Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > PI-SonosController (3P)
PI-SonosController (3P) Discussion of Sonos Controller Plug-in
  #41
Old October 19th, 2013, 04:22 AM
NicolaiL's Avatar
NicolaiL NicolaiL is offline
Super Seer
Originally Posted by dcorsus View Post
Found issue, fix will be part of next beta. Thanks for catching this.
Changed implementation a little: currently count will continue to go up when player is off-line, changed that to only count missing pings, when the PI assumed the player to be on-line and before set to off-line.
Dirk
Sounds great! I like the new logic for the count.
Re my issues above I eventually found a very interesting issue with the Spanning Tree protocol. Once I fixed that my general ping times to all of my Sonos zons (wired or wireless) dropped right down and seem more stable. Thanks for pointing out the network issue.
Re the original log entries. Network issue or not, the one below here, is this a "valid" log entry or a piece of failing code?
15/10/2013 14:19:06 ~!~Sonos Error~!~ERROR in GetTimeNow for zoneplayer = Den with UPNP Error = -2147012194: Unknown error type. OrgError=-2147012894. Error = Exception from HRESULT: 0x80072EE2
Cheers
Nicolai
  #42
Old October 19th, 2013, 10:24 AM
dcorsus dcorsus is offline
Obviously, you shouldn't have this error. Do you still have now that you fixed the network? If so, how frequent? Which kind of player is this? Do you see the same error on your HS2 version? Can you turn the PI's debug flag on and capture everything that happens just before and right after this error.
Dirk
  #43
Old October 22nd, 2013, 03:21 PM
NicolaiL's Avatar
Super Seer
Dirk
Pings are now acceptable, but yes, still getting errors. HS2 also gives errors. They looks like this:
PHP Code:
22/10/2013 20:12:47     SonosController     ERROR in myDeviceFinderCallback_DeviceFound for KianiCall back wwrong Device pointerExpected 654197448 530099880
22
/10/2013 20:12:47     SonosController     ERROR in myDeviceFinderCallback_DeviceFound for JasmineCall back wwrong Device pointerExpected 532005080 653623672
On HS3 I get the following when starting:
PHP Code:
22/10/2013 20:16:15           Sonos     GetPagePlugin for SonosControl called with pageName SonosConfig and user = default and userRights and queryString =
22/10/2013 20:16:15           Sonos     hspi.GetPagePlugin called for instance = and pageName SonosConfig and user = default and userRights and queryString =
22/10/2013 20:15:24           Sonos     GetPagePlugin for SonosControl called with pageName SonosConfig and user = default and userRights and queryString =
22/10/2013 20:15:24           Sonos     hspi.GetPagePlugin called for instance = and pageName SonosConfig and user = default and userRights and queryString =
22/10/2013 20:15:17           Web Server     Web Server authorized local login successful from192.168.1.51 User: default
22/10/2013 20:15:14           Sonos     InitializeSonosDevicesDone Initializing Sonos Devices
22
/10/2013 20:15:14           Sonos     [Log Entry Contains Chars Converted to Hex in Brackets{}]WriteSonosNamesToIniFile wrote new string Office{3B}:{3B}S5:|:Bedroom/Ensuite{3B}:{3B}ZP90:|:Jasmine{3B}:{3B}S3:|:Kiani{3B}:{3B}S3:|:Den{3B}:{3B}S5:|:Bathroom{3B}:{3B}ZP120:|:Kitchen/Lounge{3B}:{3B}ZP90
22
/10/2013 20:15:14           Sonos     CreateSonosControllersCreated instance of ZonePlayerController for Zoneplayer Kitchen/Lounge with index 2
22
/10/2013 20:15:14           Sonos     GetPagePlugin for Zoneplayer Kitchen/Lounge set ZoneUDN RINCON_000E58A06C2801400
22
/10/2013 20:15:14           Sonos     CreateWebLink called with ZoneUDN RINCON_000E58A06C2801400 and PageName PlayerControl000E58A06C2801400
22
/10/2013 20:15:14           Sonos     SetAdministrativeState called for device Kitchen/Lounge and Active True
22
/10/2013 20:15:14           Sonos     SetHSDeviceRefPlayer called for zone Kitchen/Lounge with HS Ref 8732
22
/10/2013 20:15:13           Sonos     InitIO Called for Instance RINCON_000E58A06C2801400
22
/10/2013 20:15:13           Info     Plug-in SONOSCONTROLLER with instance RINCON_000E58A06C2801400 has connected successfully
22
/10/2013 20:15:13           Info     Remote application or plugin has connected127.0.0.1:53033
22
/10/2013 20:15:13           Info     Remote application or plugin has connected127.0.0.1:53032
22
/10/2013 20:15:13           Sonos     AddInstance called with InstanceName RINCON_000E58A06C2801400
22
/10/2013 20:15:13           Sonos     CreateSonosControllersCreated instance of ZonePlayerController for Zoneplayer Bathroom with index 7
22
/10/2013 20:15:13           Sonos     GetPagePlugin for Zoneplayer Bathroom set ZoneUDN RINCON_000E583BF06601400
22
/10/2013 20:15:13           Sonos     CreateWebLink called with ZoneUDN RINCON_000E583BF06601400 and PageName PlayerControl000E583BF06601400
22
/10/2013 20:15:13           Sonos     SetAdministrativeState called for device Bathroom and Active True
22
/10/2013 20:15:13           Sonos     SetHSDeviceRefPlayer called for zone Bathroom with HS Ref 7969
22
/10/2013 20:15:12           Sonos     InitIO Called for Instance RINCON_000E583BF06601400
22
/10/2013 20:15:12           Info     Plug-in SONOSCONTROLLER with instance RINCON_000E583BF06601400 has connected successfully
22
/10/2013 20:15:12           Info     Remote application or plugin has connected127.0.0.1:53031
22
/10/2013 20:15:12           Info     Remote application or plugin has connected127.0.0.1:53030
22
/10/2013 20:15:12           Sonos     AddInstance called with InstanceName RINCON_000E583BF06601400
22
/10/2013 20:15:11           Sonos     CreateSonosControllersCreated instance of ZonePlayerController for Zoneplayer Den with index 1
22
/10/2013 20:15:11           Sonos     GetPagePlugin for Zoneplayer Den set ZoneUDN RINCON_000E5888D39601400
22
/10/2013 20:15:11           Sonos     CreateWebLink called with ZoneUDN RINCON_000E5888D39601400 and PageName PlayerControl000E5888D39601400
22
/10/2013 20:15:11           Sonos     [Log Entry Contains Chars Converted to Hex in Brackets{}]HS updated in UpdateHSHS Code 7841 Info = {3C}table{3E}{3C}tr{3E}{3C}td{3E}{3C}img src=/Sonos/images/noart.png height="150" width="150" {3E}{3C}/td{3E}{3C}td{3E}{3C}p{3E}Stop{3C}/p{3E}{3C}p{3E}Lastfm{3C}/p{3E}{3C}p{3E}pop Tag Radio{3C}/p{3E}{3C}p{3E}{3C}/p{3E}{3C}p{3E}{3C}/p{3E}{3C}/td{3E}{3C}/tr{3E}{3C}/table{3E}
