Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion > HomeSeer DSC Plug-in
HomeSeer DSC Plug-in HomeSeer DSC plug-in for Power Series security panels
  #61
Old February 28th, 2014, 07:38 AM
theplant theplant is offline
Same for me. Being able to tell the difference between armed away and armed stay being the most important.
Looking forward to it.
Sent from my Nexus 4 using Tapatalk
  #62
Old February 28th, 2014, 09:41 AM
NicolaiL's Avatar
NicolaiL NicolaiL is offline
Super Seer
Actually, I have one more request!
Please make sure the new PI is an upgrade of the old one and will be able to utilise existing devices created by the current version. As I'm already in production and have integrated DSC devices with other devices and events I would absolutely hate to have to re-do that work.
  #63
Old February 28th, 2014, 11:33 AM
Sgt. Shultz's Avatar
Sgt. Shultz Sgt. Shultz is offline
Which devices did you want to keep?
I might be able to keep the device itself as it was linked to the plugin already, but I'm wondering just how much conversion I can do to it without rendering it unusable to you.
If I know which ones to target, I can make my code more detailed for converting those devices.
Wade
I know nothing...., nothing!!!
  #64
Old February 28th, 2014, 11:44 AM
I've also expanded the LED status response so that individual ones can be used.
The LED status code has 9 sub codes:
Ready
Armed
Memory
Bypass
Trouble
Program
Fire
Backlight
AC
Each can have one of three values:
Off
On
Flashing
(e.g. the "LEDStatus - Bypass" response will show if the panel is in bypass mode or not. This could be used as an individual device, or as a response code in the events area.)
I found this to be useful if a status request is done, as the panel will send a "Zone Restored" response when the zone is in bypass mode. (IT100)
  #65
Old February 28th, 2014, 12:49 PM
NicolaiL's Avatar
Super Seer
For me, just the zone devices (1-64) themselves. I'm OK if you need to change the value/status pairs as long as I can keep the basic devices.
  #66
Old February 28th, 2014, 03:21 PM
Dafunktyfunk's Avatar
Dafunktyfunk Dafunktyfunk is offline
Wow, this is great!!
Did you write this from scratch or did you buy the HS code?
Will there be a charge for this plug?
Will it support BOTH HS2 AND HS3 or just one or the other?
Nice work!
Transitioning to HS3Pro .298 - WinXPEmbedded
  #67
Old February 28th, 2014, 05:13 PM
Well, technically, Homeseer bought the code from me...
But seriously, it's an upgrade to the current HS3 plugin, so it will still be free.
As noted above, it's for HS3. HS2 plugins have been sunsetted for all additional development.
  #68
Old March 12th, 2014, 03:52 PM
Code has been added to convert the existing devices to the new plugin devices.
Testing is being done.
I expect the new plugin out in the next two weeks.
  #69
Old March 12th, 2014, 04:43 PM
NicolaiL's Avatar
Super Seer
That sounds really good!
I have one more request I failed to mention earlier ...
... would you be able to speed up processing so it takes less time for a zone activation to be reflected in HS3? I ask because I trigger based on zone activations to turn light on and I want the minimum possible delay.
Cheers
Nicolai
  #70
Old March 24th, 2014, 10:58 AM
OSchubert OSchubert is offline
Hi sirs,
my technician left me alone with a half made alarm system. I try since a few days to make a cable between my DSC 4401 (for a maxsys alarm panel) and my home troller with the DSC plugin. I need the pinout from the RJ11 (DSC 4401) to the DB9 (home troller). I tried a lot of combinations, but it doesn't really work. I found this:
DB9 PINs:
1: (D)CD in Data Carrier Detect
2: RX in Receive Data
3: TX out Transmit Data
4: DTR out Data Terminal Ready
5: GND Signal Ground
6: DSR in Data Set Ready
7: RTS out Request to Send
8: CTS in Clear to Send
9: Ring in Ring Indicator
RJ11 PINs:
1: DSR
2: Frame Gnd
3: TX
4: RX
5: Signal Gnd
6: DTR
The only cable which makes no troubles but still don't work is this:
RJ11 -> DB9 Pins:
1 -> 2
2 -> 3
3 -> 4
4 -> 5
5 -> 6
6 -> 7
This pinout makes no sense to me.
I think this one is the right one, but it doesn't works:
1 -> 6
2 -> 5
3 -> 2
4 -> 3
5 -> 7
6 -> 4
I have no idea whats going wrong. Please, can somebody help me?
  #71
Old March 27th, 2014, 11:44 AM
rwiese1 rwiese1 is offline
Any update on the release date?
  #72
Old April 9th, 2014, 05:01 PM
The beta release of the plugin is available at the bottom of the updater list.
  #73
Old April 9th, 2014, 05:21 PM
OShubert, I'm betting what you found was the developer guide.
What you're looking for is the PC4401 application guide.
You'll find the schematic for converting to a db9 on page 3.
  #74
Old April 9th, 2014, 05:49 PM
That could be - on page 3 of what, of the application guide? I don't have a application guide - can you help me?
  #75
Old April 9th, 2014, 08:49 PM
sparkman's Avatar
sparkman sparkman is offline
http://www.intek.co.nz/content/docum...t%20Manual.pdf
Cheers
Al
  #76
Old April 9th, 2014, 09:27 PM
Thank you "sparkman". I think that on page 2 it is shown which function is on which PIN of the RJ11 connector:
1: DSR
2: Frame Ground
3: TX
4: RX
5: Signal Ground
6: DTR
and on page 3 the functions of the DB9 connector:
1: CD
2: Signal IN (I think RX)
3: Signal OUT (I think TX)
4: DTR
5: GND (I think Signal Ground)
6: DSR
7: RTS
8: CTS
9: Ring Indicator
It looks like everything is as supposed, but it doesn't work. My best idea is:
RJ11 PIN -> DB9 PIN:
1 -> 6
2 -> 5
3 -> 2
4 -> 3
5 -> 7
6 -> 4
But it doesn't work. Maybe the programmer of the plugin knows which (RJ11) function is needed on which PIN of the DB9?
I have no more ideas - maybe my DSC4401 is broken (not only my english)?
  #77
Old April 10th, 2014, 06:46 AM
Sorry, I never had to make a cable for the 4401.
  #78
Old April 10th, 2014, 07:00 AM
I still thank you for your reply, Sgt. Shulz.
  #79
Old April 10th, 2014, 01:30 PM
Hello,
Will you be able to release an update to the HS2 version? I am very desperate for that...
HS abandoned it with MAJOR security holes and flaws...
  #80
Old April 10th, 2014, 04:44 PM
All development for HS2 was sunsetted last summer.
