Thanks to Uncle Michael, Mark and everyone I was able to get an X10 tab. I understand what you mean about labels in Setup and I got the software setup. Still no communication from the X10 so I tried a last ditch effort and plugged in a 100' extension cord to the outlet I originally used in the basement through the years and dragged it to the second floor bedroom and plugged in the CM11A. Voila! Everything is working fine! HSTouch included.
Now I have to find a local compatible circuit to plug the CM11A A in. I was also thinking that I might extend the RJ11 connection to the controller instead. Does anyone know if there is a length limitation of the connection to the RS-232 serial port?
Thank you again
Thank you again
