Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeTroller-SEL
HomeTroller-SEL Discussions related to the HomeTroller-SEL automation controller
Old February 26th, 2016, 09:54 AM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
Gmail errors
If you enable the SEL unit for Gmail and enable the receive email feature, you may get a TLS certificate error in the log. To fix this, open a terminal window and enter the following:
sudo certmgr -ssl -m smtps://smtp.gmail.com:465
Units sold after 2/26/16 will have this done during manufacturing and should not need this run.
Old March 5th, 2017, 01:19 AM
Lenard511 Lenard511 is offline
When I run the command you gave form Linux tools. Below is the response I get back:
running comand sudo certmgr -ssl -m smtps://smtp.gmail.com:465
Mono Certificate Manager - version 3.2.8.0
Manage X.509 certificates and CRL from stores.
Copyright 2002, 2003 Motus Technologies. Copyright 2004-2008 Novell. BSD licensed.
X.509 Certificate v3
Issued from: C=US, O=Equifax, OU=Equifax Secure Certificate Authority
Issued to: C=US, O=GeoTrust Inc., CN=GeoTrust Global CA
Valid from: 5/21/2002 4:00:00 AM
Valid until: 8/21/2018 4:00:00 AM
*** WARNING: Certificate signature is INVALID ***
Import this certificate into the CA store ?
If I type y or yes and hit the execute button nothing happens.
I still get the below error:
Unable to log into Gmail server: Authenticate as SSL client failed. You might be connecting to non SSL port.:Inner Exception: System.IO.IOException: The authentication or decryption has failed. ---> Mono.Security.Protocol.Tls.TlsException: Invalid certificate received from server. at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.LocalValidation (Mono.Security.Protocol.Tls.ClientContext context, AlertDescription description) [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.validateCertificates (Mono.Security.X509.X509CertificateCollection certificates) [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.Client.TlsServerCertifi cate.ProcessAsTls1 () [0x00000] in :0 at Mono.Security.Protocol.Tls.Handshake.HandshakeMessage.Proces s () [0x00000] in :0 at (wrapper remoting-invoke-with-check) Mono.Security.Protocol.Tls.Handshake.HandshakeMessage:Proces s () at Mono.Security.Protocol.Tls.ClientRecordProtocol.ProcessHands hakeMessage (Mono.Security.Protocol.Tls.TlsStream handMsg) [0x00000] in :0 at Mono.Security.Protocol.Tls.RecordProtocol.InternalReceiveRec ordCallback (IAsyncResult asyncResult) [0x00000] in :0 --- End of inner exception stack trace --- at Mono.Security.Protocol.Tls.SslStreamBase.AsyncHandshakeCallb ack (IAsyncResult asyncResult) [0x00000] in :0
Old July 21st, 2017, 07:59 PM
nevilletwarner nevilletwarner is offline
Viewer
I am having the same issues. Was anyone able to find a solution?
GMail/Stunnel Errors mrhappy HS2 / HSPRO 32 August 2nd, 2016 03:49 PM
Can't set Gmail Password. Phill HS3 / HS3PRO Discussion 2 March 3rd, 2015 03:45 PM
gmail errors kenrad HS3 / HS3PRO Discussion 0 December 19th, 2013 07:30 PM
gMail/stunnel pwhite8314 HS2 / HSPRO 1 March 29th, 2010 11:39 AM
POP connection to gmail marksy HomeSeer General Discussion Area 9 November 6th, 2005 12:17 AM
