I've been having trouble with the various versions of the plugin and Alexa so I decided to wipe everything out and start from scratch. I'm using a Homeseer ZEE-2. I followed the instructions with the help of tech support and completely wiped the controller and set it back to factory defaults. So far, so good. So I installed the .25 version of the HAI plugin and entered the control panel configuration information. But once out of the manage plugin configuration page and/or restarting the plugin all of the panel configuration data is lost and all the fields are empty again.
What's the trick to get the panel configuration data to stick? I hit "submit" each time I entered a configuration value in a field.
