Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeTroller-SEL
HomeTroller-SEL Discussions related to the HomeTroller-SEL automation controller
Old May 3rd, 2017, 11:04 AM
abwyatt's Avatar
abwyatt abwyatt is offline
SEL won't restart on power restore
My SEL used to restart automatically after a power outage returns power to the SEL.
But I just discovered it no longer does so. Anyone know why this has happened or what controls the auto restart?
Current Date/Time: 5/3/2017 9:41:41 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.318
Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 0 Days 0 Hours 8 Minutes 33 Seconds
IP Address: 192.168.100.101
Number of Devices: 187
Number of Events: 171
Available Threads: 199
Enabled Plug-Ins
2.0.35.0: BLLAN
3.0.0.5: CM15A
1.0.0.0: drhsEventEnabler
3.0.0.103: HSTouch Server
3.0.4.2: SDJ-Health
3.0.5917.35093: UltraLog3
3.0.1.110: Z-Wave
Old May 3rd, 2017, 11:17 AM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Pretty sure that's a setting in the hardware BIOS. That's not something I would expect to change suddenly though; odd. Contact our support folks for help with that.
Old May 3rd, 2017, 11:27 AM
abwyatt's Avatar
I should have added that it happened after my SEL had another of it's gmail caused HS3 crashes. I really need to do something about using another email system.
However, this time when I turned the power off and on as I usually do, it wouldn't boot up.
I connected a screen to check what was going on and there was a disk error. First time I've had that occur. Fixed that, then it reported mono-sgen had stopped unexpectedly. I assumed that it was related to the disk error. Rebooted several times after that and it looked fine.
Next I tried turning the power off then on, and that is when I discovered that the SEL was not restarting automatically.
Old May 3rd, 2017, 11:47 AM
abwyatt's Avatar
Thanks for your pointer anyway. It's fixed now.
Hope the disk error stays away and is not a sign of a deteriorating SSD.
Old May 4th, 2017, 05:09 PM
Pete's Avatar
Pete Pete is offline
In Linux you can force a disk check while it is booting or boot up with a USB / ISO disk checking disk which will do an external check of the SSD.
Automator
Hardware | Haswell Intel iSeries 3 - 16Gb | Pine64 - 2Gb computers
HS3 Pro & Lite
Edition Beta 3.0.0.398 | Ubuntu 16.04 64 bit | Oracle Windows Virtual Box ==> for Wintel only SAPI and HS3 plugins
HS3 Plugins - a bunch
Light switches - X10,UPB, ZWave and Zigbee
Speech - Microsoft SAPI - Neospeech - Amazon Echo
Security - Leviton HAI Omni Pro 2
Weather - Davis Vantage Vue - MeteoStick
Firewall - PFSense
CCTV - Zoneminder
Audio - Russound - AB8SS
Old May 4th, 2017, 11:48 PM
abwyatt's Avatar
Thanks for the pointer Pete. So I take it you permanently leave the USB ISO disk plugged in as a fail safe?
Where can I get the ISO file?
Old May 5th, 2017, 12:03 PM
Pete's Avatar
No.
A bootable USB / ISO is only utilized for repair of the main hard drive and only if needed.
It just boots up to either a wintel or Linux desk top with disk repair utilities.
This is a last resort fix if forcing a disk check doesn't fix the hard drive.
Here is my favorite that I have used recently.
Boot-Repair-disk
Using Linux/Windows tools you can write the ISO to a USB stick. I have not burned a CD / DVD in many years now.
In Linux it is a bit different. You configure a forced disk check in the boot sequence where as it checks the disk before booting the OS (or mounting the hard drive).
Old May 6th, 2017, 12:34 AM
abwyatt's Avatar
No.
Boot-Repair-disk
Great! Thanks for the tips Pete.
HomeTroller Series 3 Not Powering On After Power Failure/Restore KBF100 HomeTroller™ 2 December 9th, 2012 10:29 PM
HT2 - Restart after power loss Mark42 HomeTroller™ 6 November 2nd, 2010 05:27 AM
power restore not giving me chance to cancel johnnyt HomeSeer General Discussion Area 8 April 5th, 2005 06:09 AM
Power Restore goddard99 HomeSeer General Discussion Area 1 October 19th, 2004 05:15 AM
