I had to restart my system after having updated the plug-in to 1.0.6 from 1.0.5. I looked at the log and saw a bunch of errors to do with the Device History plug-in. These errors occur when it tries to build a chart from an event. The events have been running fine for months and have not been changed. The errors began yesterday, just after installing the update. I generate 24 charts, once an hour and this error is generated with every chart. I removed and reinstalled the plug-in with no change. Here are all of the log entries, beginning with the installation of the update. The errors continue as of this post.
Feb-28 3:40:45 PM Updater Starting download of updates
Feb-28 3:40:45 PM Updater Plugin is loaded, unloading before updating.
Feb-28 3:40:46 PM Info Plugin Device History with instance: has disconnected
Feb-28 3:41:06 PM Updater Downloading update: Device History
Feb-28 3:41:06 PM Updater Update HSPI_SKWARE_DEVICE_HISTORY.exe downloaded successfully
Feb-28 3:41:06 PM Updater Installing package Device History
Feb-28 3:41:07 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_SKWARE_DEVICE_HISTORY.exe
Feb-28 3:41:07 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_SKWARE_DEVICE_HISTORY.exe.config
Feb-28 3:41:07 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\skWare\DeviceHistory\System.Web.DataVisualization.dl l
Feb-28 3:41:07 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\skWare\DeviceHistory\Newtonsoft.Json.dll
Feb-28 3:41:07 PM Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Data\skWare\DeviceHistory\HSPI_SKWARE_DEVICE_HISTORY.db3
Feb-28 3:41:07 PM Updater Extracting files from zip file: images.zip
Feb-28 3:41:07 PM Updater Extraction Complete.
Feb-28 3:41:07 PM Updater Making dir: C:\Program Files (x86)\HomeSeer HS3\Docs\skWare\DeviceHistory\
Feb-28 3:41:07 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\Docs\skWare\DeviceHistory\skWare Device History Plug-In User Guide.pdf
Feb-28 3:41:07 PM Updater Install/Update of package Device History was successful.
Feb-28 3:41:07 PM Updater Re-initializing plugin after update.
Feb-28 3:41:13 PM Info Plugin Device History has connected. IP:127.0.0.1:51419
Feb-28 3:41:14 PM Info Device History: Upgrading from 1.0.5 to 1.0.6
Feb-28 3:41:15 PM Plug-In Finished initializing plug-in Device History
Feb-28 3:42:16 PM Event Event Trigger "Delayed Events Device History - 3 (Delayed Event)"
Feb-28 3:42:16 PM Event Event Trigger "Device History Charting Device History - 3"
Feb-28 3:42:16 PM Event Deleting event after run: "Delayed Events Device History - 3 (Delayed Event)"
Feb-28 3:42:16 PM Error Event Device History Charting Device History - 3 plugin action failed:Could not load file or assembly 'Newtonsoft.Json, Version=4.5.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Feb-28 3:44:06 PM Error Event Device History Charting Device History - 3 plugin action failed:Could not load file or assembly 'Newtonsoft.Json, Version=4.5.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
Feb-28 3:45:56 PM Error Event Device History Charting Device History - 3 plugin action failed:Could not load file or assembly 'Newtonsoft.Json, Version=4.5.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
