Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > PI-SonosController (3P)
PI-SonosController (3P) Discussion of Sonos Controller Plug-in
Old August 7th, 2017, 08:03 PM
Ultrajones's Avatar
Ultrajones Ultrajones is offline
Possible Memory Leak?
Hi Dirk,
I just logged into my HomeSeer system and noticed the Sonos plug-in taking over 525 MB of memory. Is this normal? For comparison, HomeSeer, HSTouch, HSPI_ZWave and the 17 other plug-ins I run consume less than 250 MB.
Ultrajones
Old August 7th, 2017, 08:40 PM
rprade's Avatar
rprade rprade is offline
Originally Posted by Ultrajones View Post
Hi Dirk,
Ultrajones
Mine is running at 39.8MB right now and I have never seen it using a lot of memory. I have 8 clients.
Randy Prade
Aurora, CO
Prades.net
"Do or do not, there is no try"
-Yoda
Old August 7th, 2017, 09:12 PM
dcorsus dcorsus is offline
Hi Dirk,
Ultrajones
It shouldn't. The only thing that can jack up memory utilization is the period when the music DB is being (re)created or there is an issue with the MusicDB.
Which version of the PI are you running? Windows or Linux?
Are you using HSTouch and/or is the MediaAPI option selected in the options (if you are on the latest R3.1.x.x PI version).
Dirk
Old August 8th, 2017, 09:10 AM
MNB's Avatar
MNB MNB is offline
I can also confirm same, mine is running at 23.9Mb with 6 clients on version 3.1.0.20. Mike
Old August 12th, 2017, 10:53 AM
Ultrajones's Avatar
Hi Dirk,
I was using version 3.0.0.21 on Windows 10. I just had it enabled and wasn't using any of the features.
Old August 12th, 2017, 11:05 AM
rprade's Avatar
Hi Dirk,
You might want to try the beta 3.1.0.20.
Memory Leak mark_anderson_us HS2 / HSPRO 149 August 20th, 2012 06:09 AM
Is this a memory leak? ArbWare HS2 / HSPRO 1 December 10th, 2009 04:14 PM
Memory Leak mterry63 Bluetooth Connector 3 September 21st, 2008 01:50 PM
Is this a memory leak ? Stuart HS2 / HSPRO 4 August 8th, 2007 08:25 AM
memory leak rvgara Hauppauge Capture (3P) 2 May 3rd, 2003 06:50 AM
