Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > PI-SonosController (3P)
PI-SonosController (3P) Discussion of Sonos Controller Plug-in
Old July 8th, 2017, 06:55 PM
jbbtex's Avatar
jbbtex jbbtex is offline
Transport locked
I'm getting this error over and over in the HS log.
ERROR in GetQueueElement for zoneplayer = Emma with UPNP Error = Read only tag / Transport is locked / Access denied.
Error = MyUPnPService.InvokeAction for ServiceID = http://192.168.1.108:1400/xml/ContentDirectory1.xml while preparing to send
Action = Browse for URI = http://192.168.1.108:1400/MediaServer/ContentDirectory/Control and Request = Q:0
BrowseDirectChildren * 0 1 with error = Unable to connect to the remote server
Any idea what the problem could be?
Brady
Old July 8th, 2017, 07:16 PM
dcorsus dcorsus is offline
What are you trying to do with HSTouch? Browse content? The MediaAPI doesn't really work properly so I would turn the "support MediaAPI" in the config page off.
Dirk
Old July 8th, 2017, 07:20 PM
rprade's Avatar
rprade rprade is offline
How is your Sonos network configured? I will get that error frequently if even one is hardwired making it run on SonosNet. With all of my units straight WiFi the errors almost completely go away. I might see one a week. It has been this way since I switched to Sonos last year. It is also repeatable - it will immediately begin generating those errors and fail on TTS announcements if I connect a unit to copper and they will go away when I return it to WiFi.
You will also get similar errors if a unit defined in the plug-in is offline. Is Emma plugged in and working with the Sonos App?
Randy Prade
Aurora, CO
Prades.net
"Do or do not, there is no try"
-Yoda
Old July 8th, 2017, 08:01 PM
jbbtex's Avatar
I did have the Media API turned on. Turning it off but didn't seem to help.
All of my players are connected to copper and I have the wifi in each unit turned off.
I haven't had any issues until I moved this player to another room/different cat 5e. I'll try it on a different cat5e.
Thanks for the suggestions.
Old July 8th, 2017, 09:31 PM
After turning the MediaAPI flag off, you need to restart HSTouch (or HS3 if you are currently experimenting with HS3 >v332). This is a function only used via MediaAPI calls.
Dirk
Old July 8th, 2017, 10:06 PM
jbbtex's Avatar
Dirk
OK. Thanks
Old July 8th, 2017, 10:11 PM
Bob_Linux_User's Avatar
Bob_Linux_User Bob_Linux_User is offline
I agree with Randy, about having Cat5 connected. I have reduced my SONOS errors by going to all WIFI, but they still occur as they did tonight while We were gone to a wedding. I also do not have the MediaAPI enabled.
Bob
Jul-08 18:41:34	 	Sonos Error	ERROR in GetSoftwareVersion for zoneplayer = TV Playbar_RR with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://192.168.1.4:1400/xml/DeviceProperties1.xml while sending Action = GetZoneInfo for URI = http://192.168.1.4:1400/DeviceProperties/Control and Request = UPNP Error = with error = The underlying connection was closed: The connection was closed unexpectedly.
Jul-08 18:41:14	 	Sonos Error	Error in Adding AlarmClock Control Call Back for zoneplayer = TV Playbar_RR. Error=Error in MyUPnPService.AddCallback while sending URL = http://192.168.1.4:1400/AlarmClock/Event to = http://192.168.1.4:1400/AlarmClock/Event with error = The underlying connection was closed: The connection was closed unexpectedly.
Jul-08 18:40:41	 	Sonos Error	Error in Adding DeviceProperties Call Back for zoneplayer = TV Playbar_RR. ErrorError in MyUPnPService.AddCallback while sending URL = http://192.168.1.4:1400/DeviceProperties/Event to = http://192.168.1.4:1400/DeviceProperties/Event with error = The underlying connection was closed: The connection was closed unexpectedly.
Jul-08 18:40:13	 	Sonos Error	ERROR in GetSoftwareVersion for zoneplayer = TV Playbar_RR with UPNP Error = Read only tag / Transport is locked / Access denied. Error = MyUPnPService.InvokeAction for ServiceID = http://192.168.1.4:1400/xml/DeviceProperties1.xml while sending Action = GetZoneInfo for URI = http://192.168.1.4:1400/DeviceProperties/Control and Request = UPNP Error = with error = The underlying connection was closed: The connection was closed unexpectedly.
Email Transport Sheriff HomeSeer General Discussion Area 21 December 28th, 2015 07:33 PM
Email Transport Sheriff Legacy Software (Older Versions) 0 July 5th, 2015 05:12 PM
Feature request: add transport & volume controls to UPnP master device mfisher PI-SonosController (3P) 7 April 23rd, 2012 02:04 AM
Sending email using SMTP: The transport failed to connect to the server. TimJo HomeSeer General Discussion Area 0 June 28th, 2008 12:53 PM
Locked out of HS/2 tmcgowan HS2 / HSPRO 16 December 17th, 2005 11:41 AM
