Perhaps you might listen to the folks who purchased your plugin in this thread and not worry about your TODO list...
MyQ Garage Door Control with ImperiHome
Originally posted by spud View PostHave you tried to use a multiswitch? What's wrong with this solution?
Guys give Spud a break... this isnt broken, just not ideal. I'd also like to have a proper button w/ status but I decided to create an Event and placed a shortcut on my desktop so I don't have to open IH to trigger the garage doors to open/close
I created a Composite Devices script that shows if ALL the Garage doors are open or closed, and which one is open if one is.
Not perfect but I can also use the composite garage doors vDevice for events.
Spud, an idea...
I think it would be valuable to have more device patterns embedded in the plugin so we would not need to manually create so many devices (humidity, temp, etc).
If you don't want to add these constantly (since new devices come to market every year) - what about exposing the device pattern in the user config? This way we could add our own patterns, and share them?
I
Originally posted by jumper4000 View PostI just tried multiswitch. It works, but it takes a couple extra clicks to open/close the garage and it doesn't match my other door lock/gate devices. I guess it's a workaround for now, but if you can get this working with the "Door Locks" device type, that'll be great.
Why not ask the MyQ author to make changes to the door device that plugin creates so it works properly with imperihome? The garadget plugin door device works great with imperihome. You could mention that as an example._______________________________________________
Originally posted by jlrichar View PostWhy not ask the MyQ author to make changes to the door device that plugin creates so it works properly with imperihome? The garadget plugin door device works great with imperihome. You could mention that as an example.Last edited by spud; August 25, 2017, 12:46 PM.
Guest
Originally posted by macrho View PostPerhaps you might listen to the folks who purchased your plugin in this thread and not worry about your TODO list...
Let's all play nice with the developers and be respectful of their time and effort
Originally posted by 519zwave View PostIt is conceivable that Spuds todo list consists of more than this plugin, and wasn't referring to the importance of that work around for imperihome...??
Originally posted by macrho View PostPerhaps, though this thread has been open for over a year. I have higher expectations for a plugin I purchase. Maybe the solution will wind up with the MyQ guys...
That said, his plug-in does not follow the norms for control values to be the same as status values as all HomeSeer devices and most other plug-in's devices do.
Spud built a plug-in that cannot accommodate the divergence from the norms that the MyQ plug-in uses.
For whom do you have higher expectations?HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostI use Eric's MyQ plug-in and I am very happy with how hard he has worked to get around all the hurdles that Chamberlain continues to throw at him.
My expectation is response from the plug-in author from whatever plug-in I purchased. In this case, if this isn't going to be added, then simply close the thread.
Originally posted by macrho View PostMyQ still doesn't offer an API, so it's a hack to get that working? I had released a MyQ plugin for Vera and never thought of charging for something that is not officially supported by the vendor.
I agree with you somewhat about charging for plugins that do not use official APIs. It is probably fine to charge, as long as EVERY customer understands that it is much more likely to fail when the original service vendor makes changes. While the authors are all up-front about this on the board, it is not specifically listed in the updater, or in the Homeseer store, and it should be._______________________________________________
Originally posted by jlrichar View PostThat is all well and good. But it seems you are asking the wrong author. You did pay for the MyQ plugin? Did you ask Eric (if that is the one you are using) to make the change to his plugin? He is currently putting a ton of time into his plugin, perhaps this is not a problem for him to incorporate.
Originally posted by spud View Postyeah that's a good solution too, basically he would only need to change the values of the 2 controls to open and close so that it match the values of the Open and closed statuses, i.e change 100 and 200 to 1 and 2
He said he will fix it in the next update, so looks like we're set - https://forums.homeseer.com/showthread.php?t=190641
