled into the same issue and on that forum a MSFT employee committed to send this problem internally to the right people. Haven't heard anything ( 2 months ago) and not holding my breath to be brutally honest. If MSFT doesn't fix this, I'm afraid the alarm functions will be toast.
In the HS3 version, I've been working on designing out the UPNP.DLL from MSFT but so far that change has not been incorporated into the HS3 Sonos PI, so also there the alarm function is not working. The HS2 version is EndOfLife (http://board.homeseer.com/showpost.p...&postcount=165) hence there are no plans to spend the huge amount of effort it would require to port that function.
Dirk
  #168
Old February 7th, 2016, 02:36 PM
U5tabil's Avatar
U5tabil U5tabil is offline
Stupid question. But when i try installing it says "homeseer is not installed on system." What do i need to do?
Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
  #169
Old February 7th, 2016, 02:51 PM
You are posting on the HS2 forum here so I suspect you are trying to install the HS2 version of the PI on a HS3 install, right?
Install the PI from the updater in HS3.
DIrk
  #170
Old February 7th, 2016, 05:19 PM
U5tabil's Avatar
DIrk
Yeah I had that version installed, just thought there was a different one here