22/10/2013 20:15:11           Sonos     ArtworkURL Set for ZoneName DenAlbum http://192.168.1.26:80/Sonos/images/noart.png
22/10/2013 20:15:11           Sonos     ArtworkURL is setting HS Status for ZoneName Den with Value http://192.168.1.26:80/Sonos/images/noart.png and HSRef = 1484
22/10/2013 20:15:11           Sonos     Album Set for ZoneName DenAlbum =
22/10/2013 20:15:11           Sonos     Artist Set for ZoneName DenArtist =
22/10/2013 20:15:11           Sonos     Track Set for ZoneName DenTrack pop Tag Radio
22
/10/2013 20:15:11           Sonos     PlayChangeNotifyCallback called for Zone Den with ChangeType PlayStatusChanged and Changevalue stopped
22
/10/2013 20:15:11           Sonos     PlayChangeNotifyCallback called for Zone Den with ChangeType SongChanged and Changevalue stopped
22
/10/2013 20:15:11           Sonos     CurrentPlayerState Set for ZoneName DenValue stopped
22
/10/2013 20:15:11           Sonos     Den TrackInfo(Source) = Lastfm
22
/10/2013 20:15:11           Sonos     UpdateRadioStationsInfo updated RadioStation LastFM pop Tag Radio for Zone Den
22
/10/2013 20:15:11           Sonos     [Log Entry Contains Chars Converted to Hex in Brackets{}]CreateRadioStationDatabase called with C:\Program Files (x86)\HomeSeer HS3\html\Sonos\MusicDb\SonosRadioStationsDB.mdb and Provider=Microsoft.Jet.OLEDB.4.0{3B}Data Source=C:\Program Files (x86)\HomeSeer HS3\html\Sonos\MusicDb\SonosRadioStationsDB.mdb for zoneplayer Den
22
/10/2013 20:15:11           Sonos     [Log Entry Contains Chars Converted to Hex in Brackets{}]UpdateRadioStationsInfo called for Zone Den with CurrentURI lastfm://globaltags/pop and CurrentURIMetaData = {3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{3E}{3C}item id="RP:SA_RINCON11_LegolasHaifisch:0:LFM%3aTAG%3apop" parentID="RECENT" restricted="true"{3E}{3C}dc:title{3E}pop Tag Radio{3C}/dc:title{3E}{3C}upnp:class{3E}object.item.audioItem.audioBroadcast{3C}/upnp:class{3E}{3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{3E}SA_RINCON11_LegolasHaifisch{3C}/desc{3E}{3C}/item{3E}{3C}/DIDL-Lite{3E}
22/10/2013 20:15:11           Sonos     Den TrackInfo (title) = pop Tag Radio
22
/10/2013 20:15:11           Sonos     Den TrackInfo (MediaInfo/Title) = pop Tag Radio
22
/10/2013 20:15:11           Sonos     [Log Entry Contains Chars Converted to Hex in Brackets{}]Den TrackInfo (CurrentURI) = lastfm://globaltags/pop and TrackInfo (CurrentURIMetaData) = {3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{3E}{3C}item id="RP:SA_RINCON11_LegolasHaifisch:0:LFM%3aTAG%3apop" parentID="RECENT" restricted="true"{3E}{3C}dc:title{3E}pop Tag Radio{3C}/dc:title{3E}{3C}upnp:class{3E}object.item.audioItem.audioBroadcast{3C}/upnp:class{3E}{3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{3E}SA_RINCON11_LegolasHaifisch{3C}/desc{3E}{3C}/item{3E}{3C}/DIDL-Lite{3E}
22/10/2013 20:15:11           Sonos     GetcurrentTrackInfo called for zoneplayer Den
22
/10/2013 20:15:11           Sonos     MPAdd added IPAddress 192.168.1.34 and ClientName RINCON_000E5888D39601400 to its ping list. IPAddress list count 3
22
/10/2013 20:15:11           Sonos     CheckDeviceIsOnLine pinged IPAddress 192.168.1.34 successfully
22
/10/2013 20:15:11           Sonos     IPAddress for zoneplayer Den192.168.1.34
22
/10/2013 20:15:11           Sonos     PlayChangeNotifyCallback called for Zone Den with ChangeType DeviceStatusChanged and Changevalue AudioInTrue
22
/10/2013 20:15:11           Sonos     DirectConnect for zoneplayer Den found AudioInputName Audio Component
22
/10/2013 20:15:11           Sonos     GetLoudnessState called for ZonePlayer Den with values Channel=Master and DeviceStatus =Online
22
/10/2013 20:15:11           Sonos     SetMuteState is setting HS Status Mute for ZoneName Den with Value False and HSRef 3506
22
/10/2013 20:15:11           Sonos     GetMuteState calledDeviceStatus =Online
22
/10/2013 20:15:11           Sonos     UpdateBalance is setting HS Status for ZoneName Den with Value and HSRef 6781
22
/10/2013 20:15:11           Sonos     GetVolumeLevel called for ZonePlayer Den with values Channel=RF and DeviceStatus =Online
22
/10/2013 20:15:11           Sonos     GetVolumeLevel called for ZonePlayer Den with values Channel=LF and DeviceStatus =Online
22
/10/2013 20:15:11           Sonos     SetVolume is setting HS Status Volume for ZoneName Den with Value 74 and HSRef 7463
22
/10/2013 20:15:11           Sonos     GetVolumeLevel called for ZonePlayer Den with values Channel=Master and DeviceStatus =Online
22
/10/2013 20:15:11           Sonos     DevicePropertiesCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     AudioInCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     ConnectionManagerCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     SystemProperties ControlCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     MusicServices ControlCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     AlarmClock ControlCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     GroupManagement ControlCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     ZoneGroupTopology ControlCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     ContentDirectory ControlCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     RenderingControlCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     AvTransportCallback added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     ConnectionManager service added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     ContentDirectory service added for zoneplayer Den
22
/10/2013 20:15:11           Sonos Error     Error in MediaRenderer.Services for zoneplayer Den with UPNP Error = -2147219524Unknown error typeOrgError=-2147220224. Error Exception from HRESULT0x80040500
22
/10/2013 20:15:11           Sonos     AVTransport service added for zoneplayer Den
22
22
/10/2013 20:15:11           Sonos     RenderingControl service added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     Additional services found for Den with ID urn:tencent-com:serviceId:QPlay
22
/10/2013 20:15:11           Sonos     GroupManagement service added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     ZoneGroupTopology service added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     SystemProperties service added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     DeviceProperties service added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     AudioIN service added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     MusicServices service added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     AlarmClock service added for zoneplayer Den
