Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > PI-SonosController (3P)
PI-SonosController (3P) Discussion of Sonos Controller Plug-in
  #161
Old March 1st, 2014, 02:42 PM
dcorsus dcorsus is offline
Originally Posted by Krameduoh View Post
Dirk, Since the latest update this issue has resurfaced. I've lost all my buttons in HSTouch. The only Device options available in HSTouch Designer are Master and Player.
Sent from my HTC6435LVW using Tapatalk
I've updated my bugreport w/ what I can see.
With HS Server v.20, the parent devices now show up in the designer. However I mark the children devices (art, track, album...) as hidden, with the intent that if you set the HS Device Management page to only show non-hidden devices, you would get a neat view of only the summary items for the player.
It now appears that devices marked as hidden won't show in the HS Designer drop down menus. So what you can do until I work this out with the HS team is to manually set your children devices to "Unhidden". Then restart the HST Designer and you should be able to select them and use them. I haven't done any testing on Androids/iPads/CE devices, so there may be some HS issues still lurking. Using the Windows client on my development PC, the album/art/track... info seems to work.
Dirk
  #162
Old March 2nd, 2014, 05:26 PM
New Sonos HS3 beta v3.0.0.10 posted
Changes to Beta v3.0.0.10
  • Help file added, so make sure you copy the Sonos folder!
  • Added "play" command to selecting Audio Line input
  • Added event: "Play Audio Input" to direct a player to source from any audio input
  #163
Old March 13th, 2014, 08:20 AM
Sean Willoughby's Avatar
Sean Willoughby Sean Willoughby is offline
Feature Request:
Can you add replacement word capabilities to the Speaker Proxy?
Original phrase
A Wind Advisory has been issued for Fredericksburg. A WIND ADVISORY IS IN EFFECT UNTIL 11:00AM EDT THURSDAY, MARCH 13.
A Wind Advisory has been issued for Fredericksburg. A WIND ADVISORY IS IN EFFECT UNTIL 11:00AM Eastern Daylight Time THURSDAY, MARCH 13.
- Sean
HS3
OS: Windows 7 x64
Plugins:
BLRandom, BLRadar | RFXCOM | PI-SonosController | DirecTV, UPB, XBMC by Spud | UltraCID3, UltraM1G3, UltraMon3, UltraWeatherBug3 | HSTouch Server, Z-Wave
  #164
Old March 13th, 2014, 10:27 AM
Originally Posted by Sean Willoughby View Post
Feature Request:
Original phrase
If this was a word replacement plugin you could, but something like this doesn't belong in this PI, it is already too complicated as is.
Dirk
  #165
Old March 13th, 2014, 11:40 AM
The problem I have is... I used BLSpeech (paid for it) which is also a speech proxy. After switching over to your plugin to use SONOS speakers, your plugin (paid for also) replaced that proxy which did replace words if needed. I tried running both without any luck. Please help me with a solution here.
  #166
Old March 13th, 2014, 04:20 PM
dpdpkpcom
Guest
Posts: n/a
Unhappy Probably me being stupid, but.....
Does this plugin work on a hs3 Linux-hosted setup ?
It doesn't seem to launch the plugin when all of the standard ones get launched ?
Thank you
dp
  #167
Old March 13th, 2014, 05:56 PM
It doesn't run under Linux because it makes heavy use of windows provided (COM) functions, like the UPNP/SSDP functions. Mono only "translates" .NET functions, not Windows provided COM functions, at least not from what I understand of making Windows app work under Linux.
You could run HS3 on Linux and this PI on a remote windows machine (provided HS adds a few more functions I need to make that work 100%). It may not be what you want, I get that.
To avoid raising your hopes, the chance that this PI will be changed to work under Linux is slim to none. The PI, at last count had about 20,000 lines of code that are tightly weaved around the UPNP com component. Over the years it has already been challenging enough with different versions of windows, Firewalls on HS machines that cause havoc, VMs, network issues, that it is impossible for me to take on the tasks to test and support now a whole slew of more (Linux) environments.
Dirk
  #168
Old March 14th, 2014, 04:27 AM
dpdpkpcom
Guest
Posts: n/a
Thank you very much for the informative reply Dcorsus !!
I thought it would be something like that. And I totally understand why it won't be ported if it's so integrated with COM components.
I don't actually run Homeseer, but I'm trying to integrate Sonos with my existing HA setup. I would have made the leap away from Domoticz if this plugin had allowed the integration.
Windows isn't an option for me for religious reasons ;-)
  #169
Old March 23rd, 2014, 12:16 AM
SQLGOD SQLGOD is offline
Getting Error On Startup
Installed v3.0.0.10. On start up I'm getting this error:
Starting up....
3/23/2014 12:23:08 AM ~!~Error~!~Error, Class not found in plugin EXE, maybe namespace is not correct,? Note filename is case sensitive!: hspi_sonos.exe Class: hspi_sonos.HSPI->Startup Complete, 1 errors detected, check the log for more information.
