Plugin to monitor Z-Wave battery device Health - CLOSED
I've updated to 3.0.4.0 but when I try to access the config I get the error message and log entrys below.
ERROR in GetPagePlugin: Item has already been added. Key in dictionary: 'Livingroom Z-Wave Fibaro On/Off Sensor(Z-Wave)' Key being added: 'Livingroom Z-Wave Fibaro On/Off Sensor(Z-Wave)'
Mar-07 15:49:54 SDJ-Health Failed to find battery child.
Mar-07 15:49:54 SDJ-Health Activity Checking stopped.
Mar-07 15:49:54 SDJ-Health Polling devices stopped.
Mar-07 15:49:54 SDJ-Health PEData read sucessfully from child device #989
Mar-07 15:49:54 SDJ-Health PEData read sucessfully from child device #988
Mar-07 15:49:54 SDJ-Health PEData read sucessfully from child device #987
Mar-07 15:49:54 SDJ-Health PEData read sucessfully from child device #986
Mar-07 15:49:54 SDJ-Health PEData read sucessfully from child device #985
Mar-07 15:49:54 SDJ-Health PEData read sucessfully from child device #1048
Mar-07 15:49:54 SDJ-Health PEData read sucessfully from child device #1047
Mar-07 15:49:54 SDJ-Health PEData read sucessfully from child device #1038
Mar-07 15:49:54 SDJ-Health PEData read sucessfully from child device #1030
Mar-07 15:49:54 SDJ-Health PEData read sucessfully from child device #1028
Mar-07 15:49:42 Plug-In Finished initializing plug-in SDJ-Health
Mar-07 15:49:42 SDJ-Health Version 3.0.4.0 Initialized.
I stopped HS3, copied in the .exe and the images folder, restarted HS3. I've even stopped the plugin and deleted the .ini and .ini backup file and restarted but still the same error.
Any ideas what might be causing this?
Simon
Originally posted by Simonk View PostI've updated to 3.0.4.0 but when I try to access the config I get the error message and log entrys below.
Simon
Steve
Originally posted by SteveMSJ View PostIt looks like something might be a bit messed up with the monitoring devices. If this was upgraded from the earlier version then perhaps something didn't convert correctly. The error in GetPagePlugin is because it is trying to add two devices with the same name to the list. It is probably due to the same issue but it's not impossible to have 2 devices named the same so I have corrected that bug and uploaded 3.0.4.1 to the earlier post. This will hopefully allow you to open the Config page. Change to LogLevel 2 and restart the plugin which should give me a bit more information to track down which devices it is having problems with.
Steve
Code:Mar-07 21:58:47 SDJ-Health Device #508 added to message queue for processing. Mar-07 21:58:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:58:38 SDJ-Health Failed to find battery child. Mar-07 21:58:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:58:38 SDJ-Health Failed to find battery child. Mar-07 21:58:38 SDJ-Health Checking status... Mar-07 21:56:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:56:38 SDJ-Health Failed to find battery child. Mar-07 21:56:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:56:38 SDJ-Health Failed to find battery child. Mar-07 21:56:38 SDJ-Health Checking status... Mar-07 21:54:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:54:38 SDJ-Health Failed to find battery child. Mar-07 21:54:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:54:38 SDJ-Health Failed to find battery child. Mar-07 21:54:38 SDJ-Health Checking status... Mar-07 21:52:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:52:38 SDJ-Health Failed to find battery child. Mar-07 21:52:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:52:38 SDJ-Health Failed to find battery child. Mar-07 21:52:38 SDJ-Health Checking status... Mar-07 21:52:38 SDJ-Health PEData written sucessfully to child device #987 Mar-07 21:52:38 SDJ-Health Device #674 found in database Mar-07 21:51:24 SDJ-Health Device #674 added to message queue for processing. Mar-07 21:50:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:50:38 