22
/10/2013 20:15:11           Sonos     Den MediaRenderer Friendly Name Den Sonos PLAY:5 Media Renderer
22
/10/2013 20:15:11           Sonos     Den MediaServer Friendly Name uuid:RINCON_000E5888D39601400_MS
22
/10/2013 20:15:10           Sonos     DirectConnect for zoneplayer Den added Image = /images/Sonos/PlayerIcon_S5.png for HSRef 7841
22
/10/2013 20:15:10           Sonos     DirectConnect for zoneplayer Den found Icon already stored at /images/Sonos/PlayerIcon_S5.png
22
/10/2013 20:15:10           Sonos     DirectConnect for zoneplayer Den checking for file C:\Program Files (x86)\HomeSeer HS3\html/images/Sonos/PlayerIcon_S5.png
22
/10/2013 20:15:10           Sonos     DirectConnect for zoneplayer Den found IconURL http://192.168.1.34:1400/img/icon-S5.png
22/10/2013 20:15:10           Sonos     DirectConnect called for Zone Den with device name uuid:RINCON_000E5888D39601400 and Model S5
22
/10/2013 20:15:10           Sonos     SetAdministrativeState called for device Den and Active True
22
/10/2013 20:15:10           Sonos     SetHSDeviceRefPlayer called for zone Den with HS Ref 7841
22
/10/2013 20:15:09           Sonos     InitIO Called for Instance RINCON_000E5888D39601400
22
/10/2013 20:15:09           Info     Plug-in SONOSCONTROLLER with instance RINCON_000E5888D39601400 has connected successfully
22
/10/2013 20:15:09           Info     Remote application or plugin has connected127.0.0.1:52990
22
/10/2013 20:15:09           Info     Remote application or plugin has connected127.0.0.1:52989
22
/10/2013 20:15:09           Sonos     AddInstance called with InstanceName RINCON_000E5888D39601400
22
/10/2013 20:15:09           Sonos     CreateSonosControllersCreated instance of ZonePlayerController for Zoneplayer Kiani with index 6
22
/10/2013 20:15:09           Sonos     GetPagePlugin for Zoneplayer Kiani set ZoneUDN RINCON_000E587A2B0801400
22
/10/2013 20:15:09           Sonos     CreateWebLink called with ZoneUDN RINCON_000E587A2B0801400 and PageName PlayerControl000E587A2B0801400
22
/10/2013 20:15:09           Sonos     [Log Entry Contains Chars Converted to Hex in Brackets{}]HS updated in UpdateHSHS Code 5817 Info = {3C}table{3E}{3C}tr{3E}{3C}td{3E}{3C}img src=/Sonos/images/noart.png height="150" width="150" {3E}{3C}/td{3E}{3C}td{3E}{3C}p{3E}Stop{3C}/p{3E}{3C}p{3E}Unknown{3C}/p{3E}{3C}p{3E}{3C}/p{3E}{3C}p{3E}{3C}/p{3E}{3C}p{3E}{3C}/p{3E}{3C}/td{3E}{3C}/tr{3E}{3C}/table{3E}
22/10/2013 20:15:09           Sonos     ArtworkURL Set for ZoneName KianiAlbum http://192.168.1.26:80/Sonos/images/noart.png
22/10/2013 20:15:09           Sonos     ArtworkURL is setting HS Status for ZoneName Kiani with Value http://192.168.1.26:80/Sonos/images/noart.png and HSRef = 4350
22/10/2013 20:15:09           Sonos     Album Set for ZoneName KianiAlbum =
22/10/2013 20:15:09           Sonos     Artist Set for ZoneName KianiArtist =
22/10/2013 20:15:09           Sonos     Track Set for ZoneName KianiTrack =
22/10/2013 20:15:09           Sonos     PlayChangeNotifyCallback called for Zone Kiani with ChangeType PlayStatusChanged and Changevalue stopped
22
/10/2013 20:15:09           Sonos     PlayChangeNotifyCallback called for Zone Kiani with ChangeType SongChanged and Changevalue stopped
22
/10/2013 20:15:09           Sonos     CurrentPlayerState Set for ZoneName KianiValue stopped
22
/10/2013 20:15:09           Sonos     Kiani TrackInfo(Source) = Unknown
22
/10/2013 20:15:09           Sonos     Kiani TrackInfo (CurrentURI) = and TrackInfo (CurrentURIMetaData) =
22/10/2013 20:15:09           Sonos     GetcurrentTrackInfo called for zoneplayer Kiani
22
/10/2013 20:15:09           Sonos     MPAdd added IPAddress 192.168.1.37 and ClientName RINCON_000E587A2B0801400 to its ping list. IPAddress list count 2
22
/10/2013 20:15:08           Sonos     CheckDeviceIsOnLine pinged IPAddress 192.168.1.37 successfully
22
/10/2013 20:15:08           Sonos     IPAddress for zoneplayer Kiani192.168.1.37
22
/10/2013 20:15:08           Sonos     GetLoudnessState called for ZonePlayer Kiani with values Channel=Master and DeviceStatus =Online
22
/10/2013 20:15:08           Sonos     SetMuteState is setting HS Status Mute for ZoneName Kiani with Value False and HSRef 1941
22
/10/2013 20:15:08           Sonos     GetMuteState calledDeviceStatus =Online
22
/10/2013 20:15:08           Sonos     UpdateBalance is setting HS Status for ZoneName Kiani with Value and HSRef 7895
22
/10/2013 20:15:08           Sonos     GetVolumeLevel called for ZonePlayer Kiani with values Channel=RF and DeviceStatus =Online
22
/10/2013 20:15:08           Sonos     GetVolumeLevel called for ZonePlayer Kiani with values Channel=LF and DeviceStatus =Online
22
/10/2013 20:15:08           Sonos     SetVolume is setting HS Status Volume for ZoneName Kiani with Value 44 and HSRef 5054
22
/10/2013 20:15:08           Sonos     GetVolumeLevel called for ZonePlayer Kiani with values Channel=Master and DeviceStatus =Online
22
/10/2013 20:15:08           Sonos     DevicePropertiesCallback added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     ConnectionManagerCallback added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     SystemProperties ControlCallback added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     MusicServices ControlCallback added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     AlarmClock ControlCallback added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     GroupManagement ControlCallback added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     ZoneGroupTopology ControlCallback added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     ContentDirectory ControlCallback added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     RenderingControlCallback added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     AvTransportCallback added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     ConnectionManager service added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     ContentDirectory service added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos Error     Error in MediaRenderer.Services for zoneplayer Kiani with UPNP Error = -2147219524Unknown error typeOrgError=-2147220224. Error Exception from HRESULT0x80040500