Also, I noticed some of the sub-folders mentioned in the instructions are no longer in the extract (like the 'Artwork' one "<hs3root>\html\Sonos\Artwork"). Is this intended, or a miss? Not sure why my system won't load the plugin.
Appreciate any direction you can provide.
Chris
  #170
Old March 23rd, 2014, 12:26 AM
Starting up....
Chris
What system (PC) are you running this on? What OS?
Dirk
  #171
Old March 23rd, 2014, 01:37 AM
Dirk
PC is a HP Pavilion running Windows 8. SONOS software is also installed on PC and work. I've tried rebooting several times thinking some of the drivers may need to fully register, but still getting same error at start up, so I never get the PI to show in HS3 so I can get to the config page.
Chris
  #172
Old March 23rd, 2014, 12:38 PM
Did the file name by any chance got changed? I just downloaded the zip file from this post, installed it, all OK. When I change then name from HSPI_Sonos.exe to hspi_sonos.exe, I get the same error, which actually, the error tells us, the file name has changed
Dirk
  #173
Old March 24th, 2014, 01:02 PM
dpdpkpcom
Guest
Posts: n/a
Solution for Linux Users
Just to keep linux users "in the loop" with regards to a solution to stream mp3s/wavs/etc to Sonos speakers. I finally found a solution after trying multiple offerings.
It's in the form of an excellent Ruby Gem.
Host your files at a location available from a URL and then you can use the sonos command line tool to get the files streamed to your Sonos speakers.
I haven't sorted TTS yet, but am confident that this can be done as there are an abundance of Google-related TTS scripts that can be hooked into your home automation setup. They save the TTS as an mp3 that you can then use this gem to stream to Sonos.
Hope this helps others who have been similarly stumped.
dp
  #174
Old March 24th, 2014, 05:29 PM
Works now. When I copied/pasted hspi_sonos.exe file from download, for some reason when I started up HS it got renamed in capitals. I cut/pasted instead and now it works. Odd.
  #175
Old April 6th, 2014, 06:36 PM
mpovolo mpovolo is offline
Can you update the attachment link, it doesn't work.
thanks
  #176
Old April 6th, 2014, 10:42 PM
thanks
Which link? The one at the top of this thread? Works fine for me
Dirk
  #177
Old April 7th, 2014, 08:45 AM
Odd, from my IE on windows 8 the link to the PHP doesn't download. Tried it on my MAC and I can get the file. Something up with Windows 8 internet explorer.
  #178
Old April 7th, 2014, 02:49 PM
Agwan Agwan is offline
Is it just me or did the Sonos plugin and HST stop working together a few days ago? I can no longer see anything more than the "Sonos Master Master" and the "Sonos Livingroom Livingroom" where the latter is the livingroom sonos unit I have installed.
  #179
Old April 7th, 2014, 04:08 PM
See postings #134, 159, 161 above.
Bug report open for quite a while https://www.homeseer.com/bugzilla/show_bug.cgi?id=1441 but don't see any movement. Assuming you are on the latest HSTouch, HS designer, HS3 version, you can work around this by marking the devices as non-hidden.
Dirk
  #180
Old April 7th, 2014, 11:14 PM
Any idea what this error is about, Started happening after the latest update.
Apr-07 11:24:23 PM Sonos Error ERROR in GetCurrentTrackInfo/GetMediaInfo for zoneplayer = Amp with UPNP Error = -2147012194: Unknown error type. OrgError=-2147012894. Error = Exception from HRESULT: 0x80072EE2
Apr-07 11:24:23 PM Sonos Error ERROR in PlayURI for zoneplayer = Amp with UPNP Error = -2147012194: Unknown error type. OrgError=-2147012894. URI=x-sonosapi-stream:s12366?sid=254&flags=32, MetaData={0x3C}DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"{0x3E3C}item id="-1" parentID="-1" restricted="true"{0x3E3C}dc:title{0x3E}Z103.5{0x3C}/dc:title{0x3E3C}upnp:class{0x3E}object.item.audioItem.audioB roadcast{0x3C}/upnp:class{0x3E3C}desc id="cdudn" nameSpace="urn:schemas-rinconnetworks-com:metadata-1-0/"{0x3E}SA_RINCON65031_{0x3C}/desc{0x3E3C}/item{0x3E3C}/DIDL-Lite{0x3E}, Error =Exception from HRESULT: 0x80072EE2
SonosController Plugin General Forum dcorsus PI-SonosController (3P) 167 February 19th, 2018 08:30 AM
SonosController Plug-In Beta testing Forum dcorsus PI-SonosController (3P) 169 February 7th, 2016 05:19 PM
DLNA Manager Plug-In Beta testing Forum dcorsus Media Controller Plug-in (3P) 280 November 19th, 2015 12:26 PM
Beta Builds are now in the Beta forum rjh HS2 / HSPRO 0 January 7th, 2013 04:48 PM
Testing the new beta jowens14 UltraPioneerAVR HSPI 4 December 28th, 2011 11:04 PM
