I am confused by the myHomeSeer login and login types. What I want to do is have one main account for local and admin access and another for a guest connecting to the same computer. I want the guest to have control over the common area lights, etc but no access to the administrative controls.
I set up my admin #1 account online and in HS3 using an email address for username. I was able to login from an Android phone fine.
Next I created a regular user login #2 through HS3 (Setup > Network) to see what it did and that's when I started having trouble. I could not login from my Android phone with the new login or the Admin account. I switched my regular account to Admin and now when I login using the email address #1 it defaults to the #2 username.
I created a guest account #3 through HS3. When I logged in from my Android all I could do was see a few things and could not control anything. My local PC & remote PC also defaulted to this guest login (they were on the same wifi) so I was basically locked into guest mode.
I got back in after following lockout instructions on the site but what do I need to change so that I can achieve my goal above? Should I use a regular or guest account?