22
/10/2013 20:15:08           Sonos     AVTransport service added for zoneplayer Kiani
22
22
/10/2013 20:15:08           Sonos     RenderingControl service added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     Additional services found for Kiani with ID urn:tencent-com:serviceId:QPlay
22
/10/2013 20:15:08           Sonos     GroupManagement service added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     ZoneGroupTopology service added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     SystemProperties service added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     DeviceProperties service added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     MusicServices service added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     AlarmClock service added for zoneplayer Kiani
22
/10/2013 20:15:08           Sonos     Kiani MediaRenderer Friendly Name Kiani Sonos PLAY:3 Media Renderer
22
/10/2013 20:15:08           Sonos     Kiani MediaServer Friendly Name uuid:RINCON_000E587A2B0801400_MS
22
/10/2013 20:15:08           Sonos     DirectConnect for zoneplayer Kiani added Image = /images/Sonos/PlayerIcon_S3.png for HSRef 5817
22
/10/2013 20:15:08           Sonos     DirectConnect for zoneplayer Kiani found Icon already stored at /images/Sonos/PlayerIcon_S3.png
22
/10/2013 20:15:08           Sonos     DirectConnect for zoneplayer Kiani checking for file C:\Program Files (x86)\HomeSeer HS3\html/images/Sonos/PlayerIcon_S3.png
22
/10/2013 20:15:08           Sonos     DirectConnect for zoneplayer Kiani found IconURL http://192.168.1.37:1400/img/icon-S3.png
22/10/2013 20:15:08           Sonos     DirectConnect called for Zone Kiani with device name uuid:RINCON_000E587A2B0801400 and Model S3
22
/10/2013 20:15:08           Sonos     SetAdministrativeState called for device Kiani and Active True
22
/10/2013 20:15:08           Sonos     SetHSDeviceRefPlayer called for zone Kiani with HS Ref 5817
22
/10/2013 20:15:07           Sonos     InitIO Called for Instance RINCON_000E587A2B0801400
22
/10/2013 20:15:07           Info     Plug-in SONOSCONTROLLER with instance RINCON_000E587A2B0801400 has connected successfully
22
/10/2013 20:15:07           Info     Remote application or plugin has connected127.0.0.1:52953
22
/10/2013 20:15:07           Info     Remote application or plugin has connected127.0.0.1:52952
22
/10/2013 20:15:07           Sonos     AddInstance called with InstanceName RINCON_000E587A2B0801400
22
/10/2013 20:15:07           Sonos     CreateSonosControllersCreated instance of ZonePlayerController for Zoneplayer Jasmine with index 5
22
/10/2013 20:15:06           Sonos     GetPagePlugin for Zoneplayer Jasmine set ZoneUDN RINCON_000E58713C2601400
22
/10/2013 20:15:06           Sonos     CreateWebLink called with ZoneUDN RINCON_000E58713C2601400 and PageName PlayerControl000E58713C2601400
22
/10/2013 20:15:06           Sonos     [Log Entry Contains Chars Converted to Hex in Brackets{}]HS updated in UpdateHSHS Code 5640 Info = {3C}table{3E}{3C}tr{3E}{3C}td{3E}{3C}img src=/Sonos/Artwork/Cover5_1.jpg height="150" width="150" {3E}{3C}/td{3E}{3C}td{3E}{3C}p{3E}Stop{3C}/p{3E}{3C}p{3E}Tracks{3C}/p{3E}{3C}p{3E}Counting Stars{3C}/p{3E}{3C}p{3E}OneRepublic{3C}/p{3E}{3C}p{3E}Native{3C}/p{3E}{3C}/td{3E}{3C}/tr{3E}{3C}/table{3E}
22/10/2013 20:15:06           Sonos     ArtworkURL Set for ZoneName JasmineAlbum http://192.168.1.26:80/Sonos/Artwork/Cover5_1.jpg
22/10/2013 20:15:06           Sonos     ArtworkURL is setting HS Status for ZoneName Jasmine with Value http://192.168.1.26:80/Sonos/Artwork/Cover5_1.jpg and HSRef = 4683
22/10/2013 20:15:06           Sonos     Album Set for ZoneName JasmineAlbum Native
22
/10/2013 20:15:06           Sonos     Artist Set for ZoneName JasmineArtist OneRepublic
22
/10/2013 20:15:06           Sonos     Track Set for ZoneName JasmineTrack Counting Stars
22
/10/2013 20:15:06           Sonos     PlayChangeNotifyCallback called for Zone Jasmine with ChangeType PlayStatusChanged and Changevalue stopped
22
/10/2013 20:15:06           Sonos     PlayChangeNotifyCallback called for Zone Jasmine with ChangeType SongChanged and Changevalue stopped
22
/10/2013 20:15:06           Sonos     CurrentPlayerState Set for ZoneName JasmineValue stopped
22
/10/2013 20:15:06           Sonos     Jasmine TrackInfo PositionInfo (% played) = 0
22
/10/2013 20:15:06           Sonos     Jasmine TrackInfo PositionInfo (Queue Position) = 1
22
/10/2013 20:15:06           Sonos     SetTrackLength set Pair for ZoneName Jasmine Old Max Range 257 New Max Range 257
22
/10/2013 20:15:06           Sonos     SetTrackLength is setting HS Status Max Position TrackPosition for ZoneName Jasmine and HSRef 1735
22
/10/2013 20:15:06           Sonos     SetTrackLength is setting HS Device TrackLength for ZoneName Jasmine with Value 257 and HSRef 8082
22
/10/2013 20:15:06           Sonos     Jasmine TrackInfo PositionInfo (Track Duration) = 0:04:17
22
/10/2013 20:15:06           Sonos     Jasmine TrackInfo PositionInfo (Track Position Seconds) = 0
22
/10/2013 20:15:06           Sonos     Jasmine TrackInfo PositionInfo (Track Position) = 0:00:00
22
/10/2013 20:15:06           Sonos     GetAlbumArtPath returned for Zone Jasmine with AlbumURI http://192.168.1.33:1400/getaa?r=1&u=npsdy:Tra.98547055.mp3 and returned path= /Sonos/Artwork/Cover5_1.jpg
22/10/2013 20:15:06           Sonos     GetAlbumArtPath called for zone Jasmine with AlbumURI http://192.168.1.33:1400/getaa?r=1&u=npsdy:Tra.98547055.mp3 and NextTrack = False
22/10/2013 20:15:06           Sonos     Jasmine TrackInfo PositionInfo (albumArtURI) = http://192.168.1.33:1400/getaa?r=1&u=npsdy:Tra.98547055.mp3
22/10/2013 20:15:06           Sonos     Jasmine TrackInfo PositionInfo (title) = Counting Stars
22
/10/2013 20:15:06           Sonos     Jasmine TrackInfo PositionInfo (album) = Native
22
/10/2013 20:15:06           Sonos     Jasmine TrackInfo PositionInfo (creator) = OneRepublic
22
/10/2013 20:15:06           Sonos     Jasmine TrackInfo PositionInfo (Streamcontent/Title) =
