Originally posted by zwolfpack
View Post
HS3 Vista Alarm plugin v3.0.0.40 Beta (for Windows & Linux)
Mark
HS3 Pro 4.2.19.5
@zwolfpack, @aaron
right now, the plugin just responds to several bits regardless of the countdown. so the plugin is acting consistently for any arm state based on the ad2usb messages. Again, regardless of the panel settings.
i think i can hold the alarm arm status change until the countdown value is 0 but i need to check the various use cases on my 20p, and even the 20se i have.
i don't want to break functionality that has been around for a while.
if you guys can provide any debug logging that shows the ad2usb messages for the transition from the last countdown to an arm state, i would appreciate it. i would need to know your panel model, and the state of *197Mark
HS3 Pro 4.2.19.5
Here are ad2usb PuTTY captures for disarmed => armed-stay and disarmed => armed-away
Panel is Vista-21iP
System info
Operating System: Microsoft Windows Embedded Standard - Work Station
3.0.0.34: Vista Alarm
Noted that the panel is silent during the armed-stay countdown. For armed-away, it beeps once/second during countdown.Attached Files
Originally posted by zwolfpack View PostHere are ad2usb PuTTY captures for disarmed => armed-stay and disarmed => armed-away
Panel is Vista-21iP
System info
when you activate arm-stay or arm-away isn't the system actually in an Arm mode even during the countdown? that is, if you open a window or non-exit/entry door during the countdown, wont the alarm sound?Mark
HS3 Pro 4.2.19.5
Originally posted by aaron View PostThanks zwolfpack. I can also confirm settings option 197 to 0 fixes the issue.
mnsandler: any chance we can get this fixed?
when do either of you have time to test?Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Posti think i found the issue with arm-away and arm-max with the countdown
Let me know if you still want the results of opening a window during the countdown. Triggering the alarm requires a bit more planning (disconnecting the sounder) -- don't need to upset the cats!
Just to clarify - I believe the current behavior of armed-away & armed-max is the preferred behavior, see post #83. His issue was with armed-stay/instant not switching until after the countdown completed.
to confirm, if you can verify that the Armed led is lit on a panel even during a countdown, that will be good enough.
no need to test opening a window during countdown.
i'll post a beta update once i hear backMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postto confirm, if you can verify that the Armed led is lit on a panel even during a countdown, that will be good enough.
Originally posted by zwolfpack View PostYes, the panel LEDs change from ready (green) to armed (red) immediately upon the arming action. So it's showing armed during the countdown. Verified this for away, stay, max, and instant modes.Mark
HS3 Pro 4.2.19.5
Originally posted by zwolfpack View PostLooks good!
Verified that the device now switches immediately upon arming for each mode (away, stay, max, instant).Mark
HS3 Pro 4.2.19.5
Guest
Originally posted by aaron View PostI appreciate it! THANK YOU VERY MUCH!!!Mark
HS3 Pro 4.2.19.5
Mark, I've been running 3.0.0.15 of your Vista plugin with my Ademco 10 panel for a couple of years at least and this has been rock solid while fitting my needs. I just noticed there is a big jump now to 3.0.0.38. Will this cause a problem should I upgrade in my case? I hate to fall too far behind on my plugin releases...
RobertHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by langenet View PostMark, I've been running 3.0.0.15 of your Vista plugin with my Ademco 10 panel for a couple of years at least and this has been rock solid while fitting my needs. I just noticed there is a big jump now to 3.0.0.38. Will this cause a problem should I upgrade in my case? I hate to fall too far behind on my plugin releases...
RobertMark
HS3 Pro 4.2.19.5
