Please excuse me if this is the wrong place for the message. I couldn't find any other place that is Jowi related.
I was using a VB script "Jowi PictureRandom" in my HS2 setup. It takes pictures from a directory and randomly presents them in HTML to be used by HSTouch.
I can't migrate it to my HS3 setup. I moved the .vb and .ini files to the respective HS3 directories. Getting these errors in the log when attempting to run it.
Help will be appreciated.
Apr-26 10:24:20 AM Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\JOWI_PictureRandom.vb: Type 'Drawing.Graphics' is not defined.
Apr-26 10:24:20 AM Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\JOWI_PictureRandom.vb: Type 'Drawing.Bitmap' is not defined.
Apr-26 10:24:20 AM Error Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\JOWI_PictureRandom.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