22/10/2013 20:15:06           Sonos     [Log Entry Contains Chars Converted to Hex in Brackets{}]GetcurrentTrackInfo called GetPositionInfo for zoneplayer Jasmine and MetaData {3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{3E}{3C}item id="-1" parentID="-1" restricted="true"{3E}{3C}res protocolInfo="real.com-rhapsody-direct:*:audio/mp3:*" duration="0:04:17"{3E}npsdy:Tra.98547055.mp3{3C}/res{3E}{3C}r:streamContent{3E}{3C}/r:streamContent{3E}{3C}upnp:albumArtURI{3E}/getaa?r=1&u=npsdy%3aTra.98547055.mp3{3C}/upnp:albumArtURI{3E}{3C}dc:title{3E}Counting Stars{3C}/dc:title{3E}{3C}upnp:class{3E}object.item.audioItem.musicTrack{3C}/upnp:class{3E}{3C}dc:creator{3E}OneRepublic{3C}/dc:creator{3E}{3C}upnp:album{3E}Native{3C}/upnp:album{3E}{3C}/item{3E}{3C}/DIDL-Lite{3E}
22/10/2013 20:15:06           Sonos     Jasmine TrackInfo(Source) = Tracks
22
/10/2013 20:15:06           Sonos     Jasmine TrackInfo (CurrentURI) = x-rincon-queue:RINCON_000E58713C2601400#0
22/10/2013 20:15:06           Sonos     Jasmine TrackInfo (CurrentURI) = x-rincon-queue:RINCON_000E58713C2601400#0 and TrackInfo (CurrentURIMetaData) =
22/10/2013 20:15:06           Sonos     GetcurrentTrackInfo called for zoneplayer Jasmine
22
/10/2013 20:15:06           Sonos     MPAdd added IPAddress 192.168.1.33 and ClientName RINCON_000E58713C2601400 to its ping list. IPAddress list count 1
22
/10/2013 20:15:06           Sonos     CheckDeviceIsOnLine pinged IPAddress 192.168.1.33 successfully
22
/10/2013 20:15:06           Sonos     IPAddress for zoneplayer Jasmine192.168.1.33
22
/10/2013 20:15:06           Sonos     GetLoudnessState called for ZonePlayer Jasmine with values Channel=Master and DeviceStatus =Online
22
/10/2013 20:15:06           Sonos     SetMuteState is setting HS Status Mute for ZoneName Jasmine with Value False and HSRef 6545
22
/10/2013 20:15:05           Sonos     GetMuteState calledDeviceStatus =Online
22
/10/2013 20:15:05           Sonos     UpdateBalance is setting HS Status for ZoneName Jasmine with Value and HSRef 9912
22
/10/2013 20:15:05           Sonos     GetVolumeLevel called for ZonePlayer Jasmine with values Channel=RF and DeviceStatus =Online
22
/10/2013 20:15:05           Sonos     GetVolumeLevel called for ZonePlayer Jasmine with values Channel=LF and DeviceStatus =Online
22
/10/2013 20:15:05           Sonos     SetVolume is setting HS Status Volume for ZoneName Jasmine with Value and HSRef 930
22
/10/2013 20:15:05           Sonos     GetVolumeLevel called for ZonePlayer Jasmine with values Channel=Master and DeviceStatus =Online
22
/10/2013 20:15:05           Sonos     DevicePropertiesCallback added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     ConnectionManagerCallback added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     SystemProperties ControlCallback added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     MusicServices ControlCallback added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     AlarmClock ControlCallback added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     GroupManagement ControlCallback added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     ZoneGroupTopology ControlCallback added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     ContentDirectory ControlCallback added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     RenderingControlCallback added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     AvTransportCallback added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     ConnectionManager service added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     ContentDirectory service added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos Error     Error in MediaRenderer.Services for zoneplayer Jasmine with UPNP Error = -2147219524Unknown error typeOrgError=-2147220224. Error Exception from HRESULT0x80040500
22
/10/2013 20:15:05           Sonos     AVTransport service added for zoneplayer Jasmine
22
22
/10/2013 20:15:05           Sonos     RenderingControl service added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     Additional services found for Jasmine with ID urn:tencent-com:serviceId:QPlay
22
/10/2013 20:15:05           Sonos     GroupManagement service added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     ZoneGroupTopology service added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     SystemProperties service added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     DeviceProperties service added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     MusicServices service added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     AlarmClock service added for zoneplayer Jasmine
22
/10/2013 20:15:05           Sonos     Jasmine MediaRenderer Friendly Name Jasmine Sonos PLAY:3 Media Renderer
22
/10/2013 20:15:05           Sonos     Jasmine MediaServer Friendly Name uuid:RINCON_000E58713C2601400_MS
22
/10/2013 20:15:05           Sonos     DirectConnect for zoneplayer Jasmine added Image = /images/Sonos/PlayerIcon_S3.png for HSRef 5640
22
/10/2013 20:15:05           Sonos     DirectConnect for zoneplayer Jasmine found Icon already stored at /images/Sonos/PlayerIcon_S3.png
22
/10/2013 20:15:05           Sonos     DirectConnect for zoneplayer Jasmine checking for file C:\Program Files (x86)\HomeSeer HS3\html/images/Sonos/PlayerIcon_S3.png
22
/10/2013 20:15:05           Sonos     DirectConnect for zoneplayer Jasmine found IconURL http://192.168.1.33:1400/img/icon-S3.png
22/10/2013 20:15:05           Sonos     DirectConnect called for Zone Jasmine with device name uuid:RINCON_000E58713C2601400 and Model S3
22
/10/2013 20:15:05           Sonos     SetAdministrativeState called for device Jasmine and Active True
22
/10/2013 20:15:05           Sonos     SetHSDeviceRefPlayer called for zone Jasmine with HS Ref 5640
22
/10/2013 20:15:04           Sonos     InitIO Called for Instance RINCON_000E58713C2601400
22
/10/2013 20:15:04           Info     Plug-in SONOSCONTROLLER with instance RINCON_000E58713C2601400 has connected successfully
22
/10/2013 20:15:04           Info     Remote application or plugin has connected127.0.0.1:52913
22
/10/2013 20:15:04           Info     Remote application or plugin has connected127.0.0.1:52912
22
/10/2013 20:15:04           Sonos     AddInstance called with InstanceName RINCON_000E58713C2601400
22
/10/2013 20:15:04           Sonos     CreateSonosControllersCreated instance of ZonePlayerController for Zoneplayer Bedroom/Ensuite with index 4
22
/10/2013 20:15:04           Sonos     GetPagePlugin for Zoneplayer Bedroom/Ensuite set ZoneUDN RINCON_000E58A2947E01400
22
