Post your feature requests here.
Outstanding feature requests:
Ultrajones
- Add ethernet support using the Elk M1XEP [complete]
- Add thermostat support [complete]
- Added the ability to change the Elk M1XEP non-secure port [complete]
- Add watchdog timer [complete]
- Detect when the ELKRP connects to the Elk M1 panel and provide a HomeSeer trigger for this event [complete]
- Add support for reading and writing the "Custom Settings" stored in the Elk M1 [complete]
- Add support for Elk M1 Lighting [complete]
- Display different status icon for zones defined as Non Alarm [complete]
- Add option to set temperrature polling interval [Not needed, newer Elk Firmware sends temperature changes]
- Trigger event based on user disarming system [complete]
- Add an Elk M1 Timesync Action [complete]
- Trigger event based on System Trouble Status [complete, requires firmware > 4.5.2, 5.1.2]
- Add Zone and Output names to triggers, conditions and actions. [complete]
- Speak words and phases via scripting interface. [complete]
- Add support to use custom keypad codes (6 digits) or Weigand data cards to trigger HomeSeer events. [complete]
- Add GetZoneStatusEx, GetOutputStatusEx to scripting API. [complete]
- Add Elk Lighting dimming support. [complete]
- Add the ability to create for more than 99 inputs, outpus and ligthing HomeSeer devices. [complete]
- Add HomeSeer device that tracks last user action (arm|disarm). [complete]
- Add support for counters.[complete]
- Add ability to create an input and output device for each keypad.
- When adding HomeSeer devices for thermostats, make it so each of the thermostat items can be added individually.
- Add an option to allow the UltraM1G plug-in to reload data from the Elk M1 when the ElkRP software disconnects.
- Force a re-sync after the ElkRP disconnections.
Ultrajones