SDJ-Health Failed to find battery child. Mar-07 21:50:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:50:38 SDJ-Health Failed to find battery child. Mar-07 21:50:38 SDJ-Health Checking status... Mar-07 21:50:38 SDJ-Health PEData written sucessfully to child device #988 Mar-07 21:50:37 SDJ-Health Device #684 found in database Mar-07 21:50:17 SDJ-Health Device #684 added to message queue for processing. Mar-07 21:48:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:48:38 SDJ-Health Failed to find battery child. Mar-07 21:48:38 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:48:38 SDJ-Health Failed to find battery child. Mar-07 21:48:38 SDJ-Health Checking status... Mar-07 21:48:38 SDJ-Health PEData written sucessfully to child device #985 Mar-07 21:48:38 SDJ-Health Device #678 found in database Mar-07 21:47:18 SDJ-Health Device #678 added to message queue for processing. Mar-07 21:46:40 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:46:40 SDJ-Health Failed to find battery child. Mar-07 21:46:40 SDJ-Health Warnig - Battery devices #0 not found! Mar-07 21:46:40 SDJ-Health Failed to find battery child. Mar-07 21:46:40 SDJ-Health Checking status... Mar-07 21:46:40 SDJ-Health Activity Checking stopped. Mar-07 21:46:40 SDJ-Health Debug - Starting Update Activity Checking... Mar-07 21:46:40 SDJ-Health 0 devices in Checking Activity list Mar-07 21:46:40 SDJ-Health Debug - Checking Activity Devices.... Mar-07 21:46:40 SDJ-Health Polling devices stopped. Mar-07 21:46:40 SDJ-Health Debug - Starting Update Polling... Mar-07 21:46:40 SDJ-Health 0 devices in polling list Mar-07 21:46:40 SDJ-Health Debug - Checking Poll Devices.... Mar-07 21:46:40 SDJ-Health Debug - Finished registering callbacks. Mar-07 21:46:40 SDJ-Health Debug - Registering Enums.HSEvent.LOG Mar-07 21:46:40 SDJ-Health Debug - Registering Enums.HSEvent.CONFIG_CHANGE Mar-07 21:46:40 SDJ-Health Debug - CheckAndCreateDevices completed Mar-07 21:46:40 SDJ-Health PEData read sucessfully from child device #989 Mar-07 21:46:40 SDJ-Health Child device #989 found in database. Mar-07 21:46:40 SDJ-Health PEData read sucessfully from child device #988 Mar-07 21:46:40 SDJ-Health Child device #988 found in database. Mar-07 21:46:40 SDJ-Health PEData read sucessfully from child device #987 Mar-07 21:46:40 SDJ-Health Child device #987 found in database. Mar-07 21:46:40 SDJ-Health PEData read sucessfully from child device #986 Mar-07 21:46:40 SDJ-Health Child device #986 found in database. Mar-07 21:46:40 SDJ-Health PEData read sucessfully from child device #985 Mar-07 21:46:40 SDJ-Health Child device #985 found in database. Mar-07 21:46:40 SDJ-Health PEData read sucessfully from child device #1048 Mar-07 21:46:40 SDJ-Health Child device #1048 found in database. Mar-07 21:46:40 SDJ-Health PEData read sucessfully from child device #1047 Mar-07 21:46:40 SDJ-Health Child device #1047 found in database. Mar-07 21:46:40 SDJ-Health PEData read sucessfully from child device #1038 Mar-07 21:46:40 SDJ-Health Child device #1038 found in database. Mar-07 21:46:39 SDJ-Health PEData read sucessfully from child device #1030 Mar-07 21:46:39 SDJ-Health Child device #1030 found in database. Mar-07 21:46:39 SDJ-Health PEData read sucessfully from child device #1028 Mar-07 21:46:39 SDJ-Health Child device #1028 found in database. Mar-07 21:46:39 SDJ-Health 10 child devices found. Mar-07 21:46:39 SDJ-Health Child device associations cleaned up. Mar-07 21:46:39 SDJ-Health PEData read sucessfully from root device. Mar-07 21:46:39 SDJ-Health Root device identified. Mar-07 21:46:38 SDJ-Health Debug - CheckAndCreateDevices started Mar-07 21:46:38 SDJ-Health Debug - BuildInterfaceList completed Mar-07 21:46:38 SDJ-Health HomeID D7894C18 : Interface Name Z-Wave.me UZB Mar-07 21:46:37 SDJ-Health Debug - BuildInterfaceList started Mar-07 21:46:27 SDJ-Health Version 3.0.4.1 Initialized.