/10/2013 20:15:04           Sonos     CreateWebLink called with ZoneUDN RINCON_000E58A2947E01400 and PageName PlayerControl000E58A2947E01400
22
/10/2013 20:15:04           Sonos     SetAdministrativeState called for device Bedroom/Ensuite and Active True
22
/10/2013 20:15:04           Sonos     SetHSDeviceRefPlayer called for zone Bedroom/Ensuite with HS Ref 2564
22
/10/2013 20:15:03           Sonos     InitIO Called for Instance RINCON_000E58A2947E01400
22
/10/2013 20:15:03           Info     Plug-in SONOSCONTROLLER with instance RINCON_000E58A2947E01400 has connected successfully
22
/10/2013 20:15:03           Info     Remote application or plugin has connected127.0.0.1:52911
22
/10/2013 20:15:03           Info     Remote application or plugin has connected127.0.0.1:52910
22
/10/2013 20:15:03           Sonos     AddInstance called with InstanceName RINCON_000E58A2947E01400
22
/10/2013 20:15:03           Sonos     CreateSonosControllersCreated instance of ZonePlayerController for Zoneplayer Office with index 3
22
/10/2013 20:15:03           Sonos     GetPagePlugin for Zoneplayer Office set ZoneUDN RINCON_000E58551BA801400
22
/10/2013 20:15:03           Sonos     CreateWebLink called with ZoneUDN RINCON_000E58551BA801400 and PageName PlayerControl000E58551BA801400
22
/10/2013 20:15:03           Sonos     SetAdministrativeState called for device Office and Active True
22
/10/2013 20:15:03           Sonos     SetHSDeviceRefPlayer called for zone Office with HS Ref 2225
22
/10/2013 20:15:02           Sonos     InitIO Called for Instance RINCON_000E58551BA801400
22
/10/2013 20:15:02           Info     Plug-in SONOSCONTROLLER with instance RINCON_000E58551BA801400 has connected successfully
22
/10/2013 20:15:02           Info     Remote application or plugin has connected127.0.0.1:52901
22
/10/2013 20:15:02           Info     Remote application or plugin has connected127.0.0.1:52900
22
/10/2013 20:15:02           Sonos     AddInstance called with InstanceName RINCON_000E58551BA801400
22
/10/2013 20:15:02           Sonos     CreateSonosControllersZonePlayer in HS DB not found on-lineZoneHSRef 8732. ZoneUDN RINCON_000E58A06C2801400
22
/10/2013 20:15:02           Sonos     CreateSonosControllersZonePlayer in HS DB not found on-lineZoneHSRef 7969. ZoneUDN RINCON_000E583BF06601400
22
/10/2013 20:15:02           Sonos     CreateSonosControllersZonePlayer in HS DB not found on-lineZoneHSRef 2564. ZoneUDN RINCON_000E58A2947E01400
22
/10/2013 20:15:02           Sonos     CreateSonosControllersZonePlayer in HS DB not found on-lineZoneHSRef 2225. ZoneUDN RINCON_000E58551BA801400
22
/10/2013 20:15:02           Sonos     CreateSonosControllersfound 7 Device Codes
22
/10/2013 20:15:02           Sonos     SetDeviceStringConnected called
22
/10/2013 20:15:02           Sonos     BuildHSSonosDevicesFound Zone Name for TransportZonename Kiani
22
/10/2013 20:15:02           Sonos     BuildHSSonosDeviceslooking for Kiani in ZoneInfo and Refresh False
22
/10/2013 20:15:02           Sonos     BuildHSSonosDevicesFound Zone Name for TransportZonename Jasmine
22
/10/2013 20:15:02           Sonos     BuildHSSonosDeviceslooking for Jasmine in ZoneInfo and Refresh False
22
/10/2013 20:15:02           Sonos     BuildHSSonosDevicesFound Zone Name for TransportZonename Den
22
/10/2013 20:15:02           Sonos     BuildHSSonosDeviceslooking for Den in ZoneInfo and Refresh False
22
/10/2013 20:15:02           Sonos     FindZonePlayers Discovery succeeded3 ZonePlayer(sfound.
22/10/2013 20:15:02           Sonos     FindZonePlayers for zoneplayer Kiani found IconURL http://192.168.1.37:1400/img/icon-S3.png
22/10/2013 20:15:02           Sonos     FindZonePlayers found Zone Name Kiani and Stored in ZoneInfo at Index 2 with UDN uuid:RINCON_000E587A2B0801400 Friendly Name 192.168.1.37 Sonos PLAY:and Icon living
22
/10/2013 20:15:02           Sonos     FindZonePlayers for zoneplayer Jasmine found IconURL http://192.168.1.33:1400/img/icon-S3.png
22/10/2013 20:15:02           Sonos     FindZonePlayers found Zone Name Jasmine and Stored in ZoneInfo at Index 1 with UDN uuid:RINCON_000E58713C2601400 Friendly Name 192.168.1.33 Sonos PLAY:and Icon masterbedroom
22
/10/2013 20:15:02           Sonos     FindZonePlayers for zoneplayer Den found IconURL http://192.168.1.34:1400/img/icon-S5.png
22/10/2013 20:15:02           Sonos     FindZonePlayers found Zone Name Den and Stored in ZoneInfo at Index 0 with UDN uuid:RINCON_000E5888D39601400 Friendly Name 192.168.1.34 Sonos PLAY:and Icon den
22
22/10/2013 20:15:01           Warning     A database 'save' was called less than 5 minutes after the system was started this is being ignored or re-queued to promote database integrity.
22/10/2013 20:14:59           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'1' Key being added'1'
22/10/2013 20:14:59           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'0' Key being added'0'
22/10/2013 20:14:59           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-1' Key being added'-1'
22/10/2013 20:14:59           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-2' Key being added'-2'
22/10/2013 20:14:59           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-3' Key being added'-3'
22/10/2013 20:14:57           Startup     Start up complete.
22/10/2013 20:14:57           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'1' Key being added'1'
22/10/2013 20:14:57           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'0' Key being added'0'
22/10/2013 20:14:57           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-1' Key being added'-1'
22/10/2013 20:14:57           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-2' Key being added'-2'
22/10/2013 20:14:57           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-3' Key being added'-3'
22/10/2013 20:14:57           TTS     Speak: ():Welcome to Home-Seer
22
/10/2013 20:14:57           Sonos     GetIniSection called with section NewTTSSpeakDevice and # Result = -1
22/10/2013 20:14:57           Sonos     SpeakIn called for Device 100Text Welcome to Home-SeerWait=TrueHost =
22/10/2013 20:14:57           Startup     Scripting is OK and is now running Startup.vb
22
/10/2013 20:14:57           Startup     Running the startup script Startup.vb
22
/10/2013 20:14:57           HSTouch Server     Server started on port 10200
22
/10/2013 20:14:56           Startup     Starting DDNS service...
22/10/2013 20:14:56           Startup     Updater services starting...
22/10/2013 20:14:56           Database     Opening Energy (Mode=Read Onlydatabase C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
22
/10/2013 20:14:56           Startup     Starting Event Scheduler...
22/10/2013 20:14:56           Startup     Starting the HS3 Sentry EXE
22
/10/2013 20:14:56           Speech     Listening for remote speaker connections on port 10401
22
/10/2013 20:14:56           Startup     Initializing Speaker Client Interface
22/10/2013 20:14:56           Startup     Start automation engine...
22/10/2013 20:14:55           Web Server     SSL Web Server started on port 443
22
/10/2013 20:14:55           Startup     Creating ASP.NET application host...
22/10/2013 20:14:55           Web Server     Web Server started on port 80
22
/10/2013 20:14:55           Web Server     UPNP Discovery started
22
/10/2013 20:14:55           Web Server     Local IP address (subnetis192.168.1.26 (255.255.255.0)
22/10/2013 20:14:55           Plug-In     Finished initializing plug-in Current Cost
22
/10/2013 20:14:55           Current Cost     Updating ALL projected values
22
/10/2013 20:14:55           Current Cost     Opening COM port at 57600 for newer Envi units
22
/10/2013 20:14:55           Current Cost     Current Cost Startup Complete.
22/10/2013 20:14:55           Current Cost     Initializing Current Cost on COM port COM1
22
/10/2013 20:14:54           Info     Plug-in Current Cost has connected successfully
22
/10/2013 20:14:54           Info     Remote application or plugin has connected127.0.0.1:52843
22
/10/2013 20:14:54           Info     Remote application or plugin has connected127.0.0.1:52842
22
/10/2013 20:14:54           Plug-In     Finished initializing plug-in DSC Security
22
/10/2013 20:14:54           DSC Security     InitIO Successful
22
/10/2013 20:14:54           DSC Security     COM Port COM3 open OK
22
/10/2013 20:14:54           DSC Security     Polling timer is disabledthe panel will not be polled.
22/10/2013 20:14:54           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'1' Key being added'1'
22/10/2013 20:14:54           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'0' Key being added'0'
22/10/2013 20:14:54           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-1' Key being added'-1'
22/10/2013 20:14:54           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-2' Key being added'-2'
22/10/2013 20:14:54           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-3' Key being added'-3'
22/10/2013 20:14:53           Info     Plug-in DSC Security has connected successfully
22
/10/2013 20:14:53           Info     Remote application or plugin has connected127.0.0.1:52836
22
/10/2013 20:14:53           Info     Remote application or plugin has connected127.0.0.1:52835
22
/10/2013 20:14:53           Plug-In     Finished initializing plug-in BLRadar
22
/10/2013 20:14:53           BLRadar start     BLRadar plug-in has been initialized
22
/10/2013 20:14:53           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'1' Key being added'1'
22/10/2013 20:14:53           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'0' Key being added'0'
22/10/2013 20:14:53           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-1' Key being added'-1'
22/10/2013 20:14:53           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-2' Key being added'-2'
22/10/2013 20:14:53           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-3' Key being added'-3'
22/10/2013 20:14:53           Sonos     FindZonePlayersAttempting to locate all connected ZonePlayersThis may take up to 9 seconds.
22/10/2013 20:14:52           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'1' Key being added'1'
22/10/2013 20:14:52           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'0' Key being added'0'
22/10/2013 20:14:52           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-1' Key being added'-1'
22/10/2013 20:14:52           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-2' Key being added'-2'
22/10/2013 20:14:52           Warning     Exception adding a (singlepair to the collectionItem has already been addedKey in dictionary'-3' Key being added'-3'
22/10/2013 20:14:52           Sonos     BuildButtonStringRef Found LinkgroupZoneSource =
22/10/2013 20:14:52           Sonos     InitializeSonosDevices added image /images/Sonos/sonos.jpg
22
/10/2013 20:14:52           Sonos     InitializeSonosDevices found MasterHSDeviceRef in the inifileMasterHSDeviceRef 8302
22
/10/2013 20:14:52           Sonos     Initializing Sonos Devices
So basically the below error comes up in the log for each of my 7 zones:
PHP Code:
22/10/2013 20:20:12           Sonos Error     Error in MediaRenderer.Services for zoneplayer Office with UPNP Error = -2147219524Unknown error typeOrgError=-2147220224. Error=Exception from HRESULT0x80040500
These are a mixture of different devices: Play:3, Play:5, Connect and Connnect:Amp. All running latest Sonos SW.
Also, not sure if it matters, but I am running HS2 and HS3 simultaneously (although on two different machines).
Hope this helps. Let me know if you need anything else.
  #44
Old October 23rd, 2013, 11:13 PM
PHP Code:
22
PHP Code:
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
22
PHP Code:
All benign errors, the one on mediaservices is a problem in Sonos itself, I have few postings on this, they won't show if you turn debug off because they have no negative side effect. The HS2 error on DeviceFinder is some side effect of players coming and going so your network might be better but not 100% either. Have you tried calling Sonos support? Apparently they can log in and see where you may have some stp issues. Running HS2 and HS3 simultaneously should have no negative effect.
Dirk.
  #45
Old October 24th, 2013, 12:46 PM
NicolaiL's Avatar
Super Seer
Dirk.
Thanks, Dirk. I've logged a ticket with Sonos now. Looks like I was only losing ping on one zone. I've also changed the layout a bit now so I only have one wireless zone left on and all other hardwires. Looks like it may remove the lost pings altogether.
I love Sonos, but I hate the way they insist on creating their own network and giving you zero control over it.
  #46
Old November 10th, 2013, 11:33 PM
New Sonos HS3 beta v3.0.0.5 posted
Changes to Beta v3.0.0.5
  • Fixed bug where missing IP Count reset wasn't working
  • Changed the "Address" info for HS device, made it shorter, wasting less space on the web page. You would have to delete all players and recreate to see the effect
  • Fixed some bugs around grouped players and info not shown properly
  • Added support for "Favorites"
  • Reduced linking time for announcements
  • Adding grouping capability
  • Add support for S3 and S1 players (running them as a stereo pair)
  #47
Old November 11th, 2013, 04:09 PM
sooty sooty is offline
Super Seer
Device view page looks tidier now but more importantly for me is that the announcement delay is greatly reduced
Less than 2 seconds here now using 3 players in a TTS group.