Originally posted by Simonk View PostI left it running for 10 minutes, filtered log below.
Have a look through your monitoring devices and see if the devices they are monitoring make sense, i.e. they are battery powered devices and have a proper root and battery child. Also check the reported battery levels match the levels of the actual battery devices. If you find one that isn't correct then the easiest thing to do is delete the monitoring child. If it is a valid device it will create a new child when it next wakes up. If you can't find anything odd I would suggest deleting all the monitoring children, just leaving the root device, and let the plugin recreate them all. Do this whilst the plugin is running so it knows they are deleted and removes them from the information stored in the root device. If you delete them when the plugin isn't running it will recreate them from the stored information when you restart it, which you don't want it to do in this particular case.
Steve
Hi Steve, installed new version. First uninstalled the previous one. Now it is started creating the devices. It is nice you can also monitor using the last successful communication of the device or it child's but it would be nice if you could also display the last time stamp of last communication in the devices that are monitored using wake up message detection
Originally posted by olof View PostHi Steve, installed new version. First uninstalled the previous one. Now it is started creating the devices. It is nice you can also monitor using the last successful communication of the device or it child's but it would be nice if you could also display the last time stamp of last communication in the devices that are monitored using wake up message detection
I'm trying to keep the footprint of the plug-in as small as possible so you would need to convince me that adding the additional information, which needs to be detected, displayed and stored, is of benefit. It wouldn't be difficult to do, but for me the time of the last detected wake-up call and the sleep period (together with the battery information) is all I want to know. That tells me the device is alive and working which is the purpose of the plug-in.
However, perhaps you have a purpose in mind, so I'd welcome your views.
Incidentally, for devices that the plug-in monitors by 'Activity Checking', it doesn't actually display the date/time of the last activity but it uses it as an indication that the device is alive. So if the 'Activity Monitoring' period is set to 6 hours it will check every 6 hours that there has been a device change within the last 6 hours. If there has then it considers the device is alive and displays the check date/time as the 'Last Good Check'.
Steve
First off, I want to say that this is a great addition to our system. My goal is to have my wife be able to replace batteries if I am unable to. HS3 battery reporting is not quite there and this has been a negative for me.
I'm getting this error when I change the root device report:
SDJ-Health ERROR - Setting Root String: Argument 'Index' is not a valid value.
Any help on this would be appreciated.
MichaelMichael
Originally posted by Rvtravlr View PostFirst off, I want to say that this is a great addition to our system. My goal is to have my wife be able to replace batteries if I am unable to. HS3 battery reporting is not quite there and this has been a negative for me.
Michael
Steve
Originally posted by SteveMSJ View PostI can't reproduce this so I've updated the version in message #192 to 3.0.4.2. with some additional error checking to help pin down your issue. Please can you update and then post what errors it logs when you change the root device reports?
MichaelMichael
Just loaded in 3.0.4.2 on Linux, it's detecting things as they come up in the log.
However I'm seeing a number of these errors since it was installed:
Mar-17 9:20:53 PM SDJ-Health Error - whilst checking latest status of all monitored devices! Number overflow.
Mar-17 9:20:35 PM SDJ-Health Error - whilst checking latest status of all monitored devices! Number overflow.
Originally posted by karib View PostJust loaded in 3.0.4.2 on Linux, it's detecting things as they come up in the log.
Steve
Battery Discharge Rate
Hi Steve,
Been running the new version and overall it is running well. I do have an Everspring luminance sensor that dropped from 100% battery to 90% battery a few days after I installed the new version, so it flagged it as a high discharge rate (> 15.5%), but it's been sitting like that over the last week. Will it eventually clear? Everspring devices will only report battery values in steps of 10%, so I expect this will be a continual issue with these devices.
AlHS 4.2.8.0: 2134 Devices 1252 Events