Paul..
  #48
Old November 11th, 2013, 05:14 PM
Paul..
If you have been using the PI before this latest version (5), you probably have an entry in the .ini file like this
AnnouncementWaitforPlayTime=2
Edit the file and change it to
AnnouncementWaitforPlayTime=0
This should speed it up even more. I tossed in the bath and kitchen sink so chances are high that some users will experience beginning of announcement loss or the worse, no announcement. For those few, they should set the AnnouncementWaitforPlayTime time > 0. Want to use the "new start" of this HS3 version, combined with benefits in the latest Sonos SW (no need to save the queues) to see if we still need some of the delays that I had to add over the years to cover all corner case scenarios
Dirk
  #49
Old November 11th, 2013, 06:56 PM
Jakob.Sand's Avatar
Jakob.Sand Jakob.Sand is offline
Speak to rooms with occupation only
How do you suggest I build a solution in hs3 where speak in sonos is only routed to the sonos zones in the rooms where I with my PIRs know there there are somebody in the room?
What combination of events and your plugin would be best?
Best,
Jakob Sand, I automate everything!
  #50
Old November 11th, 2013, 07:11 PM
First question I would ask you, how much do you care that the announcement goes to an unoccupied room?
I would start with creating a linkgroup for each individual room you have, obviously each linkgroup having source player and destplayer the same and only that room.
Then I think you would have to create an event for each room so you can make each event conditional upon occupancy in the that room or not.
I know it is quite cumbersome, all depends on how many players (rooms) you have and how many different events you want to cover.
If you start scripting, I'm sure you can simplify things at the cost of having to write and maintain your script.
The script would be something you run when some event occurs, the script would have to check which rooms are occupied and then issue a hs.Speakex event (with text and $SONOS$Linkgroup$) so you can direct the speech to the right room.
Dirk
  #51
Old November 12th, 2013, 12:57 PM
Jakob.Sand's Avatar
Actually is would like to be able to send all warnings announcements etc. from all events more intelligent around the house and online.
Ie. if I am home and my wife is not - send some types of announcements to the sonos and others to her on SMS/Mail etc.
problem is that each event has to handle this individually - instead I would like a model where each event could just do something like: Send "Warning:XXX" to Jakob.
I was house in the house it would be Sonos - if was away it would be e-mail, if my wife was home too - only send to office Sonos...
Does anybody have a setup like that in HS3?
Dirk
  #52
Old November 16th, 2013, 11:51 PM
New Sonos HS3 beta v3.0.0.6 posted
Changes to Beta v3.0.0.6
  • Began adding support to run the plugin on another PC than the HS3 PC. You would have to start the PI with an additional parameter ie server=www.xxx.yyy.zzz representing the IP address of the HS3 PC.
  • Added support to run multiple instances. You would have to start the PI with an additional parameter ie instance=xxx (no '-' characters allowed in instance name)
  • Added option setting to display TrackLenght in Seconds (as integer) or HH:MM:SS format (handy for HSTouch screens)
  • Added option setting to display TrackPosition in Seconds, HH:MM:SS or as a percentage (0->100) (handy for HSTouch screens)
  • Most functions work in HSTouch screens, including albumart. However, content navigation is not available yet in HS3
  #53
Old November 17th, 2013, 04:20 PM
Jakob.Sand's Avatar
In the config menu I do not seem to be able to delete dublet-players.
  #54
Old November 17th, 2013, 04:41 PM
maybe a bit more info, screenshots, how did you get in this situation, what you have already tried, what traces you've looked at etc.
Dirk
  #55
Old November 20th, 2013, 06:00 AM
Jakob.Sand's Avatar
Hi Dirk,
Sorry for the too short entry.
When I click "Plugins - > Sonocontroller - > Config" under "Player Table" and try to delete a player the popup for Confirm I get - seems to stall?
Does that make sense.
Dirk
  #56
Old November 20th, 2013, 11:28 AM
Hi Dirk,
It takes a while to delete a player because deleting entries out of the .ini file is all but fast. So if you wait a little, the pop-up should go away.
Now if you delete a player that is on your network, next time you discover your network, it will be back. This is a function to remove players that are NOT on your network anymore. If you have periodic autodiscoveries on, the player will be back w/i a few minutes.
Dirk
  #57
Old November 21st, 2013, 06:57 PM
Jakob.Sand's Avatar
Link
I tested the link groups. Ie. first I created a couple of groups in the Linkgroup Configuration Table (did not fill out the speaker device field)
if I then click on the button "Control" in the master device and then click a group and at the same time look at my sonos app - all groups are splitted. They new re-group.
When I do the same in HS2 - the groups are re-arranged and grouped nicly when I look at the app at the same time.
Does it make sense?
  #58
Old November 21st, 2013, 08:51 PM
Does it make sense?
Not to me but I'm a bit slow.
Are you saying they don't group properly or how they group is different but it all ends up being OK?
If they just group differently, but group OK, I wouldn't know why because that logic hasn't really changed. Are you running this on different machines? It may just be the CPU horsepower or network response that is different.
If it doesn't group properly at all, can you again turn on the debug, do your thing, capture and post the log, including an exact description (screenshot would be nice) of how the linkgroup was set up and what didn't work properly and/or what your expectation was.
Cheers,
Dirk
  #59
Old November 22nd, 2013, 10:07 AM
Sean Willoughby's Avatar
Sean Willoughby Sean Willoughby is offline
Sorry if this has already been asked, but where is the Help manual. I would like to read up on the options and examples. I currently have the beta installed and would like to tweak/learn some things.
Thanks You!
- Sean
HS3
OS: Windows 7 x64
Plugins:
BLRandom, BLRadar | RFXCOM | PI-SonosController | DirecTV, UPB, XBMC by Spud | UltraCID3, UltraM1G3, UltraMon3, UltraWeatherBug3 | HSTouch Server, Z-Wave
  #60
Old November 22nd, 2013, 11:40 AM
Thanks You!
No Manual yet, sorry. Most of the stuff is the same like HS2 it is just how you create events/triggers that's different but the options themselves are mostly the same. What is it you would like to do?
Dirk
SonosController Plugin General Forum dcorsus PI-SonosController (3P) 167 February 19th, 2018 08:30 AM
SonosController Plug-In Beta testing Forum dcorsus PI-SonosController (3P) 169 February 7th, 2016 05:19 PM
DLNA Manager Plug-In Beta testing Forum dcorsus Media Controller Plug-in (3P) 280 November 19th, 2015 12:26 PM
Beta Builds are now in the Beta forum rjh HS2 / HSPRO 0 January 7th, 2013 04:48 PM
Testing the new beta jowens14 UltraPioneerAVR HSPI 4 December 28th, 2011 11:04 PM
